INA217 and the DC-Servo
Hello to everyone!
I was wondering if I can replace the OPA137 (I can't find it!) for the DC output control loop with another FET-input opamp. What do you suggest? Is it good an OPA134? Should I modify the schematic to implement this one? Thank you very much! Matteo. P.S: Sorry for my English... |
Where are you located? TI shows them o their web site. They even have free samples.... What package is used?
--Ethan
In Sunny Vancouver ..... (Washington) |
I alredy tried to request free samples from TI but they don't ship them to Italy for some unknown reasons... maybe because there are high taxes and tariffs. The package I need is the PDIP-8. Thank you, Matteo. |
In one of My INA217 2Ch preamps i used a TL072 for the DC Servo (half of the TL072 for each channel) and it worked just fine.....
in my later versions I simply used an High quality output cap(470uF 16v Nichicicon Muse or black gate) or a Output Transformer as opposed to a DC servo to block DC... I haven"t noticed any audible differance useing a Good output cap over the DC servo and it makes the Design much easier to implement and make for a smaller PCB..... With the INA217 you really only have any DC offset at the High gain settings and the Input of the next piece of equipment in the Chain most likely allready has an Input cap to block DC..... Good Luck
M-Audio Delta 44 + Delta 1010LT 5 Piece Drum Kit w6 Cymbals Custom Made Bass Guitar Custom Made Les Paul Guitar Mackie Traction Studio 2.1 P-4 PC w 512mb DDR 80gb HD Sell you used Equipment Here: http://www.proaux.com/phpprobid/index.php |
Thank you!! M. |
You just put a Cap in series with the output with the + of the cap faceing the Ina217 and the - of the cap connected to the output....A Good quality cap is needed here and possibly even bypass it with a good 0.1uf poly cap....
Capacitors Block DC But Pass AC so putting a cap on the output blocks any DC from entering the next piece of equipment..... Cheers PS: if you are only doing one Channel you can use the TL071...
Given that the DC offset should be a very small figure, often you'd orient the cap the other direction and use a 63V cap to block incoming phantom that was erroneously connected.
| INA217 Build... a problem | NeveSSL | DIY, Mods, and Homebrew | 40 | 05-17-2009 19:24 |
| More on the INA217 etc.... | OneRoomStudios | The Rack | 54 | 11-20-2006 12:08 |
| Chips: SSM2017 INA217 etc.... (???) | turnitdown | The Rack | 0 | 09-17-2005 13:25 |
| Are all Servo motors the same? please help me! | Plaguedog | Analog Only | 5 | 06-29-2004 12:05 |
| FS: Samson Servo 150 | battleminnow | Free Ads for Music / Recording Equipment | 1 | 02-06-2003 16:54 |
