Old 10-04-2008
nate_dennis's Avatar
nate_dennis nate_dennis is offline
Infinite Newb
nate_dennis has a reputation beyond reputenate_dennis has a reputation beyond reputenate_dennis has a reputation beyond reputenate_dennis has a reputation beyond reputenate_dennis has a reputation beyond reputenate_dennis has a reputation beyond reputenate_dennis has a reputation beyond reputenate_dennis has a reputation beyond reputenate_dennis has a reputation beyond reputenate_dennis has a reputation beyond reputenate_dennis has a reputation beyond repute
8-16 track reel-to-reel
I've looked around and haven't really seen anythreads like this; so forgive me if I'm reduntant.
I'm looking to get into analog recording and the 388 is currently at the top of my list. But, what other machines are out there?
I want to spend no more than about $500. Are there any good 8 track or 16 track units that fit that price range? I keep hearing "tascam 38" "TSR-8" and a few other units name-checked. What are their differing strengths and weaknesses? Thanks guys, you've already been so helpful to me.
Old 10-04-2008
jpmorris's Avatar
jpmorris jpmorris is offline
Tape Wolf
jpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond repute
I use the TSR-8 myself. It has its strengths and weaknesses.
On the plus side, it's fully microprocessor-controlled, which gives it nice, smooth tape handling and various other goodies like automatic punch-in. It also has built-in DBX noise reduction, with the additional ability to turn DBX off only on track 8 (e.g. for timecode) and it can be synchronised to another machine as a slave device.
On the minus side, it's only got two heads instead of three which makes alignment a problem. Also, heaven help you if anything does go wrong with the control system.
The '38 has the full three heads, but uses a simple CMOS logic system. It cannot do anything clever like slowing down as it approaches zero, or automatic punch-in. It can't be synchronized to any other machines (though other machines can be synced to it). I've heard that the sound quality isn't quite on par with the TSR-8, but I can't verify that. As with the TSR-8, some parts are still available (last I checked).
Both the '38 and the TSR-8 use 1/2" tape at 15 ips, which gives double the speed and double the track width over the 388. It does make them more expensive to run, though - the 388 uses 1/4" tape which can be had more cheaply.
Affordable 16-track machines give you the following options: Fostex or Tascam. Fostex made the B16, E16 and G16 - the E16 was something of a hit at the time and appeared in many project studios. Parts are pretty much nonexistent save for cannibalising other machines. If you're looking to get one, check the state of the heads very carefully as you won't be able to replace them at a sensible price. If you offered JRF or Phi Magnetronics enough money they'd probably make some, but I don't want to think about the price.
Tascam's offering was the MSR-16 (not to be confused with the MS16 which was a one-inch machine and more expensive). They turn up occasionally, but not much so parts are likely to be a problem, except where they are common to the TSR-8 or 38. Compatible guides etc might still be available from TEAC.
Is that helpful?
Old 10-05-2008
cjacek's Avatar
cjacek cjacek is offline
Analogue Enthusiast
cjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond repute
Good advice from jpmorris.
nate_dennis: restrict your deck buying to local sales only. Pretend as if shipping didn't exist and you'll be fine. Look over your unit carefully and bring it home yourself.
Old 10-05-2008
Infinite Newb
That would be great advice if I lived in Calli or NY or something but in South Dakota . . . not so much!!! LOL I do, however, understand the idea behind what your saying. I may be able to travel down to Denver. But that'd be about it. Thanks for all the info y'all
Lafayette RK-600a ? 2 track reel to reel tube tape recorder? Granada Analog Only 1 10-03-2008 22:40
Older books on recording, multi-track, reel to reel, etc. jjones1700 Analog Only 12 10-25-2007 03:48
Tascam 38 (8 track reel to reel, w/ remote, WORKING PERFECT! papapill Free Ads for Music / Recording Equipment 0 01-25-2006 23:02
I have a fostex Personal a series Reel to reel 8 track recorder... Theheat Fostex Forum 2 12-26-2005 19:06
Beginner Question about Reel to Reel Multi-Track recording. SwanSong Analog Only 5 05-26-2004 14:13
