cheap but decent signal splitter?
hey guys,
im looking for a signal splitter cause i want to be able to track guitars but also take down a dry signal line in case i want to reamp later. i cant afford an expensive one but also want decent quality. what do you recommend? |
What's expensive? I've had good results with the Whirlwind A/B box that's about $100 new, I think. With any of these, make sure to use a battery instead of a wall wart, if possible.
Does Naiant ( http://www.naiant.com ) make one? I've been very happy with their (Jon's) signal manipulation stuff (and mics). |
as to why a battery version is better?
I'm wanting to run multiple amps simultaneously.
"One thing led to another and, before we knew it, we were dead." --Michael O'Donoghue |
If you just need a simple splitter rather than an A/B box, any DI should work fine, they should all be able to drive several outputs. Just use a Y cable if the box doesn't have two output jacks. |
I picekd up an A/B/Y box from ART that works ok, but just ok
Splits signals fine, and lets you A/B, but has bleed from the a/b option. THat is, if B output is to a tuner, and you hit the A/B switch the amp will still get a signal, much quieter, but still audible (and the louder the amp, the louder the unwanted noise). The 'Y' function is fine, so dual amping or amp and dry signal should be fine. Daav |
Don't know if it's in your price range, but anything and everything you could possibly want in signal path manipulation is here...
http://www.loop-master.com/ |
yeah i can do the di ok with what im running, so i really just need to be able to split the signal to two outputs
| Decent splitter box? | jbroad572 | Other Equipment and Reviews | 2 | 03-28-2006 07:56 |
| Cheap and Decent? | HomelessDave | Microphones | 7 | 10-15-2005 13:10 |
| Speaker switcher? Signal splitter? | nickdahl | Mixing / Mastering | 2 | 09-25-2005 14:44 |
| Decent Cheap MIC | bsr2002 | Microphones | 2 | 01-20-2005 22:41 |
| Is this a decent signal chain? | Jotosuds | Recording Techniques | 3 | 03-11-2003 18:35 |
