Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 10-02-2008
jndietz's Avatar
jndietz jndietz is offline
The Way It Moves
jndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond repute
I need new tubes... make some recommendations!
Hey everyone... I own a B-52 ST6012 amplifier with Vintage 30s. I am interested in changing the tubes because 1) I bought the amp used and still has the same tubes and 2) right now I feel the amp has entirely too much gain. What do you guys recommend for all of the following:
Power: 2 – 6L6 / 5881
Preamp: 5 – 12AX7
Reverb: 1 – 12AT7
Rectifier: 1 – 5AR4
Thanks in advance everyone...
I play lead guitar for a rock band called Indecision based out of Omaha, Nebraska. Check us out here
Old 10-02-2008
eyema_believer's Avatar
eyema_believer eyema_believer is offline
Bondservant
eyema_believer has a reputation beyond reputeeyema_believer has a reputation beyond reputeeyema_believer has a reputation beyond reputeeyema_believer has a reputation beyond reputeeyema_believer has a reputation beyond reputeeyema_believer has a reputation beyond reputeeyema_believer has a reputation beyond reputeeyema_believer has a reputation beyond reputeeyema_believer has a reputation beyond reputeeyema_believer has a reputation beyond reputeeyema_believer has a reputation beyond repute
Preamp: 5 – 12AX7
Reverb: 1 – 12AT7
Rectifier: 1 – 5AR4
I would try buying 2 or three 12AT7s or 12AU7s and subbing them in different spots in the preamp. You'll have to try them in different spots, to see where they make the change you want. These have somewhat less gain than the 12AX7s, and will be a direct replacement for you. I wouldn't worry about the power tubes; those 6L6s won't distort until your ears bleed.
Peace!
~Shawn
Old 10-03-2008
dementedchord dementedchord is offline
Psychotic State alumni ch
dementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond repute
Peace!
~Shawn
+1...
trying at's or au's is a great idea here... as to the output tubes... if there's a degredation from age as you suggest... then the outputs are the ones to change... the pre-tubes can last for ages.... and check into rebiasing if you do change the outputs....
37.8% of all statistics are made up on the spot...
hey give a guy some room... people are trying to evolve here... for crying out loud...
Old 10-03-2008
ocnor's Avatar
ocnor ocnor is offline
Lord Of The Thighs
ocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond repute
12AT7s and 12AU7s draw more current and are NOT direct replacements for 12AX7s in all amps. Also it's not always immediately apparent that the amp is being damaged.
Old 10-03-2008
cobradenim's Avatar
cobradenim cobradenim is offline
Senior Member
cobradenim has a reputation beyond reputecobradenim has a reputation beyond reputecobradenim has a reputation beyond reputecobradenim has a reputation beyond reputecobradenim has a reputation beyond reputecobradenim has a reputation beyond reputecobradenim has a reputation beyond reputecobradenim has a reputation beyond reputecobradenim has a reputation beyond reputecobradenim has a reputation beyond reputecobradenim has a reputation beyond repute
www.eurotubes.com
Old 10-04-2008
antichef's Avatar
antichef antichef is offline
unfocuser
antichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond repute
yeeks!! what happens?
Old 10-04-2008
ErichS ErichS is offline
Senior Member
ErichS has a reputation beyond reputeErichS has a reputation beyond reputeErichS has a reputation beyond reputeErichS has a reputation beyond reputeErichS has a reputation beyond reputeErichS has a reputation beyond reputeErichS has a reputation beyond reputeErichS has a reputation beyond reputeErichS has a reputation beyond reputeErichS has a reputation beyond reputeErichS has a reputation beyond repute
This place has some good reviews and decent prices for tubes
http://thetubestore.com/
Old 10-04-2008
Bondservant
Which explains why they have more headroom, I suppose. I will edit my post. Thanks for the heads-up.
Sorry to the original poster for making a recommendation that had been made to me and worked fine for me, but potentially could damage an amp.
Peace!
~Shawn
Old 10-04-2008
Bondservant
Exclamation Look Here Look Here Look Here Look Here!!!!!!!!
Well, for some reason I can't edit my previous post about 12AU7s and 12AT7s. If someone in the future reads this shaky advice, PLEASE read this entire thread before proceeding, paying careful attention to this warning:
Old 10-04-2008
and yet it seems the book i have here lists them as lower than ax7's... even if we assume that there's some varience from brand to brand one would still wonder what problems you experienced...
Old 10-04-2008
ggunn ggunn is online now
Crystal Flavolian
ggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond repute
I don't think that there is a direct correlation between the gain of a tube and the current it consumes. That said, it's kind of hard to imagine that a preamp tube drawing a little more current could hurt (I presume) the power transformer, since the current consumed by a preamp tube (I'm pretty sure) is small compared to that drawn by the power tubes. In most/all tube amps, the preamp and power tubes pull their current from the same tap on the power tranny.
Gordon in Austin
http://www.crystalflavola.com
  #12
Old 10-04-2008
agreed... though he seemed worried about the current handling of the heater tranny specificlly... or did i miss read something again???
  #13
Old 10-04-2008
ocnor's Avatar
Lord Of The Thighs
Over at the Carvin boards, some guys with way more knowledge than I have, stated that certain resistors in some amps may not be rated for the extra current draw. They also showed pictures of toasted resistors and circuit boards which resulted from using 12at7s. Another person stated that his amp fried when he substituted 12au7s in place of 12ax7s. Some amps may be fine with the substitutions but just make sure before you do it.
  #14
Old 10-04-2008
Corndog Corndog is offline
I'm an idiot
Corndog has a reputation beyond reputeCorndog has a reputation beyond reputeCorndog has a reputation beyond reputeCorndog has a reputation beyond reputeCorndog has a reputation beyond reputeCorndog has a reputation beyond reputeCorndog has a reputation beyond reputeCorndog has a reputation beyond reputeCorndog has a reputation beyond reputeCorndog has a reputation beyond reputeCorndog has a reputation beyond repute
I swapped out the 12at7 for a 12ax7 in my '77 Fender Super Twin...is that bad??? I never trusted anything with tits or tubes.
  #15
Old 10-04-2008
ocnor's Avatar
Lord Of The Thighs
If you put a 12ax7 in a circuit designed for a 12at7 then you had better keep the fire extinguisher handy.
  #16
Old 10-04-2008
jndietz's Avatar
The Way It Moves
How about this question... where can I get myself a good multimeter?
  #17
Old 10-04-2008
Bondservant
double post
  #18
Old 10-04-2008
Bondservant
triple post!!
  #19
Old 10-04-2008
Bondservant
[QUOTE=ocnor;3014561] If you put a 12ax7 in a circuit designed for a 12at7 then you had better keep the fire extinguisher handy. [QUOTE]
So you're saying that if you put a tube that draws less current in place of one that draws more current you're creating a distressful situation inside the amp? Not that I know anything about anything.....but usually stuff only gets too hot when you draw more current than a circuit is designed for....dunnit?
  #20
Old 10-04-2008
antichef's Avatar
unfocuser
I use a 12AT7 in my 1965(ish) Epi 101 single EL84 amp. All the 12AX7s I tried tended to overpower the EL84 and it got farty sounding. Much better with the 12AT7 -- is it as simple as burning up a resistor? I can fix that
  #21
Old 10-04-2008
Bondservant
I have a Kalamazoo Model One single ended amp with a single EL84 output tube, and I did the same thing. It worked wonders!
  #22
Old 10-04-2008
ocnor's Avatar
Lord Of The Thighs
No I said that if you put a tube that handles less current[12ax7] into a circuit meant for a 12at7 that is feeding it more current that you will cook the 12ax7 causing other components to fail.
Yes resistors are easy to replace. But in modern amps with printed circuit boards if you burn the traces it becomes a little more tricky to repair.
  #23
Old 10-04-2008
dgatwood's Avatar
dgatwood dgatwood is offline
is out. Leave a message.
dgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond repute
You folks are all kidding, right?
1. There's exactly one rating that matters in preamp tubes (assuming the pinouts are the same), and that's the voltage.
2. The tube heater is a resistive load and will draw exactly as much current as it needs to draw. No more, no less. So there's no difference in tube life expectancy caused by substituting a device with lower or greater current draw. That's like asking whether a light bulb will burn out sooner if you hook it up with a heavier gauge lamp cord. It won't....
3. If your amp can't produce enough current for the tube heater, it will result in a voltage drop and the wires will heat up and the tube's sound won't be as good (or if the current limit is caused by a fuse, it will blow the fuse). Since we're just talking about a 12V current source, though, I can't imagine an amp design not being able to provide enough current. We're dealing with current in the hundreds of milliamps here. It's peanuts. The cheapest, smallest regulator or Zener you could buy should handle that little trickle....
4. All of the 12A*7 tubes are designed for a 150 mA, 12.6V supply. While there is individual variation from manufacturer to manufacturer, if your amp doesn't provide at least 150 mA, it is broken by design, and if a tube draws more than that, it is defective. In other words, the supply for a 12AX7 has to provide exactly the same voltage and current as the supply for a 12AY7 or a 12AT7 or a 12AU7 or....
In other words, you won't have any problem swapping around preamp tubes. You probably shouldn't be swapping power tubes without rebiasing, but you really can't go wrong swapping out preamp tubes as long as it's a 12A*7 or any other pin-compatible 12V tube (5965, 6072, etc.)....
One caveat: if the tubes happen to be arranged in a push-pull configuration, make sure you're using similar tubes for both sides or else you'll have a really weird output.
My bet would be a defective tube, but if not, Carvin should recall the amps. If they can't handle a 12AU7, you can pretty much guarantee that they can't handle a lot of 12AX7 models, either.
Originally Posted by Obi-Wan
If you mod me down, I will only grow stronger.
  #24
Old 10-05-2008
I'm an idiot
My Twin has 6 6l6's and I've been told that I can take the 2 outside tubes out to tame the volume. Is this ,in fact,correct???
Sorry to hi-jack thethread BTW...
  #25
Old 10-05-2008
darrin_h2000's Avatar
darrin_h2000 darrin_h2000 is offline
Been Here, Posted That
darrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond repute
I dont think that the 12ax7 will pull more current to get the higher gain...its saturation point is much lower than the tubes that will be cleaner 12at7 so they in turn must have that point higher requiring more voltage which is why PC boards on new amps can get hotter than they should...my tube stuff for the most part has no PC boards inside...but it is also all from the 1960s...and things were made very different back then.
wayne
RCA Tubes = Amperex Tubes ?? Mach5 Guitars and Basses 6 02-14-2006 07:27
groove tubes w/o tubes or the ksm family les666paul Microphones 5 12-06-2005 18:39
Tubes, tubes, tubes! Should I swap the tubes in my TSL601? Whoopysnorp Guitars and Basses 16 11-21-2004 18:23
is it the tubes that make the sound? smythology Other Equipment and Reviews 4 02-04-2003 16:27
broken tubes in mesa. can i switch to the other tubes & still play & not blow a fuse? videodrone Guitars and Basses 11 10-30-2002 16:44
