Tascam M520 meter bridge bulb replacement
I am the proud new owner of a pretty damn clean Tascam M520!
I traded this guy in one of my classes for a telecaster (mexican) and 50 bucks. It came with 2 patch bays and a bunch of half done cabling. I just learned how to solder so I will be able to complete them, its going to a take a bit of time tho. The one thing that i want to do that I don't know how to do it changing the meter bridge bulbs. There are 4 that are out. I read in sweetbeats M520 story that there is some devilish cement in there somewhere and I was wondering if anyone could share on the best way to replace the bulbs. Thanks alot |
check with sweetbeats... he did a thread not too long ago when doing his...
37.8% of all statistics are made up on the spot... hey give a guy some room... people are trying to evolve here... for crying out loud... |
Start reading at post #222 in my Tascam M-520 Story thread.
There are a couple ways to go on this. The first issue is that the proper bulbs for the VU's in the 500-series boards (and others for sure) are no longer available from Tascam. They do have bulbs, but they are the shorter variety as is found in the likes of the 38, 48 and 58 decks as well as many others. The second issue is that the bulbs come "naked" (without the metal "fuse" caps) The first issue is not really much of an issue except for physical appearances of the bulbs themselves, but as far as my eye can see, the luminesence is indistinguishable from the original longer bulbs. The second issue is where you've got choices. If you're a freak like me, then you're going to find a way to get the metal caps off the old bulbs, and its not easy...
I'll be doing the rest of mine this way even though it is a PITA...I'm sure there is a better way but... The other option is to just do as they did in the meters on the decks and solder the bulb in...there is no fuse-like "bulb holder" in the smaller meters. I wanted to leave the bulb holders intact in my M-520 and that is the other reason I opted to do it the hard way |
Thanks alot
Sounds like its a little involved.... ![]() Im not a stranger to soldering but it is kind of intimidating doing it on the VU. Im going to be Opening it up pretty soon. I am kind of nervous. So I am going to have to order the bulbs from Tascam I presume. Should be pretty cheap right? |
How many bulbs are out?
The bulbs are not cheap. About $8 each. |
4 bulbs are out
8 bucks a pop is a little steap, but I need that glow. I need that glow. |
Actually, only 2 bulbs are out. In the m520 bulbs are wired in series 2 at a time. When one of the 2 burns out they both are dark. less money for you. But, you should realize that if any are burning out then the others are of the same age and are just waiting for the right time to go themselves. ![]() Some day I will need to get a nice replacement worked out. --Ethan
In Sunny Vancouver ..... (Washington) |
Is there a PDF manual floating around online?
I am trying to figure out how I am going to hook up my patch bay and I have questions on alot. Aux? Aux out? The whole Sub in section? Why is there 2 outputs for the PGM faders. Are they indipendent? How does the Talkback work. I see no outputs on the back for it A manual would be sweet. |
The M520 is an 8-buss board.
Each PGM (buss) output has 2 connectors in bridged mono. They are the same signal and are not independent. This enables the 8-buss board to support a 16-track tape deck, as Buss-1: Track 1/9 Buss-2: Track 2/10 Buss-3: Track 3/11 etc.,... with differentiation between low-order and high-order tracks being done with the recorder's track-arming panel. Hope that makes sense. /DA
a.k.a. Davemania! Beatles and other Classic Rock covers!! Yeah, Yeah, Yeah!!! 637 songs by 191 bands.
kind of....
could you give it to me in other words? I am kind of confused.. |
The M520 has 20 Input channels and 8 Pgm Busses.
Each Pgm Buss has two output jacks of the same signal in parallel, not stereo or independently controlled. Each of 8 buss outputs would hook to 2 inputs each on a 16 track deck. Pgm Buss out #1 hooks to Tape Inputs #1 and #9, because each Pgm Buss has 2 outputs. Channeling Input signals on the M520 and assigning them to Pgm Buss 1 would feed Tape Tracks 1 and 9, the only difference or selection process between either Track 1 or Track 9, or both, is which one is set for Rec-Enable on the tape deck. Otherwise, in buss mode the mixer feeds each of 8 buss outputs to 2 output jacks which are the same signal on each jack, so each buss output sends the same signal to 2 tape tracks simultaneously on a 16 track deck. The differentiation being which tape track is set to record enable at that particular moment.
#12
How you setup your patchbay will depend entirely on your setup, and what you will need to/want to frequently access. Since, at this time, I'll be interfacing the M-520 with an 8-track deck and I have 8 channels of compression and 8 channels of parametric eq I'll probably have the SEND/RCV jacks for 8 of the 20 channels on a patchbay...no need to have the tape deck I/O on a patchbay as that can be permanently connected and switch-selectable. Not sure yet how the M-520 will be interfacing with my digital rig so it remains to be seen what goes to a patchbay and what gets permanently connected...So you see, it all depends.
The talkback mic can always be routed to the STEREO B MASTER OUT jacks...the STEREO B buss is intended to be utilized for an amp and monitor speakers in your recording room as opposed to the control room. To do this just press the T/B button just to the right of the mic, and adjust the level via the T/B pot directly above the mic. You can also route the talkback mic to the AUX 1/2 buss, AUX 3/4 bus, or all 8 PGM busses simultaneously. To do this, flip the slate source switch (that's the one just below the the test tone frequency selector) to SLATE, and then depress whatever buss to which you want to route the talkback mic in the switchrack just below the slate source switch. The level of the talkback mic to the buss you select is determined by the SLATE level pot directly above the T/B level pot. |
| Tascam 234 Syncaset Backlight Bulb Replacement? | morbank | Analog Only | 3 | 07-24-2007 09:44 |
| Tascam DM-3200, Meter Bridge, Firewire (If-FW/DM mki) Card | stefancolson | Free Ads for Music / Recording Equipment | 1 | 06-01-2007 09:37 |
| Meter Bridge | Dumby | Roland, Boss, VS Series Forum | 0 | 12-07-2006 14:47 |
| FS : ny/nj area tascam DM24 with meter bridge, 2 adat option cards, new skb 3331 case | ravyr | Free Ads for Music / Recording Equipment | 0 | 08-05-2005 20:14 |
| Tascam DA 88 Meter Bridge Cable PW88M for the MU8824 | Wire | Free Ads for Music / Recording Equipment | 1 | 03-14-2005 20:24 |
