Go Back   Home Recording > Equipment Forums > Microphones
Reply    Audiofanzine Microphone Microphone News Microphone Medias Microphone Tests Microphone Articles Microphone User Reviews Microphone Classifieds Ads
Old 09-22-2008
AMcB's Avatar
AMcB AMcB is offline
Why you gotta be so mean?
AMcB has a reputation beyond reputeAMcB has a reputation beyond reputeAMcB has a reputation beyond reputeAMcB has a reputation beyond reputeAMcB has a reputation beyond reputeAMcB has a reputation beyond reputeAMcB has a reputation beyond reputeAMcB has a reputation beyond reputeAMcB has a reputation beyond reputeAMcB has a reputation beyond reputeAMcB has a reputation beyond repute
Cond Mic cutting in and out help!!!!
My vocal mic, to be more specific Groove Tubes GT57 keeps cutting out. But only sometimes when it moves or if I hold it in a certain spot but not the same every time. Sometimes on the side or upside down or if it is bumped a bit. It's not the cable or the connection because if you wiggle it it doesn't do anything. When it cuts out it's just a lound fuzzy sound. Is this normal? I know there delicate mics, but it doesn't seem normal. Please help!
Old 09-22-2008
dgatwood's Avatar
dgatwood dgatwood is offline
is out. Leave a message.
dgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond repute
Sounds like a loose wire somewhere. If it isn't on the backside of the connector, it's probably a wire between two circuit boards or between the capsule and the board.
Originally Posted by Obi-Wan
If you mod me down, I will only grow stronger.
Old 09-23-2008
AMcB's Avatar
would it be safe to take it apart and try to fix it? Or pay to get it fixed? Or get a new one?
Old 09-23-2008
Big Kenny Big Kenny is offline
Been Here, Posted That
Big Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond repute
check cables 1st, then, only take apart what you are positive you can reassemble. Look around for loose connects or wires, if it's on the board and you are new to soldering STOP there.
In His Name
Big Kenny
Old 09-23-2008
AMcB's Avatar
ts not the cable. I can't see any loose connections on the board anywere but I can't see up into the capsal, should I take it apart further and see if I can find something or just give up. I am very scared to do this because I don't want to comepletely ruin it, cause it work sometimes now.
Old 09-23-2008
pohaku's Avatar
pohaku pohaku is offline
1K Silver Member
pohaku has a reputation beyond reputepohaku has a reputation beyond reputepohaku has a reputation beyond reputepohaku has a reputation beyond reputepohaku has a reputation beyond reputepohaku has a reputation beyond reputepohaku has a reputation beyond reputepohaku has a reputation beyond reputepohaku has a reputation beyond reputepohaku has a reputation beyond reputepohaku has a reputation beyond repute
It sounds like something loose or a bad solder joint. If you aren't comfortable taking it apart to look, then don't do it. Find a suitable electronics repair shop to repair it. Ask about their bench fees before you agree to the work.
Yeah I'm an attorney, but everyone needs a day job.
Looking for a ~$150 (around or less) cond. mic as an upgrade Nogibak Microphones 14 12-03-2007 01:57
oxy gasoline cutting torch - oPetrol cutting torch denniswang Other Equipment and Reviews 12 01-20-2006 09:09
4-Cond vs 2- Cond Mic Cable - RF Interference? teetopkram Microphones 3 04-07-2005 12:09
XP-30 fs, excellent cond 600 1 1 Meta 2 2 2 Free Ads for Music / Recording Equipment 2 11-12-2002 04:40
