Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 09-14-2008
jman1986 jman1986 is offline
Senior Member
jman1986 has a reputation beyond reputejman1986 has a reputation beyond reputejman1986 has a reputation beyond reputejman1986 has a reputation beyond reputejman1986 has a reputation beyond reputejman1986 has a reputation beyond reputejman1986 has a reputation beyond reputejman1986 has a reputation beyond reputejman1986 has a reputation beyond reputejman1986 has a reputation beyond reputejman1986 has a reputation beyond repute
MIDI mixing question
hey i have some drums recorded in pro tools that are midi. i am not sure if i should post this in the midi or pro tools thread, so heres the question.
Is there a way to like select all the bass drum notes or even the snare notes in pro tools to make the velocity the same, is there a setting i can make or something? also is there a way to just like make the snare drum or bass drum notes play by them selves (while the other notes are muted). cuz i just wanna hear the snare "track" alone to make and changes to it.
-Jesse
Old 09-20-2008
Gandalf's Avatar
Gandalf Gandalf is offline
Number 10
Gandalf has a reputation beyond reputeGandalf has a reputation beyond reputeGandalf has a reputation beyond reputeGandalf has a reputation beyond reputeGandalf has a reputation beyond reputeGandalf has a reputation beyond reputeGandalf has a reputation beyond reputeGandalf has a reputation beyond reputeGandalf has a reputation beyond reputeGandalf has a reputation beyond reputeGandalf has a reputation beyond repute
I haven't ever used PrTools, but I can tell you how to do this in Cubase. I'm sure there are similar functions in ProTools, and this may help you find them (or not)...
In order to only hear or apply functions to kick or snare or whatever I usually record them to seperate tracks. If I haven't then I copy/paste the whole drum track multiple times and then delete all but the kicks from one, all but the snares from the next etc. You can then apply individual fucntions or solo etc. I send the midi output from all the drum tracks to the same midi channel (unless I want to use the kick from one kit but the snare from another etc).
As far as making all the kicks the same velocity.... are you sure you want to do that? It will make the drums sound more synthetic which is fine if you are making dance music but if you're not.....
Anyway, if you want to do this in Cubase then it has velocity functions under midi/functions/velocity. You can limmit between 2 values, compress by a % or set all velocities the same via the fixed volicity menu.
I'm sure if you look in the ProTools help under velocity then you will find something similar.
Old 09-20-2008
killthepixelnow killthepixelnow is offline
Do it right or dont do it
killthepixelnow has a reputation beyond reputekillthepixelnow has a reputation beyond reputekillthepixelnow has a reputation beyond reputekillthepixelnow has a reputation beyond reputekillthepixelnow has a reputation beyond reputekillthepixelnow has a reputation beyond reputekillthepixelnow has a reputation beyond reputekillthepixelnow has a reputation beyond reputekillthepixelnow has a reputation beyond reputekillthepixelnow has a reputation beyond reputekillthepixelnow has a reputation beyond repute
Yes, you can (Ha, I'm not Obama) Well, there's an easy way to individualize your MIDI. Here's what I usually do:
1. Create an Instrument track
2. Create 4 MIDI channels
3. Put your DRUM instrument (Reason, BFD2, DKFH) on the Instrument track.
4. All the MIDI channels go to the Instrument track.
Now, you already have your MIDI so you must select all the notes (CTRL+ Clic on the Piano roll) of a same piece and copy them to one of the MIDI channels:
4. MIDI channel#1: Cymbals
MIDI channel#2: Toms
MIDI channel#1: Snare
MIDI channel#1: Kick
In that way you can Mute/Solo any piece individually. You can also bounce just the kick or maybe kick and snare. It's up to you.
To even all the note use the same method for selecting all the notes and go to MIDI Change velocity (I'm not in my computer so maybe it's in another Menu) In that window you can put the same velocity to all notes which I don't recommed 'cause it will sound like a damn robot. Randomize some notes to get a more natural feeling.
Hope this info will help you.
Old 09-21-2008
Here you can see how I separate a drumkit in different channels:
Good Luck!
Question: Mixing down MIDI? Xipe Cakewalk / Sonar Forum 2 10-29-2004 08:35
MIDI mixing Dr Shock Cool Edit Pro / Adobe Audition Forum 3 04-29-2004 08:06
Mixing Down Question (audio and midi) dmbpettit Cakewalk / Sonar Forum 11 03-06-2003 11:46
midi mixing figmos Mixing / Mastering 2 10-28-2002 13:50
MIDI and Korg X5D synth question - see MIDI Mania forum - thank you. kirkhere Newbies 0 08-09-2001 11:10
