DBX or No DBX and more newbie questions
I'm at home (6:11 a.m
) after my first recording session with my TSR-8.We have been recording a rehearsal, trying to get used to setting levels in analog, etc. I got some questions that I hope you can answer. 1. Do you use DBX in your recordings? First I assumed that DBSX had to be better but I think that my DBX tracks have a more polished sound that I find less natural. Not sure about that. On the other hand, tracks recorded without DBX are obviously a bit more noisy, although not that much because I recorded with pretty hot levels. I like to know your experience about this. 2. Is it true that I should use tracks 1 and 8 for "less important" instruments? Why? 3. How many times it's reasonable to re-use new tape. 3, 10, 500? Thanks in advance |
Yes. However, I mix to tape, and I don't use any NR on the master machine so I guess it evens it out in terms of polish.
thanks again JPMorris.
As I'm not mastering myself this time (I'm planning to leave that to a pro) do you think is better for that to have a no NR project or it doesn't make a difference? Regarding 3, I didn't meant to re-use old tape. Let's say we're recording live and we make a mistake. I suppose it's ok to return to zero position and press record again, isn't it? Generally, how many times can you do that until there is some noticeable tape degradation? |
You should not be hitting the tape hard when using dbx. Peaks of -7 or so are plenty.
If you have a manual for your recorder or if you can find a dx-4d manual it will mention to keep levels lower when using dbx. If you are looking for tape saturation and compression you need to turn the dbx off. As far as the using the tape over again its alot. But I dont think I would be eating up a bunch of tape for a practice. |
| 2 Newbie Questions | Kaulback | Keyboards and Sound Modules | 33 | 11-29-2004 11:58 |
| I have several newbie (*extremely* newbie) questions | Guitar Jim | Newbies | 7 | 11-25-2004 11:21 |
| Some newbie questions about the MR8 | That_Abbott | Fostex Forum | 6 | 04-20-2003 21:19 |
| Computer & Mixing Questions (Newbie questions I suppose) | Scinx | Digital Recording & Computers | 0 | 04-12-2003 09:47 |
