Old 09-06-2008
horizon_scott horizon_scott is offline
Newbie
horizon_scott is on a distinguished road
vdrums to trigger midi? :S
i was wondering how i'd go about using roland v-drums to trigger any midi? i dont have access to them yet but i will do soon and id like to know in advance so i can walk in.
im using:
roland v-drums, edirol UA25 midi interface?
do i need a usb to midi cable and how do i go about configuring stuff?
Old 09-06-2008
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
The drum brain has a midi output that you would plug into the midi input of what ever sound module you wanted to trigger the sounds from.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 09-06-2008
Newbie
so should i go straight from the brain into the laptop via midi - usb?
Old 09-06-2008
Farview's Avatar
Midi. You will need a midi interface. You will also need software to record the midi and some sort of synth (software or hardware) to play the sounds.
Jay Walsh
Old 09-06-2008
Whale Bone Whale Bone is offline
Senior Member
Whale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond repute
I haven't spent much time on it, but when I experimented with it, I found that the V-Drum doesn't necessarily transmit what it sounds through its audio output. I'm specifically referring to the hi-hat - there's a certain 'intelligence' or sensitivity that it applies to the pedal position that's not reflected in the MIDI output.
I tried recording MIDI from the V-Drums and what I recorded was a hi-hat either open or closed (instantly choked), whereas what I was playing had varying degrees of openness on the hi-hat. The audio from the drums reflected what I was doing, but the midi when played back through my JV-1080 or the V-Drums themselves didn't sound right.
There may be ways or dealing with this or compensating, but I didn't look that far into it.
Old 09-07-2008
Newbie
yeah i have the edirol UA25 which is midi so i guess i can just use that
or..
ive seen cables that are just midi out and then to USB straight into the computer, does that not work?
and yeah i have suficient programs, ezdrummer and cubase so i know how to work that, its just the whole setup thats confused me
Old 09-07-2008
KineticSound's Avatar
KineticSound KineticSound is offline
The VOICE
KineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond repute
Correct. You can simply connect the midi jacks on your V-Drums to the midi jacks on your UA25, which then goes to the computer via usb.
I've run into the same hi-hat issues that were previously mentioned by Whale Bone. It seems that the output for the hh control is limited to open & closed, instead of the multi-stepped control that the V-Drums are actually capable of. If anyone knows of a workaround to get the V-Drums transmitting more finite hh control, I'd love to know how to make that work.
Old 09-07-2008
Farview's Avatar
or..
There is no point to getting the midi to usb cable if you already have the au25
Jay Walsh
Old 09-07-2008
Newbie
okay cool, but if i didnt take the edirol could i do it straight from midi to usb or is this not possible?
Old 09-07-2008
Farview's Avatar
There has to be some sort of device that converts midi to usb. It exists, but you already have the ederol.
Jay Walsh
roland t6 vdrums as a midi controller? coolsoundman MIDI Mania 3 10-24-2006 16:38
Vdrums, MIDI, DFH - help ! PinkFloyd Drums and Percussion 4 03-09-2004 08:50
MIDI from Vdrums into CEP ? PinkFloyd Cool Edit Pro / Adobe Audition Forum 5 10-19-2003 19:51
trigger to midi out bevins Drums and Percussion 1 03-23-2000 22:13
Midi trigger? Cliff Drums and Percussion 0 03-16-2000 14:48
