Old 09-04-2008
blackscot's Avatar
blackscot blackscot is offline
Senior Member
blackscot has a reputation beyond reputeblackscot has a reputation beyond reputeblackscot has a reputation beyond reputeblackscot has a reputation beyond reputeblackscot has a reputation beyond reputeblackscot has a reputation beyond reputeblackscot has a reputation beyond reputeblackscot has a reputation beyond reputeblackscot has a reputation beyond reputeblackscot has a reputation beyond reputeblackscot has a reputation beyond repute
Looking for Stereo Volume Pedal to Control Studio Monitors
I use my home-recorded backup loops to jam guitar to in real-time, and would like the abaility to fade-out the backup while playing. Seems like routing the monitors through a single (stereo) pedal would allow that.
I've seen some stereo pedals around, but can't tell whether they would be suitable for running monitors through. Most product descriptions specifically refer to keyboards, guitar stompboxes, etc. I would need something spec'd to handle the monitors.
Thanks for any help.
Old 09-04-2008
suprstar's Avatar
suprstar suprstar is offline
it aint ez bein' green...
suprstar has a reputation beyond reputesuprstar has a reputation beyond reputesuprstar has a reputation beyond reputesuprstar has a reputation beyond reputesuprstar has a reputation beyond reputesuprstar has a reputation beyond reputesuprstar has a reputation beyond reputesuprstar has a reputation beyond reputesuprstar has a reputation beyond reputesuprstar has a reputation beyond reputesuprstar has a reputation beyond repute
I think that'd work just fine. Never tried it but I dont see why it wouldnt work. Basically, all a volume pedal is is a passive potentiometer that goes from off to full volume. Any line level signal should be affected the same way, just make sure you're controlling the signal before it goes to the monitor amp.
Old 09-04-2008
blackscot's Avatar
Senior Member
Thanks. Here are a couple items I'm looking at. I'm guessing that the "low impedence" feature is what is needed for my application.
http://guitars.musiciansfriend.com/p...dal?sku=151317
http://guitars.musiciansfriend.com/p...dal?sku=151041
How do you control the volume of your Active studio monitors? ambi Mixing / Mastering 92 02-26-2009 00:16
Volume control for Monitors clinton Recording Techniques 2 09-18-2006 01:46
Volume control for monitors clinton Digital Recording & Computers 4 09-16-2006 23:12
Between your DAW and Monitors...VOLUME CONTROL, which one r u using? johnbono Mixing / Mastering 16 08-16-2005 05:49
