need help dm 4800
I have dm 4800 with cubase 4 on xp system win I try to use the remote layer and touch fader 1 it jumps to channel 9 in cubase I have restarted the computer and the board with still no luck faders 1-8 on the board control 9-16 in cubase how do I get it to control channel 1 in cubase with the first fader on board
thank you for your help |
Yes, you have to setup the DM4800 with the Mackie Control. You also have to make sure that all your inputs and outputs are set correctly inside the DM4800. Mine is set up as:
1-24= Output to FW card (Cubase Input) 25-48= returns from Cubase (Cubase Output) Unless of course you are using it ONLY as a control surface....and not as an input to your recording software.
Custom 2.8 Quad Core Duo w/3 GB RAM (2) 250 GB Internal drive WD 120GB External Drive Behringer MX9000 Cubase SX3 Presonus Firepod (2) KRK V8's w/RP10 Sub Sabatur Records http://www.myspace.com/sabaturstudios |
| Dm 4800 | James.Folk | TASCAM User Forum | 1 | 05-03-2008 02:09 |
| need help with Dm 4800 | Affordabledemos | TASCAM User Forum | 0 | 04-07-2008 11:47 |
