PCB-making question
Hey y'all,
I made an etching tank with some directions I've found online, but haven't tried to make a PCB yet. The tank is built from a fairly large, plastic cylinder: about 5-7 inches in diamter and about, oh ... a foot high maybe. I put a hole in the bottom and ran a tube with holes in it along the bottom. I attached it to the bottom with hot glue and sealed the spot where the tube enters with hot glue as well. I ran a test with water in the tank, using a fish pump to create bubbles, and it works great. My question is this: Can the etching fluid be used more than once? And if so, what should I store it in during the meantime? Thanks
famous beagle |
I have cca 5liter canister for it, it is from water used in car sprinklers (?). I use FeCL (ferric chloride or what is the actual name) for etching. I always return the most of the used etchant back to the canister, and flush the tank with water. Etching will get slower through time, but it can be used long.
BTW what do you use to get the traces onto the copper? I was playing a few times with toner transferring, but that didn´t work too well beacuse of the paper used mainly.
famous beagle |
That is the way I do it too, I was just hoping for some easy way to do it easier
I use a muriotic acid and Hydrogen peroxide mixture for etching....it is super cheap and works super fast, definately better than Feric chloride and even better than sodium persulfate....
I use Ziplock freezer baggies to etch in...i just put my PCB in the bag with a bit of etchant and seal the top and agitate...I get a etched board in less than 5 minutes.... Cheers
M-Audio Delta 44 + Delta 1010LT 5 Piece Drum Kit w6 Cymbals Custom Made Bass Guitar Custom Made Les Paul Guitar Mackie Traction Studio 2.1 P-4 PC w 512mb DDR 80gb HD Sell you used Equipment Here: http://www.proaux.com/phpprobid/index.php |
I've heard about this before too. What do you do when you're done with the solution? And if you dispose of it, where do you dispose it? And is it harmful to the environment? I kind of like to be as environmentally friendly as I can be.
famous beagle |
“Build a man a fire and he'll be warm for a day. Set him on fire and he'll be warm for the rest of his life." |
I use 1 part acid with 2 parts Peroxide...but you can go as high as 1:1....
to dispose of the acid i just pour in some bakeing soda which neutralizes the acid, I then water it way down and flush down the Drain..... Cheers PS: muriotic acid isn"t really that toxic ,I use it in my Pool to adjust the PH and I also use it to adjust the PH for watering my hydroponic Garden...Once the acid is well diluted and neutralized it is pretty benign.... Cheers
famous beagle |
Spray it on your roses!
what about the copper?
*it wont hurt a dang thing int eh environment* good god, people act like *ooh, lead*, your bullet that missed the animal will put lead in teh soil... its a hazard... hee hee do you all KNOW where lead for lead balls (lotsd of them...) in the civil war came from down south? "lead bearing soil areas" honestly. you just take a few shovelfulls of dirt, sprinkle it over a good campfire slowly... in the morning, you dig thru the cooling ashes to find the lump of lead, LMAO *if it were dangerous, there wouldn't be any trees or grass or deer around those areas, right?* looks as healthy as any other area, to be truthful. as long as you dont drink or eat it, the used etching solution will harm nothing simply tossed out hte window into the grass. Its not like your emptying a 55 gallon tank daily in an industrial setting. a little bit of copper will hurt nothing. a lot of chemical names sound worse then they are. I wanna say acetic acid is vinegar, but dont quote my memory, lol would you drink DiHydrogen-Monoxide? sound dangerous? (water...lol) |
| major n00b question about making beats! | chris86 | Newbies | 10 | 10-26-2007 16:58 |
| Question...Making the Switch to DAW...on a budget? | Richie Woods | Newbies | 10 | 06-08-2003 16:27 |
| Making a home studio question | Manik | Newbies | 19 | 07-17-2001 02:12 |
| Cable making question | ditnoj | Newbies | 1 | 06-04-2001 09:47 |
