Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 04-27-2001
getuhgrip's Avatar
getuhgrip getuhgrip is offline
Politically Numb
getuhgrip has a reputation beyond reputegetuhgrip has a reputation beyond reputegetuhgrip has a reputation beyond reputegetuhgrip has a reputation beyond reputegetuhgrip has a reputation beyond reputegetuhgrip has a reputation beyond reputegetuhgrip has a reputation beyond reputegetuhgrip has a reputation beyond reputegetuhgrip has a reputation beyond reputegetuhgrip has a reputation beyond reputegetuhgrip has a reputation beyond repute
Arrow
What are the aux inputs on a mixer used for? Is there a relatively new book that lays out cable routing?
Mom tried to abort me, but I got better!
Old 04-27-2001
MISTERQCUE's Avatar
MISTERQCUE MISTERQCUE is offline
Not Just Anutha Brutha
MISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond repute
The purpose of auxes on boards are two-fold;
They can be used as extra line inputs or for signal effect processing (which most individuals use it for).
Most boards will have several auxes assigned as "Aux Send"; to send a signal to a outboard effect processor such as 'verbs,compression, equalization etc,and a
"Aux Return" where the effect processor sends the processed signal back to the board.
Old 04-28-2001
hixmix's Avatar
hixmix hixmix is offline
Halibut, North Dakota
hixmix has a reputation beyond reputehixmix has a reputation beyond reputehixmix has a reputation beyond reputehixmix has a reputation beyond reputehixmix has a reputation beyond reputehixmix has a reputation beyond reputehixmix has a reputation beyond reputehixmix has a reputation beyond reputehixmix has a reputation beyond reputehixmix has a reputation beyond reputehixmix has a reputation beyond repute
Cool
The Q forgot to point out that aux inputs can be used for cooking breakfast, too.
Old 04-28-2001
Gidge's Avatar
Gidge Gidge is offline
Lapdance Test Dummy
Gidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond repute
Cool
Hix, Im not gonna bother Dragon by sending him this post...Hes got enuff to deal with right now...Ill just ask you to leave this foolishness in the Cave....
Old 04-28-2001
Tapehead's Avatar
Tapehead Tapehead is offline
Dedicated Member
Tapehead is a jewel in the roughTapehead is a jewel in the roughTapehead is a jewel in the rough
Aux sends for compression or eq? That's what your channel inserts are for. These require full signal processing not a tap off the main signal which is what an aux is.
Old 04-28-2001
MISTERQCUE's Avatar
Just using those as a figure-of speech in signal processing!
Also I use both methods; I use comping in BOTH auxes
and inserts for across the board and solo track processing.
So There!! Naa-na-Na-na-Naa!
Old 04-29-2001
VOXVENDOR's Avatar
VOXVENDOR VOXVENDOR is offline
Shhhhhh, it's a secret.
VOXVENDOR has a reputation beyond reputeVOXVENDOR has a reputation beyond reputeVOXVENDOR has a reputation beyond reputeVOXVENDOR has a reputation beyond reputeVOXVENDOR has a reputation beyond reputeVOXVENDOR has a reputation beyond reputeVOXVENDOR has a reputation beyond reputeVOXVENDOR has a reputation beyond reputeVOXVENDOR has a reputation beyond reputeVOXVENDOR has a reputation beyond reputeVOXVENDOR has a reputation beyond repute
Pull out all your manuals, That will point to the direction of routing possibilies.... Should be pretty detailed instructions and routing diagrams.....
http://i208.photobucket.com/albums/bb139/Voxvendor/heartagram-1.jpg
"Health nuts are going to feel stupid someday, lying in the hospital, dying of nothing."
