Old 08-28-2008
Nick The Man's Avatar
Nick The Man Nick The Man is offline
SOUND
Nick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond repute
OC 703 Above Drum Kit
Hello all, It sure has been a while. I'm in pursuit, hot pursuit of building/creating some absortion panels. And even after searchin' the board for all she's worth I couldn't find the answers to some of my questions. So I'll cut to the chase and see if any of you acoustic-heads could answer my amatuer questions.
1. What is better 2" thickness or 4" thickness?
2. Where is the best/cheapest place to buy the insulation? (I found six 2"x48"x24" sheets "on sale" at readyacoustics.com for $69.99. Is that good/enough?)
3. How high above the kit should I hang these?
I guess thats all for now, but I know I will think of more.
Thanks to everyone. Once I get started on this project I'll be posting pictures so sit tight!
Old 08-30-2008
foggie foggie is offline
Newbie
foggie has a reputation beyond reputefoggie has a reputation beyond reputefoggie has a reputation beyond reputefoggie has a reputation beyond reputefoggie has a reputation beyond reputefoggie has a reputation beyond reputefoggie has a reputation beyond reputefoggie has a reputation beyond reputefoggie has a reputation beyond reputefoggie has a reputation beyond reputefoggie has a reputation beyond repute
"1. What is better 2" thickness or 4" thickness?"
Typically the thicker the better as far as absorption goes. This also will depend on the sound of your overall room, space (height limitations) etc.. 2" maybe enough - that's fairly standard from what I have come across.
"2. Where is the best/cheapest place to buy the insulation? (I found six 2"x48"x24" sheets "on sale" at readyacoustics.com for $69.99. Is that good/enough?)"
That seems reasonable - I had two cases (12 sheets) shipped for $130'ish
"3. How high above the kit should I hang these?"
"Typically" it should be the thickness of the 703 from the ceiling. E.g. 2" 703 should be 2" from the ceiling, wall etc..
Old 08-30-2008
SOUND
Cool thanks for all the info. Yeah my room is garbage, ceilings are only about 9"
I was also reading alot more and noticed almost everyone frames thier foam. Is there any reason for this besides making it look nice, or could I just wrap the fiberglass in burlap and throw it above my drum kit?
Old 08-30-2008
Newbie
For a ceiling application you can certainly just rap the 703 in fabric and hang it from the ceiling (use fender washers and an eye bolt for example). I believe there are "hanging kits" available specifically for this via some of the acoustic companies.
Old 08-30-2008
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
Frames make it much easier to wrap the panel with fabric and hang it.
Old 08-30-2008
Obi-Wan zenabI's Avatar
Obi-Wan zenabI Obi-Wan zenabI is offline
Force of Nature
Obi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond repute
9'???? I have 7'1.5" in my studio!
I can't even hang my 2" 703 2" below the ceiling!
I do think that putting it right on the ceiling will be ok in this application since taking the upper frequencies out should be helpful in eliminating the sense of a low ceiling in the recording. But you have room to drop it down to further reduce the low mids rolling around your space.
I don't need no stinkin' sig.
Old 08-30-2008
CIRO's Avatar
CIRO CIRO is offline
Capitu´s brother
CIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond repute
A 9' ceiling is ok!
Mine is 8,5 , with 3 clouds, the thinner is 4" (above "instruments/vox",for recording)
Above mix position, 2 more, and thicker (6" and 10").
Clouds are great, cleaning the "stage" and improving peaks and nulls.
I use w/ frame (easier to fix on ceiling, IMO).
Ciro
Old 08-31-2008
SOUND
Well, I guess I was way off. I took a guess, but when I actually measured they are 7.5.
I guess I will be absorbing with the 2" foam, and making frames. It sounds like treating a room yeilds some good results if done correctly. I'm well pleased with all my gear/equipment so there really isn't much else to buy. This looks like a good investment. And not as costly as some folks make it out to be.
6 sheets foam: $80-90 shipped
lumber: $30
Burlap: unpriced (so far)
Thanks for all the input everybody!
Very inexpensive drum bits and pieces (Hi-hats, snare drum, kick drum heads vicenzajay Free Ads for Music / Recording Equipment 8 04-23-2008 15:45
Using a midi drum pad controller to step record drum tracks using Addictive Drums??? Maud Digital Recording & Computers 4 10-15-2007 11:35
Free Drum Kits To Trick Out Your Drum Machine Thread jugalo180 DJ & Hip Hop Production 11 11-28-2005 00:09
Midi newbie - how do I import drum midis on comp to drum machine? strat0tele MIDI Mania 1 07-25-2005 00:03
drum mics and phasing problems/checking drum phase. maskedman72 Microphones 0 12-13-2002 13:13
