Go Back   Home Recording > User Forums by Brand > Emagic / Logic Forum
Reply    Audiofanzine Apple emagic Apple emagic News Apple emagic Medias Apple emagic Tests Apple emagic Articles Apple emagic User Reviews Apple emagic Classifieds Ads
Old 08-28-2008
guitar zero's Avatar
guitar zero guitar zero is offline
What's On Tap?
guitar zero has a reputation beyond reputeguitar zero has a reputation beyond reputeguitar zero has a reputation beyond reputeguitar zero has a reputation beyond reputeguitar zero has a reputation beyond reputeguitar zero has a reputation beyond reputeguitar zero has a reputation beyond reputeguitar zero has a reputation beyond reputeguitar zero has a reputation beyond reputeguitar zero has a reputation beyond reputeguitar zero has a reputation beyond repute
Outboard compressors and Logic
Just bought a book on Logic so I could figure out how to take my tracks and run them through a de-esser, or compressor, or EQ etc. We want to record everything dry, then process later, but there's not a word in the entire book about how to do this. It only covers using plug ins, no external signal processors. Does anyone know of a good resource so I can figure this out? You can do this in Logic right? I'm trying to avoid the logic manual which is the size of a small phone book, and obviously written by some techy geek.
Old 08-29-2008
antichef's Avatar
antichef antichef is offline
unfocuser
antichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond repute
It's a plugin in the Utility folder called I/O, (at least I think that's it on my system). Works fine for me. Makes me wish I had some decent outboard gear
Old 08-29-2008
What's On Tap?
Thank you. I've only got two channel apogee I/O, but that should be enough if I do one channel at a time, right?
Old 08-29-2008
antichef's Avatar
unfocuser
one stereo channel? two mono? yes. Or is that one in and one out of the Apogee? I just saw your unfilled lunchbox in that thread above -- you're way ahead of me on outboard stuff
Old 08-30-2008
What's On Tap?
yeah, it's two channels in, two out. Thanks for your replies. I'm itching to do some mixing.
Old 08-30-2008
genesisariana's Avatar
genesisariana genesisariana is offline
Money is no object!
genesisariana has a reputation beyond reputegenesisariana has a reputation beyond reputegenesisariana has a reputation beyond reputegenesisariana has a reputation beyond reputegenesisariana has a reputation beyond reputegenesisariana has a reputation beyond reputegenesisariana has a reputation beyond reputegenesisariana has a reputation beyond reputegenesisariana has a reputation beyond reputegenesisariana has a reputation beyond reputegenesisariana has a reputation beyond repute
Inside the mixer in logic, you can use the buss to send out (rout through) your outboard stuff, and back in on an input to a different channel. Im not sure how you assign what comes out of the ensemble(what I assume you have). I saved presets for channels I always run out, with the output assigned and set to the right level going out of the correct output of my firepod.
Old 08-30-2008
What's On Tap?
It's actually a Rosetta 200, but same difference I imagine. Is assigning a buss to the outputs different than the I/O routing antichef was talking about, or a different way of saying the same thing?
Old 08-30-2008
antichef's Avatar
unfocuser
Assigning a buss to the outputs is different from what I was saying. The I/O plugin is worth trying, since I think it has latency correction and is pretty simple to access. Learning how to work with busses is very good to do, though, and will allow you to run several but not all tracks through an outboard device, which might be desirable. My method is either one track at a time, or on the output strip (which is probably all tracks, since they're routed that way by default)
Old 08-30-2008
What's On Tap?
Antichef, thanks for your replies. I think I've got it. My son moved to CA and took all my cables, so as soon as my new ones arrive, I'll try it out.
Old 09-01-2008
Money is no object!
I love the apogee stuff, I have a 800 on layaway. Cant wait to use it.
Old 09-01-2008
antichef's Avatar
unfocuser
Good luck GZ - I envy you! As genesisariana says, "Money is no object", but it's often the subject of my discussions with Mrs. Chef - so no Apogee in my near future
  #12
Old 09-04-2008
Money is no object!
Money is no object for me, because I ant got none!!!
  #13
Old 09-07-2008
What's On Tap?
I didn't have any money either, so I sold my fishing boat to buy more gear. It's tough when recording comes pitted against fishing. This year, fishing lost.
outboard compressors, good prices! otobianki74 Free Ads for Music / Recording Equipment 0 06-11-2008 08:40
Compressors: outboard vs. built-in osz The Rack 13 10-15-2005 05:33
How to use outboard gear with Logic adclark Recording Techniques 1 08-20-2005 01:55
Outboard Compressors VS Plugins ambi Other Equipment and Reviews 13 05-27-2002 15:02
Outboard Compressors VS Softwear Plugins/fx ambi Keyboards and Sound Modules 1 05-23-2002 10:21
