Reel Motor Bearing Puller
I was just looking at the total number of threads on this fourm. It seemed low and it is a cool forum so I thought I'd fortify with what offerings I have. Hopefully they can be useful.
I'm much more confortable with mechanical things...I've gotten a lot of help on this forum and over in the Analog Only forum getting comfortable with the electrical stuff, basic, and not so basic. ![]() ![]() Anyway, when I got my Tascam 58 a couple years ago the nose bearing on the supply reel motor was bad. I pulled the motor expecting it to be easy to pull the bearing, but the bearings are cemented onto the shaft, so I made a puller out of some spare hardware in the shop and the steering wheel puller for my Chevy Suburban (these are pretty cheap at a local chain auto parts store). I took a large thick washer, used a hacksaw to cut out a section of the "O" to make it a "C" shape, and then drilled and tapped two holes for the long cap screws that snug the washer up against the back side of the bearing. With a little pressure the bearing would pop off. Here is a picture of the puller: ![]() Here is the puller going to work on the bearing: ![]() I suggest that if you do this, when you resintall the new/replacement bearing that you apply some loctite to the shaft and bearing hub. I believe the cement originally applied reduces noise. |
| Pearl export series bearing edge | chestwick91 | Drums and Percussion | 3 | 04-25-2007 11:17 |
| price check Akai 4000DS MKII Reel to Reel tape recorder | daav | Free Ads for Music / Recording Equipment | 1 | 07-17-2006 17:35 |
| Anyone use wax on the bearing edge? | timboZ | Drums and Percussion | 1 | 07-14-2005 20:33 |
| 388 Capstan/Reel motor question | carquinez | TASCAM User Forum | 1 | 12-20-2004 23:26 |
| Bearing Edges | ebeam | Drums and Percussion | 1 | 12-12-2002 14:20 |
