just ordered two stacks of owens 705 - seeking advice
I just bought twelve panels of Owens Corning 705 rigid fiberglass. (2' x 4' x 2") I have a rehearsal room that is also used occasionally for recording. The room dimensions are approximately...x: 10' y: 15' z: 9'. My plan is to cut right-triangles and stack them in the three available corners of the room. (Each wedge would be 5.3' tall and 2' wide.) If I were to cut the triangles smaller (1.4' wide), I could stack them all the way to the ceiling.
As you might know, this stuff is a little expensive, so before I go cutting, I'd be very grateful to hear anyone's suggestions as to how I should configure this material. Thanks a lot. |
I personally would just keep the 2x4 panels in-tact,cover them and stradle them across the corners. You could then go floor almost to ceiling with 2 panels stacked on top of each other (8ft high). You would use 8 panels for the 4 corners and then you could hang the other 4 panels on the walls. When you can afford more, just double up in the corners for 4 inches of thickness.
Don't know your room layout though, I'm sure the triangles would work too. Now let's here from the experts.... |
I did it,but after changing for 2'x4'x 4" with air gap the (measured) absorption was improved. It confirms what I use to read about ... seems 2' wide is the "minimun" way to go. Ciro |
re:
thought I'd post my room setup...
Does anyone know why 705-FRK is rated much more absorptive than plain 705 ?
(attached owens corning absorption coefficients) Will they compare more similarly in bass frequencies (below 125hz)? I have the plain 705, and I'm wondering if I should have gotten the 705-FRK. These will be used for bass traps. Last edited by question444; 08-27-2008 at 05:51.. |
nevermind my last post - not sure how to delete it.
| New Here and Seeking Advice | Nilman13 | Recording Techniques | 19 | 07-13-2006 13:41 |
| Seeking advice on connections: | Creamyapples1 | Mixing / Mastering | 5 | 01-18-2006 11:34 |
| Seeking Advice | SergeD | Cakewalk / Sonar Forum | 10 | 06-07-2004 17:10 |
| Seeking Mr. Sayers advice. | RICK FITZPATRICK | Studio Building & Display | 18 | 09-16-2002 10:36 |
| Seeking advice on what gear to get next? | SWG | Roland, Boss, VS Series Forum | 0 | 04-12-2000 14:17 |
