Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 08-22-2008
ESPplayer7 ESPplayer7 is offline
Senior Member
ESPplayer7 is an unknown quantity at this point
which of these two monitors would be better
I am looking at two different monitors that i will be using to master music in reason to a cd. Which of the two would be better? I notice one has a sub in it, would this be bad for mastering because it will be adding more bass?
these two
http://www.m-audio.com/products/en_u...Pro3-main.html
http://www.m-audio.com/products/en_u...AV30-main.html
Old 08-22-2008
CIRO's Avatar
CIRO CIRO is offline
Capitu´s brother
CIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond repute
Both are 3"woofer monitors (I see no sub) - response 100hz-20khz (+/-3 db).
There´s a lot of information below 100 hz, if you need mix/master something , with 3" you´ll need headphones to "take a look" (all the time) on sub/bass frequencies.
5",at least, or 6" (better) and a treated room (a good amount of bass traps, take a "search")and you are in a much better shape.
Sansom Rubicon 5A is just a bit more expensive (but cheaper than the M audio 5",at least in Brazil).An excellent value for the price,and you´ll hear the lows...
Ciro
www.soundclick.com/ciromoreau
Old 08-23-2008
SonicAlbert's Avatar
SonicAlbert SonicAlbert is offline
Super-Sonic "Herb" Albert
SonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond repute
I wouldn't go with either of those to mix an album or to master it. The speakers are too small, you'll not have an accurate picture of what the music really sounds like on other playback systems.
Roughly speaking, a monitor with speakers smaller than 6" should be used with a sub. Otherwise, you'll probably go much to heavy on the lower frequencies when you mix.
http://www.misterpotts.com
Flat panel LCD monitors VS. CRT monitors for optimum recording... Obstacle1 Digital Recording & Computers 27 08-26-2006 23:19
Large monitors vs. small monitors w/ sub Kasey Mixing / Mastering 6 07-28-2005 11:55
Monitors Compared to Computer Monitors thehouseofshawn Newbies 1 12-12-2004 22:30
WTB: 100 watts or so Guitar Amp, power amp,floor monitors and powered studio monitors sjaguar13 Free Ads for Music / Recording Equipment 1 06-12-2004 14:26
Is it generally cheaper to get powered monitors or passive monitors plus a power amp? videodrone Other Equipment and Reviews 8 04-19-2003 13:05
