Old 08-20-2008
Superhuman Superhuman is offline
Shagaholic
Superhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond repute
Finishing touches to homestudio
Hi All,
Posted here a while back when I was just starting work on an attic studio. Anyway, it's built now and is ready for final fitting out before the desk and gear is brought in.
THe room measures roughly 4m x 5m and allowing for where the stud walls start (away from the eaves area) the vertical walls height is 1.3m which then goes to a pitched ceiling with a centre height 3m at the apex. To reduce relections and add some additional soundproofing I am having a thick carpet with specialist underlay fitted to the floor but I was also toying with the idea of carpeting the walls up to the 1.3m mark (where the roof starts to pitch upwards). The carpets are being professionally fitted so now would be the ideal opportunity to get the walls done properly IF that is a good idea....
Should I carpet the walls? I also have some bass traps and about 40 spikey accoustic foam tiles for treating the sloping ceiling areas - I'll post another thread with photos looking for advice on placing the accoustic tiles when I get to that stage. Carpet or no carpet??
Some 7 string shred...
Finishing Touches on Vocal Booth... elove Studio Building & Display 1 07-06-2005 08:20
Need help with finishing touches on my tracks mattkw80 Cool Edit Pro / Adobe Audition Forum 8 02-27-2004 18:01
Adding finishing touches (reverb etc.) Red_House Recording Techniques 3 02-22-2004 14:07
EQ finishing touches kdgospel Mixing / Mastering 16 11-17-2003 14:39
Your favorite Compressing/limiting tips/tricks for finishing touches on the final mix David B Mixing / Mastering 9 04-09-2002 08:16
