Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 08-18-2008
Nitemare2970's Avatar
Nitemare2970 Nitemare2970 is offline
Newbie
Nitemare2970 has a reputation beyond reputeNitemare2970 has a reputation beyond reputeNitemare2970 has a reputation beyond reputeNitemare2970 has a reputation beyond reputeNitemare2970 has a reputation beyond reputeNitemare2970 has a reputation beyond reputeNitemare2970 has a reputation beyond reputeNitemare2970 has a reputation beyond reputeNitemare2970 has a reputation beyond reputeNitemare2970 has a reputation beyond reputeNitemare2970 has a reputation beyond repute
Red face mixing technique help
got a couple of questions for some experienced sound engineers... or not experienced.
1. How do i get my bass drum to cut through the mix more- ive already cut all freqs below 75 on all the other instruments. Help??
2. When u record guitars, do u pan 1 all to the left and one to right or just slightly to left and right?
Old 08-18-2008
avieth avieth is offline
Dedicated Member
avieth has a reputation beyond reputeavieth has a reputation beyond reputeavieth has a reputation beyond reputeavieth has a reputation beyond reputeavieth has a reputation beyond reputeavieth has a reputation beyond reputeavieth has a reputation beyond reputeavieth has a reputation beyond reputeavieth has a reputation beyond reputeavieth has a reputation beyond reputeavieth has a reputation beyond repute
To get the bass drum to cut through, you'll want to free up some room around 80-150Hz for it.
As for the guitars, there is no proper way of doing it. If you have two guitar tracks you should do what is necessary to achieve the sound you want.
Old 08-18-2008
NL5's Avatar
NL5 NL5 is offline
Unpossible!
NL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond repute
The only way to give you accurate advice is if you were to post an mp3 in the mix clinic.....
They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. -B.F.
Old 08-19-2008
benage benage is offline
Junior Member
benage has a reputation beyond reputebenage has a reputation beyond reputebenage has a reputation beyond reputebenage has a reputation beyond reputebenage has a reputation beyond reputebenage has a reputation beyond reputebenage has a reputation beyond reputebenage has a reputation beyond reputebenage has a reputation beyond reputebenage has a reputation beyond reputebenage has a reputation beyond repute
If you are making a track with a quieter kick drum i.e. rock, I have found it sounds nice to let the bass guitar fill the very low frequencies 50-150hz and give the kick drum a 5-10db boost around 200hz. I also cut the same frequency 5db out of the bass guitar to make room for it. Increasing the beater click around 3khz can also increase the clarity of the kick. hope this helps
Old 08-19-2008
MCI2424's Avatar
MCI2424 MCI2424 is offline
1K Silver Member
MCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond repute
1. Whenever mixing, you must have either the bass or the kick "on point". Both cannot have the same sonic space. Cutting the 75Hz on all instruments just means you cut 75Hz from all instruments. You have to move the kick into anothe space. Pull up the bass and the kick and mix them alone eq'ing until they are both clear and sit in the mix. You may need compession on either or both to get a consitant volume through the whole song. Bring up one track at a time after this and find out if it sits well. Really, too much eq'ing means your tracks were recorded in a bad room or bad quality sources.
2. Depends on what you want. You can pan anywhere you want, but usually I find the best place is right in the middle (for a single guitar) and 9 - 3 for two guitars. If two guitars are hard panned, they have to be right on the money timing wise or you get drop outs that stand out.
"Tascam, Fostex or Studers don't make hit records...........people do"
MCI2424 - 2007
Old 08-19-2008
Newbie
thanks
thanks guys that helped a lot!!
Okay, here is a drum track that was recorded recently
http://www.megaupload.com/?d=TTCDBRPB
Any suggestions, im striving for a metal sound by the way. I would record and post some bass and guitar but my bands bass player is in California at the moment and im in N.C., kind of a small problem.
Does the bass drum fit right in that mix??
oh btw, i dont think that the guitar source is the problem, they are recorded in isolation booths with a SM57 and they are low cutted. (but they could be the problem, im not an expert)
Old 08-19-2008
jaybriggs84 jaybriggs84 is offline
Dedicated Member
jaybriggs84 has a reputation beyond reputejaybriggs84 has a reputation beyond reputejaybriggs84 has a reputation beyond reputejaybriggs84 has a reputation beyond reputejaybriggs84 has a reputation beyond reputejaybriggs84 has a reputation beyond reputejaybriggs84 has a reputation beyond reputejaybriggs84 has a reputation beyond reputejaybriggs84 has a reputation beyond reputejaybriggs84 has a reputation beyond reputejaybriggs84 has a reputation beyond repute
Typical EQ for a kick drum would be boost the bottom end(50-80hz), cut a lot around 800hz, you may have to cut up 12db or more depending on the drum and where the mic was placed, and boost some around 4k to get some sharpness from it. That should help. If you're compressing then use a slow attack and fast release. Cut some bass guitar where you boosted your kick.
I tend to avoid hard panning guitars for most things I do, but there's no rule for it or against it. Since you say you're doing metal music, then hard panning is pretty common.
Old 08-19-2008
Seafroggys Seafroggys is offline
Force of Nature
Seafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond repute
You know I do the opposite.
My bass drum's fundamental is 42 hz. I put a hi-pass at 55 hz, and a cut at 188 hz. This actually makes it cut more, since you remove the low end mud and knocking out at around the 200 area gets rid of mid ranged mud.
Plus notching out the 188 area frees up room for the bass guitar to cut through, since that's usually where the first harmonics run around in, which tend to be the strongest frequencies for the bass guitar.
Old 08-19-2008
Rokket's Avatar
Rokket Rokket is offline
Sgt Floyd Pepper
Rokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond repute
Just because you get the drums to sound good alone, doesn't necessarily mean they will sit right in a mix with other instruments and vocals. They need to be mixed for the song with all the components of the song.
The hardest part of being a bartender is figuring out who is drunk, and who is just plain stupid.
Old 08-20-2008
ChrisBass's Avatar
ChrisBass ChrisBass is offline
Registered User
ChrisBass is on a distinguished road
You could also try using a compressor's sidechain to cut your bass guitar when the bass drum hits. This will make your bass drum stand out cleanly without having to sacrifice as much harmonic loss from cutting the eq.
Mixing Grid Technique! darkecho MP3 Mixing Clinic 4 09-09-2006 11:44
i think the got the mixing technique for punkrock - NEW LINK jerberson12 MP3 Mixing Clinic 6 05-26-2005 12:49
secret mixing technique of thee nubs sweetnubs Recording Techniques 9 03-02-2003 02:48
two hi hat mic technique? jamiecer Microphones 24 02-21-2003 12:17
Technique, Baby, Technique! GONZO-X Guitars and Basses 27 06-08-2002 12:53
