Go Back   Home Recording > Special Forums > DIY, Mods, and Homebrew
Old 08-16-2008
ashley_B_Soton ashley_B_Soton is offline
Newbie
ashley_B_Soton is on a distinguished road
What Kind of speaker would i use to build a cab??
I am thinking about buiding a guitar and bass Cab for the studio I am building. The problem is, what kind of speaker would i use for each?
I have seen threads on here about buiding cabs and mostly they talk about materials and techniques, i just want to know where i would get them in the UK or online? And what i should be looking for with regards to the speaker.
Old 08-17-2008
Dr ZEE's Avatar
Dr ZEE Dr ZEE is offline
Anti-Pro Circles Insider
Dr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond repute
Keep the order straight.
First, choose the amp(s) for studio you are building.
Next choose the speaker(s) for the amp(s) you've chosen.
Next build the cab(s) for the speakers.
Next put the speaker(s) into the cab(s) you've built and then - cab(s) into the studio you are building
When choosing the "right" speaker (or speakers) for an amp the impedance of the speaker (or combination of speakers) and power handling are things to watch with care.
There are bunch of other aspects, which are not critical from technical point and are preferential from any other point you can think of.
Dr ZEE
MZE | ZDL | DZW
Old 08-17-2008
drstawl's Avatar
drstawl drstawl is offline
5K Californium Member
drstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond repute
I'm a fan of the instrument 12" drivers from JBL and Altec-Lansing.
Great drivers for cabs as they will, en masse, handle some serious power without blowing up, but provide astonishing efficiency on a watt/SPL basis.
Old 08-17-2008
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
+1
It really all depends on what type of sound you are going for. Celestions are a popular choice for guitar, if you are doing the distorted marshall or mesa thing. If you are doing a more fenderish sort of thing, JBLs are a popular choice.
As with most things in audio, it depends on the context.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 08-17-2008
Newbie
The amps will Probably be a laney RB9 and a marshall JCM 2000 but i would preferably like to keep it flexible and not sound too bad on other amps as i already have a slew of requests to use the studio when its ready.
I was wondering not only what make but what model of speaker, just to give me an idea, but i will research a little myself.
Old 08-17-2008
Farview's Avatar
For Laney and Marshall the common choice would be Celestion vintage 30's.
It would probably be easier to just get an older used cabinet. It would cost less than the materials to make a good cabinet and you could have it tomorrow.
Jay Walsh
Old 08-18-2008
antichef's Avatar
antichef antichef is offline
unfocuser
antichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond repute
Whenever I order speakers, I usually get them from Weber:
https://taweber.powweb.com/weber/ There are descriptions there about which ones do what, if you look around.
Note that lower wattage handling capacity speakers break up sooner than higher capacity ones, and that when they break up, they stop getting louder at the same rate -- the end result is that a high wattage speaker will go louder than a low wattage one when it's pushed. A lot of people like the breakup sound, of course, and you don't need (or even want) loud-loud-loud in the studio, but you also can't ignore the possibility of blowing a speaker by pushing it too hard.
I've always wanted to build a cabinet, but what Farview says is right about getting a used one. I've picked up a couple of used ones and replaced the speakers.
I searched the web for someone who builds cabinets and didn't find much - the ones I found were pretty expensive and shipping is also quite expensive. (Weber has cabinets, for example, but I never want to spend that much). I asked a local speaker guy about this, and he said there just wasn't any money in doing it, because of 1) the cost of materials, 2) the cost of shipping, and 3) the availability of used ones, which aren't going to be much worse than something you could build -- undoubtedly someone with skills can build a better cabinet than what's generally available, but the difference in quality wouldn't likely justify the expense/trouble. That said, I'm sure the Weber cabinets are awesome
Old 08-18-2008
Farview's Avatar
It's been my experience that it's pretty easy to find a loaded 4X12 cabinet for right around the cost of the speakers. So buying a bunch of 3/4 birch plywood and spending a weekend measuring, sawing, sanding, etc... is silly from a monetary point of view. Assuming your weekend is worth more than $50 to you.
Of course, if you really enjoy woodworking and you are just looking for a project to take on, that's a different story.
Jay Walsh
Old 08-18-2008
Newbie
Thanks, i will look into how much it'll cost each way.
Though looking at the 15" speakers on the weber site, i am tempted to use them. But it may be a cost too far, and i have no idea how it will adversly or beneficially effect the sound.
Old 08-19-2008
Farview's Avatar
No one really uses 15 inch speakers for guitar. A Bass cabinet, sure, but not guitar.
Jay Walsh
Old 08-19-2008
Newbie
Exactly the reason why i'm tempted, however i was going to build a bass cab anyway.
How to build a kick mic out of a 10" speaker? visa Microphones 10 10-10-2007 01:23
What kind of desk would you build? (pics included) RideTheCrash Studio Building & Display 4 11-06-2005 21:38
What kind of damage from 2 amps in one speaker? Yasoo The Rack 5 10-13-2004 21:18
1 speaker? 2 speaker recording/outpu? Taylor_214 The Rack 3 05-30-2004 21:41
