Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 08-15-2008
midwesttribune midwesttribune is offline
Junior Member
midwesttribune has a reputation beyond reputemidwesttribune has a reputation beyond reputemidwesttribune has a reputation beyond reputemidwesttribune has a reputation beyond reputemidwesttribune has a reputation beyond reputemidwesttribune has a reputation beyond reputemidwesttribune has a reputation beyond reputemidwesttribune has a reputation beyond reputemidwesttribune has a reputation beyond reputemidwesttribune has a reputation beyond reputemidwesttribune has a reputation beyond repute
editing prog.= I USE PROTOOLS LE 6.7 mbox
a yawl im currently workin ona rap project an I record down the basic vocal on a mono track and use a compressor so when I get too loud it brings me down and so-forth, also I make mulitple track adlibs an such for the end of lines, for effect. But the majority of the time it just sounds like im recordin over a beat an not in the mix well, and that my voice appears to plain as far as no added effects, tweaks ect. Although in the editing process other people do with protools there are a few basic plugins that are typical for vocal editing succsess. Can anyone involved in anytype of vocal editing (singer, rapper, any) gimme some techniques/tricks/ect. an if you mention a plugin describe what you do and adjust within the plugin an what it does, thanks alot.
Old 08-15-2008
kubeek's Avatar
kubeek kubeek is offline
Dedicated Member
kubeek has a reputation beyond reputekubeek has a reputation beyond reputekubeek has a reputation beyond reputekubeek has a reputation beyond reputekubeek has a reputation beyond reputekubeek has a reputation beyond reputekubeek has a reputation beyond reputekubeek has a reputation beyond reputekubeek has a reputation beyond reputekubeek has a reputation beyond reputekubeek has a reputation beyond repute
I just use compressor, eq and a bit of reverb usually.
Post some tracks?
Originally Posted by walters View Post
i'm not getting that Polish mastering sound why is that?
Old 08-15-2008
Junior Member
like explain in detail what levels you tweak with the eq and reverb? b.c im aware those are there but dont know how to use them, what the really end up doin ect. thanks
Old 08-15-2008
SouthSIDE Glen's Avatar
SouthSIDE Glen SouthSIDE Glen is offline
independentrecording.net
SouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond repute
A yawl.
G.
Glen J. Stephan,
SouthSIDE Multimedia Productions
RECORDING RESOURCES AND INFO SITE:
Old 08-16-2008
coolsoundman coolsoundman is offline
Senior Member
coolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond repute
midwest,
I think you should eq the vocal. Adjust your hi's, mid's, low's to a point that it sounds more of a natural sound and a little crisp. I would then put a reverb or a delay. On those effects, watch for your global slider or the wet mix slider. move those around or better, mess with the effects plugin to see what you may like. But one thing, just add a little, not a whole lot, cause it will start to sound cheap or fake. hope that works.
Old 08-21-2008
danico4not's Avatar
danico4not danico4not is offline
audiospy
danico4not has a reputation beyond reputedanico4not has a reputation beyond reputedanico4not has a reputation beyond reputedanico4not has a reputation beyond reputedanico4not has a reputation beyond reputedanico4not has a reputation beyond reputedanico4not has a reputation beyond reputedanico4not has a reputation beyond reputedanico4not has a reputation beyond reputedanico4not has a reputation beyond reputedanico4not has a reputation beyond repute
I'll use the cutting tool to separate my mono wav file into several little files. I'll adjust the volumes of each individually, and add a compressor on. I'll play around with the ratio and threshold to get a good sound. sometimes I'll add reverb if necessary to soften the sound and help it lay in the mix. sometimes for effect, a little delay or something can't hurt..
one,
LP
www.lostpoet.com
www.myspace.com/losianthelostpoet
www.myspace.com/lostpoetstudios
www.youtube.com/danico4not
"i've travelled the world to learn I must return..."
-Matt Monro To Russia with Love
Vocal Editing-basics NEED HELP! midwesttribune Pro Tools Forum 4 08-24-2008 11:11
Vocal Editing and other stuff TAK4! Newbies 3 08-11-2007 19:12
Cubase LE vocal editing JWS's Blue Room Cubase User Forum 3 07-10-2006 18:05
Help: Basics in Vocal Editing, Processing and Such? on point 305 Digital Recording & Computers 2 08-24-2004 23:06
Vocal Editing process Thirst Mixing / Mastering 23 10-24-2003 16:34
