hum in my HS80'S
i recently purchased the yamaha hs80's and i'm getting used to them, when i've noticed that after several minutes use, i'm getting an oscillating hum (low, like a grounding issue hum) from the right side. i can turn the monitor off, and back on and it disappears; however after a few moments it's back. it also seems to distort the output from that side considerably as well as the cut the volume in more than half. i'm running them into a mackie 16 track mixer (used primarily for output only), but i do have another set of unpowered monitors being used by a power amp into a separate pair of main outs from the mixer. the hs80's are using balanced cables via the xlr main outs. i've moved the AC from one power strip to another with no results; the power strips are your average home depot types. i want to trouble shoot by unplugging the amp from the mixer, but since the amp isn't providing anything to the speakers, and this seems like an AC issue, i'm just shooting in the dark.
are there any suggestions to this annoying issue? |
Are they still under warranty?
There are 10 types of people...those who understand binary and those who don't My humble home studio! My Choons My DIY Broadband absorbers thread! Mbox2, MacMini (Intel), Mackie HR624, Focusrite Liquid Mix, Frontier Design AlphaTrack |
disconnect the other amp and speakers... swap the cables to the yamamas... first at the speaker end... and then at the mixer end...
1. if the noise stays with the speaker in the first test then it is the problem... 2. if the noise moves in the first test then do the second test... 3. if the noise moves in this test then the mixer is the problem... 4 if the noise stays with the speaker then the cable is the problem... that being said... what you most likely have is one of the amps in the yamamas has a problem thats heat related... a transistor ready to blow??? as it takes some time to show and kinda resets when you unplugged it...
37.8% of all statistics are made up on the spot... hey give a guy some room... people are trying to evolve here... for crying out loud... |
