Apogee Rosetta 200 problem?
Just hooked up the rosetta via SPDIF through presonus firewire (had to since firewire is only option with my iMac). Play back levels are REALLY hot, and record levels are REALLY weak. Tried to record some acoustic guitar through Studio Projects C3 pair and had to peg the juggernauts with boost on just to get the meters to move in my DAW. Anything simple I should be thinking about? Thanks.
I'd run tone through the system and find out where the problem is. That's really all you can do at this point.
+4/-10 settings for inputs and outputs respectively maybe?
SPACE AVAILABLE FOR RENT |
Cant you use the Firewire?
Make sure the levels are set correctly in the Presonus control panel application for their interface.
http://www.misterpotts.com |
check that...
"...if the opposite of pro is a con lets go beyond this, the opposite of CONgress must be PROgress..." Cage |
Thanks for the replies. In response, I can't use the firewire because apogee rosetta doesn't come with firewire, it's a $350 add on card. So I have to go spdif into the firewire unit I have, then into the computer.
I did find out the unit has an auto callibration that sets back to factory reset of -12. I'll try that. I'll check for the +4/-10, I don't remember seeing anything like that. And yes I did change the levels in the presonus mixer, but I have to peg the levels while recording, and they have to be turned wayyyyyyyyyy down during playback. I'll keep working on it. Thanks again for the help. |
The default line level is -12dBFS?!?
What is this, 1992? |
No loudness wars at apogee.
Although I guess you certainly don't have to worry about overdriving your front end...
But geez... I keep my tracking converters at -20dBFS (because that's as low as I can get them). Then I *still* keep the front end cool. But I remember when converters were at -12... That was a gain-staging nightmare that I wouldn't want to go through again. So "anti-normal." But then again, "normal" seems to have taken a back seat to "record really hot without clipping" over the last bunch of years... |
Yeah, the frustrating thing is when I calibrate this unit, it doesn't have any indicator to tell you what your level is. It's all by ear. The playback I had to turn as low as it would go, and it's still hot.
| FS: Apogee Rosetta 800 x2 | otobianki74 | Free Ads for Music / Recording Equipment | 2 | 09-04-2008 19:05 |
| looking for an Apogee Rosetta 800 96k | earworm | Free Ads for Music / Recording Equipment | 0 | 09-03-2006 06:57 |
| Apogee Rosetta 800 - New in box | 6gun | Free Ads for Music / Recording Equipment | 0 | 07-16-2006 16:14 |
| RME ADI-8 PRO vs. Apogee ROSETTA | Gabriel Sousa | The Rack | 5 | 02-19-2006 15:12 |
| Apogee Rosetta 800 | fluxburn | Digital Recording & Computers | 0 | 09-30-2003 11:10 |
