Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 08-10-2008
Joni0001984 Joni0001984 is offline
Registered User
Joni0001984 is on a distinguished road
Alesis Control Pad & Sysex Dump: 2 pads at once => a no go!
Problem: My second Alesis Controlpad also skips every other drum stroke when hitting two drums at once.
Solution: The solution to that is to alter the the midi length. I've tried changing legato to 15 ticks in Cubase 4 - file - preferences - midi and it got a little better, but not perfect.
I've heard you should use some kind of midi converter, maybe a sysex editor, and change the length of every midi note. The notes it sends is unstable and unevenly strong. By lengthening the notes maybe my BFD 2.0 will hear it better. I have tried several other programs with similar results.
Method: Now I need to know how to test this Sysex theory. But what software works? Midi-ox did not recieve any data, even though I set it to 2048 as Alesis recommends. Alesis did not recommend Midi-ox for the Control Pad anyway.
References: Check out Phillips response and my own of course by googling: "Axeman's Alesis Control Pad"
Cheers, Joni
Old 08-11-2008
altitude909's Avatar
altitude909 altitude909 is offline
Best Advice Ever: RTFM
altitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond repute
play around with the cubase input transformer, it will do what you describe
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual
SysEx Dump Help SPCONN3 Alesis Forum 0 10-27-2003 08:28
QS7 - Sysex messages to control Controllers A-D sunrad Alesis Forum 5 01-08-2003 13:09
Sound module woes... please help me (bank changes, midi dump, sysex, ect...) LANSTARR Keyboards and Sound Modules 4 11-20-2001 15:04
Control a 02R with Cubase/Logic via sysex Stocky Sound Cubase User Forum 0 04-03-2001 07:59
Dump Request Macros for Sysex rjt Cakewalk / Sonar Forum 1 06-19-2000 11:06
