Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 08-09-2008
Orchestrator1 Orchestrator1 is offline
Newbie
Orchestrator1 is on a distinguished road
Panning Stereo.
What is the correct way to pan stereo.
I use Cubase SX as my editor so I have both sides of the stereo signal to pan.
If I pan them both hard right or left I would loose the stereo effect between the two mics. I have converted a stereo track to a mono track and the mono track appears to retain the stereo effect so is this the correct way to do it.
Rex.
Old 08-09-2008
leddy leddy is offline
Force of Nature
leddy has a reputation beyond reputeleddy has a reputation beyond reputeleddy has a reputation beyond reputeleddy has a reputation beyond reputeleddy has a reputation beyond reputeleddy has a reputation beyond reputeleddy has a reputation beyond reputeleddy has a reputation beyond reputeleddy has a reputation beyond reputeleddy has a reputation beyond reputeleddy has a reputation beyond repute
You truly have a dizzying intellect.
It is not really possible for a mono track to retain "stereo effect". Stereo is two separate tracks. Your DAW may combine them onto one (stereo) track, but they are separate. You may pan tracks anyway you like and still be "stereo", as long as the left and right are not identical - that would be mono. What constitutes accurate, pleasing, tasteful, balanced, etc. stereo is up to you.
What have you recorded, and how did you do it? Are you trying to capture an accurate stereo image of something (like a piano or guitar) or are you building a stereo image by panning a bunch of overdubbed parts?
Old 08-09-2008
aitikin aitikin is offline
Newbie
aitikin has a reputation beyond reputeaitikin has a reputation beyond reputeaitikin has a reputation beyond reputeaitikin has a reputation beyond reputeaitikin has a reputation beyond reputeaitikin has a reputation beyond reputeaitikin has a reputation beyond reputeaitikin has a reputation beyond reputeaitikin has a reputation beyond reputeaitikin has a reputation beyond reputeaitikin has a reputation beyond repute
Pan it left and right? Is that what you're looking for? I'm not entirely sure what you're asking about.
Old 08-09-2008
rayc's Avatar
rayc rayc is offline
L'ancien escargot
rayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond repute
Don't pan stereo. Stereo's cool. I like mono but I wouldn't pan stereo.
Cheers
rayC
soundclick, unearthed, mspace & utub
Old 08-10-2008
Newbie
I have recorded a musette accordion in stereo, if I record it in mono it sounds crap and has no life.
I have duplicated this stereo track to fatten it and panned one track hard left and the other hard right to avoid conlict. If you mute the left track all together and as the right track is panned hard right you only hear one side of the stereo signal comming out of the right monitor, the left monitor has no signal at all which is fine and understanable but to me there is no stereo effect comming out of the right monitor now. True or false.
Old 08-10-2008
mattr's Avatar
mattr mattr is offline
Resident stroppy teenager
mattr has a reputation beyond reputemattr has a reputation beyond reputemattr has a reputation beyond reputemattr has a reputation beyond reputemattr has a reputation beyond reputemattr has a reputation beyond reputemattr has a reputation beyond reputemattr has a reputation beyond reputemattr has a reputation beyond reputemattr has a reputation beyond reputemattr has a reputation beyond repute
EDIT: ok, I just reread that post and interpreted it differently this time. I'm confused.
Yes or no, have you recorded it in stereo (using two mics)?
Old 08-10-2008
Newbie
Yep, two Rode K2 Valve mics.
Old 08-10-2008
gecko zzed's Avatar
gecko zzed gecko zzed is offline
audio illusion
gecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond repute
Rex.
If you record a source using a pair of mikes into stereo track, that source's position in the stereo landscape will be determined by its position relative to the two mikes, and the input levels of the two mikes. This position may need adjustment if you are mixing down and it interferes with something else (or something else interferes with it). On the other hand, on playback, you may discover that recording levels or positioning of the mikes wasn't ideal, and you need to adjust this position.
You adjust the position using a single pan control if you have recorded a single stereo track, or by adjusting two pan controls if you have recorded the stereo on two separate tracks (which, I would argue, is not really stereo, but two mono tracks).
If your intention is to pan a source hard left or hard right, then you are quite right; any stereo image you have recorded will be negated by doing this. In this case, there is no point in recording it in stereo. You might as well save yourself time and trouble by recording in mono, and using the pan to place this mono track anywhere you like on the stereo landscape.
Recording in stereo is worthwhile when you have a source that already occupies a large area (e.g. drums, choral ensemble, grand piano, room ambience), as opposed to sources that could easily be regarded as coming from a single point (e.g. a vocal track).
Old 08-10-2008
mixsit mixsit is offline
Been Here, Posted That
mixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond repute
Originally Posted by gecko zzed View Post
...If your intention is to pan a source hard left or hard right, then you are quite right; any stereo image you have recorded will be negated by doing this. In this case, there is no point in recording it in stereo. You might as well save yourself time and trouble by recording in mono, and using the pan to place this mono track anywhere you like on the stereo landscape..
To add.. in most apps as you hard pan a stereo track it is turning one side down, not mixing it towards the side and panning it over. If 'duplicated the track' means 'copied then panned' you'd have the same as the one panned center -left got left info, right gets right. If it's double tracked stereo you still get a L mono and R mono of each version.
Split stereo tracks (or record) to dual mono for complete control -level, pan position and width.
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini
(formerly S.P. Technology
Old 08-10-2008
Elton Bear Elton Bear is offline
Unregistered Abuser
Elton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond repute
Thank god somebody pointed that out, I was almost losing faith in the good people of the board! Nice thread.
Kicking it lo-fi:
POS computer
Cubase SX2
M-Audio Delta 1010LT
ART Studio V3 Tube MP
Behringer Eurorack Desk
AKG C3000B
Shure SM58
Shure SM57
Sennheiser e818 S II
Ashton DMP-100 drum mics
Old 08-10-2008
Newbie
Hi geco zzed & mixsit.
Your bloody genius's, at last someone understands where i'm comming from, not so much in this forum but in another.
OK, what I did was convert the stereo track to mono, the mono track retained the quality of recording the instrument in stereo which is very important, but now it is mono, if we pan it hard right and duplicate it and pan that track hard left we have stereo again.
Now having said that, when you convert a stereo instrument track down to mono there is an audible conflict. So my latest theory is to duplicate the normal stereo track, pan one hard right and the other hard left, you loose one side of the signal from each track but it is stereo and there is no conflict.
Hope i'm right on this.
Rex.
  #12
Old 08-10-2008
gecko zzed's Avatar
audio illusion
Rex.
Converting a stereo track to mono will preserve soom of the room ambience associated with the original stereo track. The 'audible conflict' you refer to is most likely to do with phase issues arising from mike positioning. These may not be audible in the stereo, but become evident once you convert to mono.
If you duplicate the track, pan the original hard left and the new one hard right, you don't restore your original stereo field. Instead you get a mono signal in the centre of the field. However, were you to delay one track a slight amount, you would get an apparent stereo effect.
If you pan a stereo track hard left, duplicate it and pan the duplicate hard right, you get the same effect as if you were to have your single stereo track panned centre. So you don't gain anything. But, again, you might get an interesting sense of space if you delay one a fraction.
I'm not sure what your intention is, but you might be better off simply recording two versions of the same thing, and panning one hard left and the other hard right.
  #13
Old 08-10-2008
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
Umm, no. If you actually converted the stereo track to mono, there is no way to make it stereo again. You have combined the left and right channels, you can't get them apart. It's like trying to turn a cake back into four, eggs, milk sugar, etc... Once it's mixed, you can't do it.
Rex.
OK, mono is when you have one signal. If you have one signal coming out of both speakers, it's still mono. Stereo is when there is a difference between the signals going to the left speaker and the right speaker.
You are really trying very hard to outsmart yourself, none of this is as difficult as you have made it.
here are some questions:
1. If you have it recorded in stereo (one mic on the left and one mic on the right), why are you mixing it to mono?
2. If you want to listen to it in stereo, why don't you listen to what you already have recorded?
3. Are you sure you are starting out in stereo? Just because you recorded to a stereo file, doesn't mean you recorded in stereo. There are a number of ways you can buss two mics together to make a mono signal and then record it to a stereo file format.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
  #14
Old 08-10-2008
Unregistered Abuser
Rex.
Apologies if my last post was a little over-sarcastic, having read this post I understand a little better what you're getting at, but as Farview says I still don't get your intentions.
If you want a stereo sound from a stereo recording (that is, two mics on separate channels), pan one left and one right, as wide as you want for the sound you're seeking.
If you want the instrument to be panned, pan both to the same place.
If you have two of the same recording (which would be a mono recording on a stereo track), you ain't gonna be getting stereo separation, whatever you do. If you pan your 'left' and 'right' mono channels to the centre, solo one, then solo the other, they should sound different. If they sound the same, that's not a stereo recording.
I don't mean to patronise if you know this, I'm just finding it hard to understand your problem to help out...
Kicking it lo-fi:
POS computer
Cubase SX2
AKG C3000B
Shure SM58
Shure SM57
  #15
Old 08-11-2008
Newbie
OK. I am using Cubase SX3.
I have now solved my problem.
What I was doing was using 'Stereo Dual Panner' in the Cubase mixer to pan one instrument Stereo track to extreme right and the another duplicate stereo track to the left. What was happening was the space between the two mics was completly lost in each track.
If I use the 'Combined Dual Panner' mode In the Cubase mixer I can now have two seperate stereo tracks each panned to either side with no problems.
As i said, before, i was using the 'Stereo Dual Panner' mode and panning just one stereo track hard right or left was giving me a conflict in other words an in phase problem.
It was like recording into two seperate mics touching each other and after recording into a stereo track panning it to the far right. It wasn't sounding nice.
Rex.
  #16
Old 08-11-2008
Can someone describe what 'Combined Dual Panner does? Does it give dual-mono like flexibility?- that would be a pretty cool feature for stereo tracks.
  #17
Old 08-11-2008
mattr's Avatar
Just to add, remember that there is not one single way that a program pans. In Vegas I have the option on each track to change the pan mode between...
Add channels (0 dB centre)
Balance (0 dB centre)
Balance (-3 dB centre)
Balance (-6 dB centre)
Constant Power
Film
These all behave slightly differently, although I tend to go for constant power as it mimicks what I'm used to on analogue desks.
And you get different behaviors with stereo tracks too. For example, when panning a stereo track (I would assume) some DAWs will combine the two tracks (imagine a mixer with two channels, one panned hard left and one panned hard right, both at 0... as you pan the mix hard left the left channel remains as it is, while the right channel has its pan pot turned to the left), whereas it sounds like Cubase is muting one of the tracks and leaving the other track up (imagine the same mixer scenario however this time the stereo is 'panned' simply by pulling down one of the faders). Either way leaves you with audio on one side and not on the other.
  #18
Old 08-11-2008
Constant Power
Film
This looks like the typical pan law options for mono tracks on the stereo buses. You have these in Logic as options per track, or global for tracks? (Per track would seem to be even more dicy keeping track of than 'global.
Presumably pan on stereo tracks was the question. I'm wondering if what you describe here (and me earlier and asking about the OP's Cubase SX3) is that control option.
panning stereo sounds djclueveli Mixing / Mastering 14 07-30-2007 12:05
Stereo Panning Douhgy MP3 Mixing Clinic 4 01-29-2003 14:21
How panning of stereo tracks works - Did you know you only shrink the stereo field? Boray Roland, Boss, VS Series Forum 2 01-29-2003 11:09
Double stereo tracks, panning and stereo image question Cheetah Recording Techniques 5 06-01-2001 10:55
Panning When Mixing Down To Stereo Flyin' Brian Recording Techniques 1 09-21-1999 10:07
