Old 08-08-2008
DarkFriend's Avatar
DarkFriend DarkFriend is offline
Senior Member
DarkFriend has a reputation beyond reputeDarkFriend has a reputation beyond reputeDarkFriend has a reputation beyond reputeDarkFriend has a reputation beyond reputeDarkFriend has a reputation beyond reputeDarkFriend has a reputation beyond reputeDarkFriend has a reputation beyond reputeDarkFriend has a reputation beyond reputeDarkFriend has a reputation beyond reputeDarkFriend has a reputation beyond reputeDarkFriend has a reputation beyond repute
Thumbs up $30 Vocal Booth that Works
- Three pieces of plywood. Width should be 3 feet and height about 1 foot over your head. So if you are 6 feet tall, you want three pieces of 3x7 plywood.
- Six heavy door hinges.
- One super thick foam bed/mattress pad from Target, Bed Bath and Beyond, KMart, etc.
- About ten roofing nails
Connect the panels together with the hinges and drop the foam pad on top. Cut it along the plywood seams into three pieces from top to bottom. Use the nails to attach the foam pad to the plywood. Fold and go! Position it into a "C" or "[" to sing with the mic at the center back.
Just built this recently, and it definitely works. Add-ons include casters/wheels on one side to roll the thing around, or cheap door handles so you can pick it up or move it easier.
Old 08-08-2008
stevieb stevieb is offline
1K Silver Member
stevieb has a reputation beyond reputestevieb has a reputation beyond reputestevieb has a reputation beyond reputestevieb has a reputation beyond reputestevieb has a reputation beyond reputestevieb has a reputation beyond reputestevieb has a reputation beyond reputestevieb has a reputation beyond reputestevieb has a reputation beyond reputestevieb has a reputation beyond reputestevieb has a reputation beyond repute
Why go to the trouble of cutting 4 x 8 sheets of plywood down to 3 x 7? The leftover is waste, at least it can't be used on this project, so why not make the sides 4 x 8?
Old 08-08-2008
DarkFriend's Avatar
Senior Member
Because if I left it at 4x8, I wouldn't be able to fit it in my studio door?
Aside from that, it seems to me that the smaller the booth, the more focused and dead the sound.
Old 08-08-2008
santiu santiu is offline
Rock-scientist
santiu has a reputation beyond reputesantiu has a reputation beyond reputesantiu has a reputation beyond reputesantiu has a reputation beyond reputesantiu has a reputation beyond reputesantiu has a reputation beyond reputesantiu has a reputation beyond reputesantiu has a reputation beyond reputesantiu has a reputation beyond reputesantiu has a reputation beyond reputesantiu has a reputation beyond repute
have any with versus without clips? What thickness wood did you use? Plywood must be cheap over there in georgia. Three sheets of 4x8 ply by themselves will cost you well over $30 here in Los Angeles
Old 08-08-2008
mattkw80 mattkw80 is offline
Newbie 4 EVA
mattkw80 has a reputation beyond reputemattkw80 has a reputation beyond reputemattkw80 has a reputation beyond reputemattkw80 has a reputation beyond reputemattkw80 has a reputation beyond reputemattkw80 has a reputation beyond reputemattkw80 has a reputation beyond reputemattkw80 has a reputation beyond reputemattkw80 has a reputation beyond reputemattkw80 has a reputation beyond reputemattkw80 has a reputation beyond repute
I may build this..... got any pics of the finished project ?
Old 08-08-2008
jasonbmerrill's Avatar
jasonbmerrill jasonbmerrill is offline
the end of unreality
jasonbmerrill has a reputation beyond reputejasonbmerrill has a reputation beyond reputejasonbmerrill has a reputation beyond reputejasonbmerrill has a reputation beyond reputejasonbmerrill has a reputation beyond reputejasonbmerrill has a reputation beyond reputejasonbmerrill has a reputation beyond reputejasonbmerrill has a reputation beyond reputejasonbmerrill has a reputation beyond reputejasonbmerrill has a reputation beyond reputejasonbmerrill has a reputation beyond repute
mattress foam is simply horrible to use for decent absorption...
Old 08-08-2008
DarkFriend's Avatar
Senior Member
You'd think that would be the case, but it works great. I've got three A/C units right outside the window. Without the vocal booth, the mic picks up a lot of room and outside noise. In the foam booth, it is dead silent.
Old 08-08-2008
i understand that --
it DOES deaden the sound.
however, it does NOT deaden it in an even way across the spectrum. it will kill alot of highs, and leave the lows to muddy up your sound.
it might be silent, but its not "even"
you might want to fill it with something a bit more absorptive.
rockwool covered with burlap? That might be not so good.
maybe cotton -- there are certain absorptive cottons that would work good in that situation.
but for decent recordings, you are just shooting yourself in the foot using mattress foam, ime.
Old 08-08-2008
DarkFriend's Avatar
Senior Member
I'll post a song in a week or two and you can hear the results. Let me know if you think the vocals are missing something. What I'm hearing are the best vocals I've gotten out of my home studio.
Old 08-08-2008
i dunno, maybe this mattress foam you are using is above the norm?
you should look up some specs for the material you are using, there are specs available for rockwool/fibreglass, and other materials that show different absorption levels for different materials @ different thicknesses.
Even a decent absorber like rockwool only absorbs decent lower bass @ 4 inches.
Old 08-08-2008
DarkFriend's Avatar
Senior Member
Jason - my main goals were to
- isolate the vocals
- get rid of the outside noise
- get rid of the room
- do the above cheaply
For these purposes, it does seem to work. I dunno, perhaps the fact that the foam is mounted on fairly dense plywood helps its absorption properties?
  #12
Old 08-08-2008
i dont think plywood is absorptive
if you accomplish these goals, yet sacrifice sound, i dont see the point...
but, hey if it works for you, if it sounds good who really cares all that much?!?!
  #13
Old 08-08-2008
Rock-scientist
i don't get the argument here. If he's happy with the new sound, what's there to argue? who cares what the absorptive properties of his mattress foam is? I mean, sure it might not work as well for other people, but this is the internet. YMMV always applies doesn't it?
  #14
Old 08-08-2008
TimOBrien TimOBrien is offline
2.5K Gold Member
TimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond repute
Here's my portable version that I've posted here for over a year:
http://www.palmcitystudios.com/timob...oundbooth.html
You can also hang sheets of 703 acoustic fiberglass sheets in it if you want.
NOT a full acoustic solution but it works for me and keeps the wifey happy 'cause I can break it down in 10 minutes and store it in the garage....
  #15
Old 08-08-2008
of course, but it applies for my comment as well, no?
its not an argument.
  #16
Old 08-08-2008
Rock-scientist
agreed... ooops, sorry, i totally missed you "if it sounds good who really cares all that much?!?!" remark... my bad.
  #17
Old 08-08-2008
omtayslick omtayslick is offline
1K Silver Member
omtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond repute
Thumbs up
Pretty cool Tim.
Tom
  #18
Old 08-09-2008
DarkFriend's Avatar
Senior Member
Smile Photos
Ha - started to disassemble this and forgot I needed to take photos.
Kind of difficult to get a good shot, especially since I had myself backed into a corner, but you get the idea.
As I mentioned above, I finished a song yesterday, and I'm SO thankful I took the few hours to build this box. It made a world of difference. Look for the MP3 in the Mix Clinic forums in a week when I get the track back from mastering.
  #19
Old 08-10-2008
1K Silver Member
Now that he's posted pics, we can see that it's not actually plywood. Pricing is probably correct.
Tom
  #20
Old 08-10-2008
DarkFriend's Avatar
Senior Member
Not plywood? What is that then? I'm about as handy as a 5 year old..
  #21
Old 08-10-2008
Rod Gervais Rod Gervais is offline
Force of Nature
Rod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond repute
It's OSB (Orient Strand Board)
  #22
Old 08-12-2008
rayc's Avatar
rayc rayc is offline
L'ancien escargot
rayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond repute
Absorbent, not absorbtive.
ABSORBENT please!
Cheers
rayC
soundclick, unearthed, mspace & utub
  #23
Old 08-12-2008
ABSORBENT please!
http://www.thefreedictionary.com/absorptive
  #24
Old 08-13-2008
DarkFriend's Avatar
Senior Member
As promised, here's a link to the MP3 that came out of the sessions with this new, cheap vocal booth. I guess the better idea would be to post just the vocal line with no effects to really hear how quiet it is.
http://www.pmtechllc.com/wont_hurt_one_bit.mp3
or
http://www.myspace.com/evanlesser
  #25
Old 08-13-2008
kinda
soundproofing for vocal only (vocal booth?) UNIQNESS Studio Building & Display 9 06-15-2005 00:49
Fastest cheapest ISO booth, works, and takes up minimal space. tubedude Recording Techniques 12 05-10-2003 21:45
"Best" room ambiance for vocal tracking w/ no vocal booth? zip Mixing / Mastering 12 09-10-2001 20:32
"Best" room ambiance for vocal tracking w/ no vocal booth? zip Mixing / Mastering 0 09-07-2001 11:18
