Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 08-06-2008
chimprock chimprock is offline
Registered User
chimprock is on a distinguished road
Peavey VT Classic amp help
Hello everyone. I own a 1979(or so) Peavey VT Classic amp(50 watt 2x12). I am looking to replace the two speakers in it but I am unsure what the ohm rating of each speaker is, I can't seem to find it anywhere on the speakers. Does anyone else own this amp and know what the rating is?? It is a combined ohm rating of 8ohms, but I am unsure of how the speakers are wired. Any help would be greatly appreciated! Thanks.
Old 08-06-2008
arcaxis's Avatar
arcaxis arcaxis is offline
Force of Nature
arcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond repute
I'm lazy, I found some links for you to look at....
http://colomar.com/Shavano/speaker.html
http://www.bcae1.com/srsparll.htm
http://www.bcae1.com/spkrmlti.htm
For a combined rating of 8 ohms:
Series connection each speaker should be 4 ohms
Parallel conection each speaker should be 16 ohms
Old 08-06-2008
Registered User
The only problem is that I am unsure of whether or not it is wired in series or parallel. The wires are all wrapped in one bunch and it's tough too see where they are all going. I am guessing it is wired in parallel by the amount of wires though. So most likely the speakers are 16ohm rated, there doesn't seem to be many 4ohm guitar speakers out there.
Old 08-06-2008
Guitarer Guitarer is offline
Custom User Title
Guitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond repute
I dunno if they did the same thing back then...but my newer Classic 50 is 16 ohm, 8 each in parallel.
Old 08-07-2008
dementedchord dementedchord is offline
Psychotic State alumni ch
dementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond repute
what arcaxisis is trying to tell youis that it doesn't matter what's in there if you know the target is to be 8ohms... either 2 4's in series or 2 16's in paralell will get you there...
37.8% of all statistics are made up on the spot...
hey give a guy some room... people are trying to evolve here... for crying out loud...
Old 08-07-2008
Registered User
I understand, but I am unsure of whether or not the speakers are already wired in series or parallel.
Old 08-07-2008
arcaxis's Avatar
Force of Nature
Does one of the speakers have two wires on each of its terminals and the other speaker have just one wire on each of its terminals? This is likely a parallel connection. Series would only have one wire on each of the speakers terminals.
To further check the connection...
Do the speakers plug into the back of the amp with a phone jack?
If so, unplug it and remove one wire off only one speaker. Using a 1.5vdc flashlight battery and a few pieces of wire, momentarily connect and remove the battery to the tip and sleeve part of the plug that goes to the speakers. If you get a thunk sound out of only one speaker they are likely parallel. If you get no sound at all they are in series because you've opened the connection between them.
If you get to removing the speakers, mark the wires before you remove them so when you put them back you shouldn't have any out of phase speaker problems. You can actually check the phasing with that battery and both speakers hooked up. If you touch the battery to the plug, the speaker cones should move in the same direction, in or out. If they don't, reverse the connection on only one speaker to correct it.
Old 08-07-2008
ggunn ggunn is offline
Crystal Flavolian
ggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond repute
FWIW, most dual speaker tube guitar amps have their speakers wired in parallel so that if one speaker fails it doesn't present the amp with an open circuit on the output transformer while you are playing. More than likely it's two 16's in parallel. It's easy to check, though, especially if the speakers have slip-on (blade) connectors. Turn the amp on with nothing plugged into it and listen up close for the slight hum that all tube amps make. Disconnect one speaker. If the other one still hums, they are parallel.
If you have a multimeter, another way is to disconnect a speaker and check its DC resistance. An 8 ohm speaker will show about 6 ohms, a 16 ohm speaker about 12 ohms, etc.
Gordon in Austin
http://www.crystalflavola.com
Old 08-08-2008
Registered User
Well, I've finally received an e-mail back from Peavey. They told me that there are 2 - 8ohm speakers wired in parallel for 4ohms. So, since I've had the amp it's been plugged into the Main Out jack which is rated at 8ohms, when really it should have been in the Aux. Out jack which is rated at 4ohms. Doesn't that seem odd that they would make a Main out jack that is mismatched with the combined speaker load? Anyway, thanks for the advice everyone, I greatly appreciate it.
Old 08-08-2008
Registered User
Also, I was wondering what you guys would recommend for a speaker replacement. The amp is incredibly bright and clean (like a Fender) with the stock speakers. I am looking for more of an AC-30 type of tone, but I don't want to spend $200+ on some blue back Celestions. Any suggestions??
Peavey Classic 30 Extension Cab andydeedpoll Guitars and Basses 10 05-25-2008 15:14
wtb: peavey classic 30 Guernica Free Ads for Music / Recording Equipment 1 11-29-2007 15:24
peavey classic 30 problem? andydeedpoll Guitars and Basses 27 09-07-2007 15:51
peavey classic 50 Jacko Guitars and Basses 16 01-23-2006 17:34
Peavey Classic 20 King Elvis Guitars and Basses 0 10-16-2002 18:07
