If 9-volt Power Was Inadverdently Run Thru Pups...
Would it burn out the pups? Would it make a difference if the pups were active, or passive?
I know, there is more to electricity than just voltage- but that is the only thing that would be constant- amerage would vary. |
Depends.... Pickups could handle 9v at 11 milliamps (~.1 watts) no problem. if It was 11 amps (~100 watts), your pickups would fry. The wiring in a pickup is some pretty damn small guage wire, it will not take a lot of current. Your pickups (coils) will melt and/or poof if you push too much current thru it, as would any wire too small for the load.
Zaphod B Two-Headed President of the Galaxy (in exile) Tunes at http://www.soundclick.com/cowtowntommyboy "I have educated. I know what asshole is. "
If that's the case then I guess I'm way off.. Isn't a pickup basically a coil wire wrapped around a magnet(s)? I thought the string's vibration in the magnetic field induced a small current in the coil? I thought the coil itself would have very low resistance.
Anyhow, there's lots of very small-gauge wire wrapped around those bobbins. You can check at any of the large pickup manufacturers' web sites for impedance values, you'll see I am correct.
I can't say for sure, as I'm not about to do a test on a customer's pickup, but my guess is you would be fine.
Light "Cowards can never be moral." M.K. Gandhi
"It's not about who killed my son, it's about what's killing our children." -Aqeela Sherrills http://www.theforgivenessproject.com/ |
| new Pups. | cubanorocker316 | Guitars and Basses | 2 | 08-01-2007 17:10 |
| 12 Volt Halogen track lighting | biggestmuff | Studio Building & Display | 3 | 02-07-2006 14:59 |
| 12 volt phantom powered mic into a 48 volt pre? | Scriabin | Microphones | 1 | 04-22-2003 21:04 |
