Old 07-31-2008
MCI2424's Avatar
MCI2424 MCI2424 is offline
1K Silver Member
MCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond repute
I need a patchbay that is switchable from balanced to unbalanced inputs/outputs. If I have a mic pre that is balanced I want to be able to convert from balanced in to unbalanced out without the 6db loss. It must be active. Also, if I have an unbalanced input (RNP/RNC) I want to be able to convert the input form unbalanced to balanced to go to a balanced tape machine's inputs.
So, inputs and outputs to this patchbay have to be switchable through active circuits.
Am I just dreaming?
A Fostex 16 channel Tape Machine has 16 unbalanced ins and 16 unbalanced outs, so buying 32 channels of unbalanced to bal anced converters is too expensive.
Also I would like to configure the patchbay remotely through a GUI (probably MIDI)
Old 08-01-2008
bigtoe bigtoe is offline
Force of Nature
bigtoe has a reputation beyond reputebigtoe has a reputation beyond reputebigtoe has a reputation beyond reputebigtoe has a reputation beyond reputebigtoe has a reputation beyond reputebigtoe has a reputation beyond reputebigtoe has a reputation beyond reputebigtoe has a reputation beyond reputebigtoe has a reputation beyond reputebigtoe has a reputation beyond reputebigtoe has a reputation beyond repute
i guess i'm not understanding why you need active circuits.
you can either use transformers or tie (-) and ground together or float the ground depending on whether the nature of balanced out. i think it's float the ground... i'm surprised i'm not electrocuted...so check this info out...or someone pipe in.
also is your fostex +4? you might want that - 6dB loss from balanced output to unbalanced input.
remember the dangers of running micpres thru your patchbay...48V issues...
i have no clue what the GUI thing is about.
it sounds like what you are trying to do costs way more than a a couple level switching boxes.
Half baked,
Mike
www.independentrecording.com
"the first step to having 300-1000 shrink-wrapped CD's under your bed."
Old 08-01-2008
SonicAlbert's Avatar
SonicAlbert SonicAlbert is offline
Super-Sonic "Herb" Albert
SonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond repute
First of all, what you are talking about would be very very expensive. It might very well exist, but again it will be mind-numbingly expensive. Especially remote controlled through a computer based GUI.
As Mike suggested, you'd probably be better of figuring this out using level switching boxes. You'd use a regular balanced patchbay and do the level switching before or after it, depending on the gear. It wouldn't be remotely controlled, but it would be practical and a heck of a lot more affordable.
http://www.misterpotts.com
Patchbays chestwick91 The Rack 14 11-05-2007 09:31
patchbays... pikingrin Newbies 2 01-07-2006 04:06
patchbays AndAllWasSilent The Rack 1 10-26-2003 14:58
Patchbays... Teacher The Rack 4 06-05-2003 06:34
patchbays dbassguy The Rack 15 07-16-2001 17:01
