Can anyone make me an recommendation on a channel strip?
Hi,
I'm fairly new to this forum and started to get some really useful information here. Also I'm trying to put some new recording gig together for my band and looking for a channel strip. I'm using Rode K2 Mic and Mbox2 Pro. The budget is $2000 Would you guys be able to give me some recommendations? Thanks in advance! |
Personally? I'd avoid the whole "channel strip" garbage out there and just go for good preamps. That said, Langevin DVC. Hard to beat in that price range.
youre about in the price rance for a used api 3124
I was actually leaning towards a good preamp rather than a channel strip.
btw what do you guys think about geoff daking mic pre 4 with some good eq to go with? Last edited by sogon78; 07-31-2008 at 11:46.. |
Comes down to your own taste.
In that price range can you buy a "bad" pre?
He who seeks the truth must doubt everything |
For mic pres alone: Avalon= clean and stackable over tons of tracks. I have to look at my rack for more info on what I use and own. I am kind'a in a hurry. Good Luck
"Tascam, Fostex or Studers don't make hit records...........people do" MCI2424 - 2007 |
[QUOTE=Massive Master;2969952]Personally? I'd avoid the whole "channel strip" garbage out there and just go for good preamps. That said, Langevin DVC. Hard to beat in that price range.[/QUOTE
I don't know, unless a person has used some channel strips it is hard to say what is garbage and what is not. The two I listed have done really well on many sources and I have a rack full of great mic pre-amps (too many). Depends on how serious one is in the recording game. Channel strips are just the ticket for the occasional home recordist. They have the functions built in and are a good value for them. Investing in a long term adventure, I agree with you wholy. Depends on the situation. The one thing I hope will happen is that there is a mass market dump on eBay for the FR VMpro because I want a second one!
2 possibilities:
Avalon VT-737sm SSL XLogic Alpha Channel |
+1 on the Langevin DVC. It's the Langevin dual mic pre + eq plus the Langevin ELOP-- both of which cost >$1000 each, put together into one unit that sells for $1800. There are two versions and all of the second version units (it's been several years since the change) allow you to use the pre/eq section separate from the optical limiter section. The preamps sound very good. The eq is simple high/low shelving, but very useful. The limiter is simple-- kind of LA-3A like without the output transformer, relatively transparent and it is really hard to make it sound bad. I have a couple of slightly sluttier and higher gain preamps (Avedis MA5 and LaChapell 583s) that I tend to use most of the time because I don't track too many sources at once, but I will often put the DVC limiter on for vocals or other sources that can benefit.
SPACE AVAILABLE FOR RENT |
Guys,
Thanks for you reply, and actually I have almost decided to pick up the chameleon lab 7602. I have read good reviews and heard that it was really the best bang for the buck. (I could really use the money left over) |
| Channel Strip or just Pre-Amp?! | guismarques | The Rack | 22 | 04-20-2007 08:43 |
| What is a channel strip? | e_rock | Newbies | 6 | 04-20-2005 07:50 |
| mic pre/channel strip? | djessence | Microphones | 4 | 12-09-2001 12:19 |
| 424 & channel strip | Welschy | TASCAM User Forum | 0 | 10-11-2001 16:13 |
| Channel Strip | Peter Lake | The Rack | 18 | 07-20-2001 17:57 |
