Go Back   Home Recording > User Forums by Brand > Pro Tools Forum
Reply    Audiofanzine Digidesign Digidesign News Digidesign Medias Digidesign Tests Digidesign Articles Digidesign User Reviews Digidesign Classifieds Ads
Old 07-24-2008
JTC111's Avatar
JTC111 JTC111 is offline
Just Folkin' Around
JTC111 has a reputation beyond reputeJTC111 has a reputation beyond reputeJTC111 has a reputation beyond reputeJTC111 has a reputation beyond reputeJTC111 has a reputation beyond reputeJTC111 has a reputation beyond reputeJTC111 has a reputation beyond reputeJTC111 has a reputation beyond reputeJTC111 has a reputation beyond reputeJTC111 has a reputation beyond reputeJTC111 has a reputation beyond repute
mp3 option
I've got PT 7.4.2 with MP Toolkit. Does anyone know if that includes the "mp3 option"? And if it does, where do I find it?
Old 07-25-2008
Dax Productions Dax Productions is offline
Senior Member
Dax Productions has a reputation beyond reputeDax Productions has a reputation beyond reputeDax Productions has a reputation beyond reputeDax Productions has a reputation beyond reputeDax Productions has a reputation beyond reputeDax Productions has a reputation beyond reputeDax Productions has a reputation beyond reputeDax Productions has a reputation beyond reputeDax Productions has a reputation beyond reputeDax Productions has a reputation beyond reputeDax Productions has a reputation beyond repute
I believe it does. The install stuff for it should be on your protools install cd. Correct me if I'm wrong!
Old 07-25-2008
JTC111's Avatar
Just Folkin' Around
I called Sweetwater tech support and found out the deal. It's an option during install but the option is for a trial version only. If you want it after the trial version expires, it's a $20 upgrade.
Old 07-26-2008
Senior Member
Really? So when it says "pro tools mp3 option" on the music production toolkit features list that just means you have the *option* to buy it for extra if you want it???
Weak! Then again, just put it in itunes or get yourself a free lame encoder.
Old 07-26-2008
JTC111's Avatar
Just Folkin' Around
Yeah, there's a lot of things they list as stuff you're getting but you only wind up with a limited version. It's f'n annoying. I really need to go through all the plugs and make a list of what I actually have because on a bunch you have limited access.
Old 08-10-2008
Rusty K's Avatar
Rusty K Rusty K is offline
1K Silver Member
Rusty K has a reputation beyond reputeRusty K has a reputation beyond reputeRusty K has a reputation beyond reputeRusty K has a reputation beyond reputeRusty K has a reputation beyond reputeRusty K has a reputation beyond reputeRusty K has a reputation beyond reputeRusty K has a reputation beyond reputeRusty K has a reputation beyond reputeRusty K has a reputation beyond reputeRusty K has a reputation beyond repute
Yes but can you still import an mp3 into PT without the Mp3 option?
Old 08-10-2008
bennychico11's Avatar
bennychico11 bennychico11 is offline
bennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond repute
The music production toolkit does include the ability to import/export MP3s.
Sweetwater told you wrong
http://www.digidesign.com/index.cfm?...00&itemid=4865
Pro Tools MP3 Option
By including the Pro Tools MP3 Option, the Music Production Toolkit makes it easy to listen to a new mix on a portable device or quickly share it with other band members without having to use a separate application.
www.redlabaudio.com
Old 08-10-2008
Rusty K's Avatar
1K Silver Member
Yikes...$495...what about the $20 mp3 option? Can you import with that?
Old 08-10-2008
yes
my previous post was referring to the original poster's question
www.redlabaudio.com
Old 08-10-2008
JTC111's Avatar
Just Folkin' Around
Damn, I looked all over for that information and couldn't find it. Thanks Benny.
Actually, they were running a deal where it was $245 if you were buying an 003. It was worth it to me just for the TL Space reverb and Smack compressor alone. Those are two excellent plugs. Plus, it bumps the 32 track ceiling up to 48 stereo tracks @ 96kHz. Well worth $245.
Old 08-10-2008
Senior Member
You CAN import mp3's WITHOUT the mp3 option. The mp3 option allows you to export as mp3.
  #12
Old 08-10-2008
JTC111's Avatar
Just Folkin' Around
Although I never specified it, I was talking about exporting as an mp3.
  #13
Old 08-10-2008
Rusty K's Avatar
1K Silver Member
Cool...I didn't know I could import. Coversion is not a problem, I've got several ways of doing that.
  #14
Old 08-11-2008
MessianicDreams's Avatar
MessianicDreams MessianicDreams is offline
Throbbing Member
MessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond repute
Yes, MP toolkit comes with the MP3 option.
You can use it thru the bounce-to-disk function - when you're chosing what your target file format is, there should be MP3 in there.
On a side-note, it uses the Fraunhofer encoder algorythms, which supposidly is the best out there!
There are 10 types of people...those who understand binary and those who don't
My humble home studio!
My Choons
My DIY Broadband absorbers thread!
Mbox2, MacMini (Intel), Mackie HR624, Focusrite Liquid Mix, Frontier Design AlphaTrack
  #15
Old 08-11-2008
JTC111's Avatar
Just Folkin' Around
Now there's some sweet news!!!
what's the best option? MPR Microphones 9 03-02-2006 21:19
which option tbone36109 Microphones 3 09-04-2005 23:21
Which would be the best option? travelin travis Other Equipment and Reviews 6 08-24-2005 00:42
Best option for... bostonfan2 Digital Recording & Computers 2 09-17-2003 11:51
Is there another option for OH TamaSabian Microphones 12 08-21-2003 01:36
Copyright Đ 1995-2008 Audiofanzine except where noted. All Rights Reserved.
