I can't work out what i've done, but somehow Consolidate is now greyed out in the edit menu, and alt shift 3 doesn't do anything either
any ideas? win xp pt 7.1 |
Im not sure what Consolidate does....but I hope its what I think it does....I am used to using Adobe Audition and there was a "merge/rejoin" option that would take a track that has several splits in it and make them one file...kind of like Grouping the track, but actually making it a single file rather than just looking like a single file.... if this is the Pro Tools equivalent....then thank you very much.... |
yep sounds like the same thing thajeremy
As is often the case it was something I had done, so to help those who may do the same thing - Some (Waves in particular) plugs always take about 3-4 minutes to load when opening pro tools, so when I’m tracking I remove all the plug-ins from the plug-in folder ( on my pc c:\program files\common files\digidesign\DAE\plug-ins ) and put them into a temp directory. So when I’m switching between programs pro tools loads quickly. When I’m mixing I put them back in and it rarely matters because I don't leave PT when mixing. Turns out "consolidate" exists as a plug-in so if you remove every plug you've also removed the ability to consolidate your tracks. I had a look in the folder, but alas there wasn't a plug-in named "consolidate", so I haven't worked out which plug it’s a part of. So I just put all the plugs back and voila, consolidate is back. FYI if you ever do the same!
www.myspace.com/heavyrainproductions Last edited by wreckd504; 07-30-2008 at 04:25.. |
| PT consolidate help? | pipelineaudio | Digital Recording & Computers | 12 | 02-20-2006 10:10 |
| Record button greyed out in CW 9 | jeff0633 | Cakewalk / Sonar Forum | 1 | 02-18-2004 16:58 |
| My digital performer midi inputs are all greyed out? Anyone... | Trash Man | Digital Recording & Computers | 3 | 10-28-2003 13:36 |
| 'Record Automation' greyed out? | mixsit | Cakewalk / Sonar Forum | 3 | 08-08-2002 15:38 |
| recording button greyed out? | joseph putz | Cakewalk / Sonar Forum | 9 | 12-07-2000 10:29 |
