Old 07-23-2008
JTC111's Avatar
JTC111 JTC111 is offline
Just Folkin' Around
JTC111 has a reputation beyond reputeJTC111 has a reputation beyond reputeJTC111 has a reputation beyond reputeJTC111 has a reputation beyond reputeJTC111 has a reputation beyond reputeJTC111 has a reputation beyond reputeJTC111 has a reputation beyond reputeJTC111 has a reputation beyond reputeJTC111 has a reputation beyond reputeJTC111 has a reputation beyond reputeJTC111 has a reputation beyond repute
I'm using a Neutrik patchbay to run mics into preamps/preamps into compressors/compressors into 003, etc.
Which configuration should I be using if I want to be able to send a signal into one unit and out to a different unit?
Old 07-23-2008
NL5's Avatar
NL5 NL5 is offline
Unpossible!
NL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond repute
Half normalled.
That way when nothing is plugged in, the signal will pass thru the patchbay like nothing is there. When you plug something into the top and/or bottom, the signal is interrupted.
So if you go from your preamp to the patchbay, then to the converter, you would take the top plug and send that to the "in" on your comp" take the "out" from the comp and put it in the bottom plug. Now, your comp is inline on that channel.
Make sense? I suck at explaining things over the internet.
They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. -B.F.
Old 07-23-2008
MadAudio's Avatar
MadAudio MadAudio is offline
Damned if I do
MadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond repute
Are you saying that you're patching the mic into the patchbay?
Newest endeavor: Playing drums in a live band version of 7 Door Sedan's music.
"Do yourself a favour just shut up, read up then put up." --muttley600
Old 07-23-2008
JTC111's Avatar
Just Folkin' Around
I'm not sure what you're saying. I guess what I want to be able to do is chain things together. Let's say I have a mic pre connected to patch #1 and a compressor to patch #2. I want to be able to send a signal into the pre through the #1B patch (input to mic pre) and send the signal from the pre to the compressor by patching #1A (output from the pre) to #2B (input to the compressor). Which configuration should I use for that? My head tells me to use the "isolated" configuration but my head is often wrong.
Originally Posted by NL5 View Post
Half normalled.
Old 07-23-2008
JTC111's Avatar
Just Folkin' Around
This is the patchbay I'm using.
Old 07-23-2008
JTC111's Avatar
Just Folkin' Around
Yes, until I get around to making an XLR bay, I'm using my 1/4 inch bay. But I'm aware of the dangers of unplugging mics from a hot 1/4 inch bay and I'll be careful.
Old 07-23-2008
NL5's Avatar
NL5 NL5 is offline
Unpossible!
Isolated for the comp ins/outs. You want the preamp to automatically go to the converter, right? Then be able to insert something into the path?
edit - and I have that exact patchbay - as well as a TT bay hooked to the Trident
Old 07-23-2008
JTC111's Avatar
Just Folkin' Around
I don't think I want the pre to go to the converter automatically. It's easier on my brain if I just daisy chain. I'm much less likely to screw up that way. So to do what I described, is 'isolated' the right way to go?
And I'm jealous of your TTbay.
Old 07-23-2008
NL5's Avatar
NL5 NL5 is offline
Unpossible!
I think so. You will just have to patch in EVERYTHING. Luckily, it's easy to change back the other way if you change your mind. Normalled just means it will automatically go to where it normally would go. If that makes sense. You are essentially just putting all the inputs/outputs to the front of the patchbay.
Don't be, its a royal PITA. Especially since half my stuff is on 1/4". The Nuetrik is much better made as well.
Old 07-23-2008
NL5's Avatar
NL5 NL5 is offline
Unpossible!
The more I think about it, I'd still normal the pre's to the converters. You would patch a comp in EXACTLY the same way anyway. And, you could daisy chain exactly the same way. Only difference is if you were going straight in, you wouldn't need a patch cord.
Old 07-23-2008
JTC111's Avatar
Just Folkin' Around
Thanks. Yeah, that just works better for me. I can visually see the signal path that way and it makes my brain hurt less.
I guess I was swayed by the coolness factor. Those TT bays always look so damn impressive.
  #12
Old 07-23-2008
JTC111's Avatar
Just Folkin' Around
I have three pres for a total of 5 outputs. I only have 4 converters available on the 003 (1-4 are DIs and mic pres). I don't think the math works for me, no?
  #13
Old 07-23-2008
NL5's Avatar
NL5 NL5 is offline
Unpossible!
It still would, yes. The four would be normalled to your 4 inputs. If you decided to use pre 5 instead of pre 1 lets say, you would just take the output from 5 and put it in the bottom of channel 1.
  #14
Old 07-23-2008
JTC111's Avatar
Just Folkin' Around
I kinda sorta understand what you're saying but unless someone is sitting here with me drawing pictures, I don't think it's something my brain is going to retain it or fully comprehend it too easily. I think I'm better off sticking to isolated (the setting for simpler minds apparently).
  #15
Old 07-23-2008
NL5's Avatar
NL5 NL5 is offline
Unpossible!
Yeah, it would be WAY easier to just show you. It's really not that complicated. Maybe someone can explain better than me. Sonic Albert is pretty good with this stuff - he helped me out quite a bit when I was getting started.
You should have seen me when I got the Trident. It was supposed to be shipped with all the wiring and labeled with a manual. It showed up with no wiring at all, and no manual. I had to figure out the stupid patchbay and ELCO's from SCRATCH. Talk about a PITA. Took me MONTHS!
  #16
Old 07-23-2008
JTC111's Avatar
Just Folkin' Around
So why do we put ourselves through all this?
  #17
Old 07-23-2008
NL5's Avatar
NL5 NL5 is offline
Unpossible!
Mental deficiency?
I'm obsessed with music! Now, if I could just learn to play.........
  #18
Old 07-24-2008
SonicAlbert's Avatar
SonicAlbert SonicAlbert is offline
Super-Sonic "Herb" Albert
SonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond repute
If you don't want to split the signal you should probably just use "non-normalled" which is what they refer to as "isolated". It's a straight through signal from rear to front of the patchbay.
It means you need to make every connection at the front of the patchbay. But that's not a bad thing because the patch cables allow you to see your routing at a glance.
Don't forget to label the front of your patchbay!
http://www.misterpotts.com
  #19
Old 07-24-2008
JTC111's Avatar
Just Folkin' Around
Mental deficiency?
I can sing and play. Now if I could just learn to record....
  #20
Old 07-24-2008
JTC111's Avatar
Just Folkin' Around
Yep, that's what I did. I like being able to see it laid out in front of me. I even have patch cables in different colors so I can see the sound chain better.
  #21
Old 07-24-2008
WhiteStrat's Avatar
WhiteStrat WhiteStrat is offline
Go Speed Racer, Go!
WhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond repute
Patchbays really improved my life in the studio. I've got everything normalled, so 70-80% of the time, I don't even need patch cables--my default hookups are ready to go.
But even with everything going straight through like you've done (that's how I started with patch bays, too) it oughta save you time and help you keep organized.
Have fun!
  #22
Old 07-24-2008
JTC111's Avatar
Just Folkin' Around
Have fun!
Fun? Is this stuff supposed to be fun? Nothing on PT7.4 and the 003 works the way it did on 5.x and the 001. I'm having to relearn a lot of things. I had to call tech support to get sound out of my synth today...ugh! And my studio really needs some tidying up after all I've done in there this week.
But on the bright side, I put in a call to the person I'm going have master my cd and found out that it's not all that much more to have him mix it as well, so I'm going to let him do that and take that pressure off of myself. On my first cd, I was very hands-on and very involved with the mixing and mastering to the point where I heard the songs so many times that to this day I can't really enjoy my own cd. It was played out in my head by the time it went to print. I really don't want that to be the case with this one. So I'll still be involved, but I'll trust him to do the initial mix and I'll get involved for the tweak stage. This guy has done work on about a third of the cds in my collection. When I look at his client list it's like I'm looking at my mp3 playlist.
Of course I'll hang around and take notes while he does his work. Might as well learn from the masters, right.
  #23
Old 07-24-2008
WhiteStrat's Avatar
Go Speed Racer, Go!
Well then, except for the hangups with the new stuff, it sounds like you're in a good place. Doing the CD this way could be the best of both worlds.
  #24
Old 07-24-2008
JTC111's Avatar
Just Folkin' Around
Yeah, although I really did envision myself doing more on this one. I've found that I have no problem mixing other people's stuff but when it comes to my own, I hesitate and anguish over every manipulation. And that's especially true on this upcoming cd because I've put together a great supporting cast and I don't want to screw it up.
Oh well, like I said, the pressure's off now. All I have to do is the tracking. The sun shines a little brighter now.
  #25
Old 07-25-2008
I think once you learn how to get around in PT 7.4 you are going to like it a lot better. It's a great version of the program in my opinion.
Patchbay configuration recommendations fraserhutch The Rack 14 08-23-2006 01:44
px1000 patchbay: don't understand how to change the configuration earworm The Rack 4 05-19-2006 00:36
New Configuration Bdrum Drums and Percussion 4 12-08-2005 15:22
Configuration? johnro Newbies 0 02-14-2002 21:47
rca-patchbay=s/pdif (coax) patchbay? fretless The Rack 5 06-29-2001 22:20
