Old 07-23-2008
kno1ills@yahoo. kno1ills@yahoo. is offline
Junior Member
kno1ills@yahoo. has a reputation beyond reputekno1ills@yahoo. has a reputation beyond reputekno1ills@yahoo. has a reputation beyond reputekno1ills@yahoo. has a reputation beyond reputekno1ills@yahoo. has a reputation beyond reputekno1ills@yahoo. has a reputation beyond reputekno1ills@yahoo. has a reputation beyond reputekno1ills@yahoo. has a reputation beyond reputekno1ills@yahoo. has a reputation beyond reputekno1ills@yahoo. has a reputation beyond reputekno1ills@yahoo. has a reputation beyond repute
Panels too thin?
It seems 4" 703 panels are the norm from what I read on the forum. Would 2" panels for the walls and ceiling and 4" panels for the corners be okay? The thicker the better? But is it pointless to have 2" panels on the walls?
Old 07-23-2008
Rod Gervais Rod Gervais is offline
Force of Nature
Rod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond repute
Absolutely not (meaning it is not pointless) = 2" with a 2" airspace is perfectly acceptable for first reflection points where your biggest concern is high-mid and high frequencies.
Plus - you still get some bang for your buck with additional LF attenuation.
Rod
Old 07-23-2008
bigtom's Avatar
bigtom bigtom is offline
Senior Member
bigtom has a reputation beyond reputebigtom has a reputation beyond reputebigtom has a reputation beyond reputebigtom has a reputation beyond reputebigtom has a reputation beyond reputebigtom has a reputation beyond reputebigtom has a reputation beyond reputebigtom has a reputation beyond reputebigtom has a reputation beyond reputebigtom has a reputation beyond reputebigtom has a reputation beyond repute
While I am no expert, I made my wall panels 2in. and my bass traps were 4in.. This was done because of advise I got from here. I have not made any for the ceiling yet, but I think I'm going to make those 4in.. Mostly because I am sick to death of all the stapeling and I have about 24 panels of 2in. left that need to be used up. I've heard of guys using 6in. on the ceiling above the listening position, but I don't know if I will do that or not. I think the big thing is make sure you have an air gap behind the wall panels so the inso. is not tight against the wall.
Big Tom
Old 07-23-2008
Junior Member
Thanks for the advice. I'll definitely consider putting 2" panels at the 1st reflection points.
Old 07-24-2008
Junior Member
Would 2" panels work at all for bass traps? Not worth it? I just wanted to get all the frames built and hung and then when I get more cash, get the other half of the 703 boards and slide them in for the bass traps.
Old 07-24-2008
CIRO's Avatar
CIRO CIRO is offline
Capitu´s brother
CIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond repute
Maybe it´s me and my crappy and small room, but I have at least 4" in the corners and RFZ. And 10" on the ceiling and 12" in front wall in the middle of monitors.
Ciro
www.soundclick.com/ciromoreau
Old 07-26-2008
bpape's Avatar
bpape bpape is offline
Acoustic Designer - GIK
bpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond repute
2" for bass control isn't going to get it. On the reflections, you're just extending the low end control a bit. 4" solid will work better. 4" with a 2" gap, better yet.
Bryan
I am serious... and don't call me Shirley
GIK Acoustics
Old 07-26-2008
Junior Member
Bryan
Would it be better than no treatment? It would be temporary.
Old 07-30-2008
bpape's Avatar
If you mount it with a 2" gap behind it as Rod suggested, it will help a little. Just don't expect miracles below 150Hz.
Bryan
GIK Acoustics
thin vocals niall Mixing / Mastering 6 09-29-2006 17:12
Thinny Thin Thin Tonytc9 Mixing / Mastering 8 09-23-2006 00:13
From Mix to CD - my mix is thin. What gives? Dr. Jeep Mixing / Mastering 9 02-13-2006 21:54
Thin Top End LeeJ Guitars and Basses 6 12-07-2004 09:14
thin carvin Mixing / Mastering 9 05-22-2004 14:53
