Go Back   Home Recording > Special Forums > DIY, Mods, and Homebrew
Old 07-18-2008
jndietz's Avatar
jndietz jndietz is offline
The Way It Moves
jndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond repute
Crate Vintage Club 30 help (still broken)
I posted another thread in "Guitars and Basses" earlier and thought it was just a blown preamp tube. But, alas, it doesn't seem to be it, either. I replaced the tube, and still have the same symptoms:
When plugged into the "input" jack, I get no sound out of either the clean or overdrive channel. When plugged into the effects loop, I get sound.
Not really sure what to do at this point or start. Links to schematics:
Preamp schematics
Power amp schematics
I play lead guitar for a rock band called Indecision based out of Omaha, Nebraska. Check us out here
Old 07-18-2008
dementedchord dementedchord is offline
Psychotic State alumni ch
dementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond repute
ok since we know that it affects both pre's we have 2 options to start with... 1st is the supply voltage present going tp the pres???
2nd do we get signal at test point 9... (or R24/R70)???
if the voltages are there and signal it that test point then it has to be in the jack for the effects loop or something in the reverb drive is sucking it down...
try to check this and fill me in...
37.8% of all statistics are made up on the spot...
hey give a guy some room... people are trying to evolve here... for crying out loud...
Old 07-21-2008
fishincan's Avatar
fishincan fishincan is offline
Newbie
fishincan has a reputation beyond reputefishincan has a reputation beyond reputefishincan has a reputation beyond reputefishincan has a reputation beyond reputefishincan has a reputation beyond reputefishincan has a reputation beyond reputefishincan has a reputation beyond reputefishincan has a reputation beyond reputefishincan has a reputation beyond reputefishincan has a reputation beyond reputefishincan has a reputation beyond repute
hi, i have a crate vintage clube 50 which stopped working on me a while back. turns out, after replacing tubes and all that, it was the capasiters. they were all bloated out, so if they are, need to be replaced. also, make sure you have the right fuses, not the fast ones, but heavy duty, slow blow ones. good luck.
ps. love the amp, my fav. haha. i still need to get my reverb working again though, anyone familiar with that? i think its probably just a transistor or something that crate uses for the reverb plate
peace, fishincan
Old 07-21-2008
peace, fishincan
please do me a favor and never work on this yourself... most amps have multiple fuses... the main power is typicly a slow-blo... the speaker protects and such are typiclly fast-blow... "bloating" is something your girlfriend/mother does once a month... and while it can indicate a bad cap it doesn always do the job... guitar amps have never had plate reverbs.... and the spring reverbs they do have are not driven or recoverd by transistors in a tube amp....
Old 07-21-2008
jndietz's Avatar
The Way It Moves
Well, I'll be honest: I'm probably going to go take it to a pro anyways. I'd love to learn how this shit works but don't have the time or patience
Old 07-21-2008
Light's Avatar
Light Light is offline
Born in the Light ofStars
Location: Creating saw dust at rapidly increasing levels
Light has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond repute
Get the RIGHT fuse, which may or may not be a slow blow. It should say right on the amp, or if not in the owners manual.
Light
"Cowards can never be moral."
M.K. Gandhi
"It's not about who killed my son, it's about what's killing our children."
-Aqeela Sherrills
http://www.theforgivenessproject.com/
Old 07-22-2008
jndietz's Avatar
The Way It Moves
peace, fishincan
I didn't think of checking those. I'll rip its guts out again tonight and check that out
Old 07-22-2008
jndietz's Avatar
The Way It Moves
Can anyone recommend a good multimeter thats cheap?
Also what are these SLO-BLO tubes?
Old 07-22-2008
if you look at the fuse and it's a thin wire then it's a quick blo... which makes it great for speaker protection and the like... if the amp DC's then it goes real quick... if what you see looks more like a strip then it's a slo blo... it's designed to be in say the primary power supply where it needs to pass current all the time... then when the current gets extreme (a short for instance) then it goes... make sense???
Crate Vintage Club 30 electronics help... jndietz Guitars and Basses 7 07-15-2008 11:44
just got my first tube amp!!! crate vintage club 3x10 surfmaster Guitars and Basses 21 03-02-2008 23:45
Crate Vintage Club 30 zed32 Guitars and Basses 17 02-21-2006 20:13
Just bought a used Crate Vintage Club 50 (mods?) Easto Guitars and Basses 3 06-12-2005 19:41
Broken Buttons on the MR8 - I'm joining the club buzzard Fostex Forum 5 03-02-2004 18:01
