Go Back   Home Recording > Special Forums > DIY, Mods, and Homebrew
Old 07-15-2008
thebigcheese's Avatar
thebigcheese thebigcheese is offline
"Hi, I'm in Delaware."
thebigcheese has a reputation beyond reputethebigcheese has a reputation beyond reputethebigcheese has a reputation beyond reputethebigcheese has a reputation beyond reputethebigcheese has a reputation beyond reputethebigcheese has a reputation beyond reputethebigcheese has a reputation beyond reputethebigcheese has a reputation beyond reputethebigcheese has a reputation beyond reputethebigcheese has a reputation beyond reputethebigcheese has a reputation beyond repute
Silencing a rattling amp
This is probably not as cool as some of your mods, but it could be a helpful tip if, like me, you have an amp that rattles. My Crate 65w amp has been rattling for a while, so I decided I was sick of it and looked into it and found that the metal around the actual amp was rattling against the wood enclosure. It's a rather bassy amp and I have a rather bassy guitar, so it made sense that something would rattle. Anyway, I had some Dynamat left over from when I was fixing some rattling in my car (also a result of speakers) and put some strips anywhere that a flat surface of the metal touched the wood enclosure. It is now 100% rattle free
I didn't take any pictures on the way, but if anyone wants me to take some pictures of the now-reassembled amp and point out what I did, I can. The main point of this post, I guess, is to let anyone with this sort of problem know that Dynamat is a good solution. I think I just bought the speaker kit, though any of the kits would probably work (you really just need small strips). They make a spray, too, apparently. That could be fun.
http://www.dynamat.com/products_car_...eaker_kit.html
It's basically just like a thick tape, but specially designed for this purpose.
My band.
Old 07-16-2008
dementedchord dementedchord is offline
Psychotic State alumni ch
dementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond repute
that's good tip... i always used that foam rubber tape for carpets and caulking doors...
37.8% of all statistics are made up on the spot...
hey give a guy some room... people are trying to evolve here... for crying out loud...
Old 07-16-2008
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
I use that foam rubber weather stripping. I always had this problem with 4x12 cabinets, so I would take off the back and line the lip that the back screwed into with the foam. I would also do the center post. Then I would put the back back on, and add a screw into the center post.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 07-16-2008
I think that you get similar results with any of the stuff. Dynamat is kinda cool and might be a bit thinner then some other options, but I think it's probably also the most expensive... I was just lucky and had some left over. It works really well, though, I can say that much.
My band.
Old 07-17-2008
Dani Pace's Avatar
Dani Pace Dani Pace is offline
Why 2K?
Dani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond repute
Anything that rattles has always annoyed me. In places where heat is not a problem like speaker cabs, grills or sreaker covers, I use self adhesive felt strips. I buy it in sheets and cut it to fit wherever I need it. I've even stuck it to drum rims to stop rattles there too.
The more I learn, the more I realize how much I don't know. http://www.soundclick.com/sixfeetover
Old 07-17-2008
altitude909's Avatar
altitude909 altitude909 is offline
Best Advice Ever: RTFM
altitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond repute
This stuff is also good on the inside of a computer case btw
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual
Old 07-17-2008
I can't believe I never thought of that... and I've still got almost a full sheet, too. Oh well, it doesn't matter so much now that I'm recording on laptop...
My band.
Old 07-18-2008
yeah, they actually sell kits for it now but did it years ago when I had some left over from doing my car.
Silencing separate tracks jonasjamison Don't Fear The Reaper 2 10-11-2007 15:56
Silencing Help themaddog Analog Only 1 04-22-2006 12:29
Best Rack for Silencing a Noisy Rackmount PC?? undermind Digital Recording & Computers 0 10-25-2005 13:41
Silencing the PC: Reviews! Halion Digital Recording & Computers 0 07-26-2005 08:45
silencing fans on my computer dminor Digital Recording & Computers 3 10-10-2001 19:34
