Go Back   Home Recording > Special Forums > DIY, Mods, and Homebrew
Old 07-15-2008
jndietz's Avatar
jndietz jndietz is offline
The Way It Moves
jndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond repute
Repairing a broken pot on an amp
'Morning everyone:
My vocalist was loading my amp into the truck and broke the volume knob for the overdrive channel clean off! All the way down to the pot.
I was wondering how I go about replacing this. What things do I need to consider when buying a new pot for this amp? How difficult is it to replace this?
Thanks in advance!
~Jared
I play lead guitar for a rock band called Indecision based out of Omaha, Nebraska. Check us out here
Old 07-15-2008
Whale Bone Whale Bone is offline
Senior Member
Whale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond repute
Pots have several specs. Basic ones:
-value, in ohms
-type, log, lin or rev log (response curve through its range)
-shaft size, threaded part that'll be mounted to the amp faceplate
-shaft shape, 'D', round, split (prob. not on anamp)
-shaft length, how far out the front it extends so the knob will sit right and clear the faceplate.
post layout, when mounting to a PC board - straight out, right angle in a striaght line or not, etc.
If it's newer, it may have posts that connect directly to a PC board, so you'd have to find the right form-factor as well as value and type, etc.. Depending on the space in the amp, you may be able to install a standard pot with wires leading to the PC board if you can't find the right fit. I've done that with broken input jacks when I couldn't find the molded, enclosed plastic 1/4" jack.
Then there's your comfort soldering (and the tools). I buy guitar pots from Stewart MacDonald and the only amp pots I've bought in recent years are for a vintage Ampeg, so I went to a specific vendor who sells accurate replacements. Others can probably suggest favorite suppliers.
Been mostly buying Alpha-brand pots recently and had good experience with them, though I've seen opinions to the contrary around here.
I've been happy ordering components from Newark - caps and ICs.
Lastly, this all sounds worse than it is. I'm sure you can find a good replacement without too much pain.
Old 07-17-2008
Dani Pace's Avatar
Dani Pace Dani Pace is offline
Why 2K?
Dani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond repute
Depending on the amp, some are a lot harder than others. Replacing the pot itself usually isn't that hard of a job but on some amps you have to do a lot of disassembly just to get to it, then a lot of reassembly putting it back together.
The more I learn, the more I realize how much I don't know. http://www.soundclick.com/sixfeetover
Old 07-17-2008
dementedchord dementedchord is offline
Psychotic State alumni ch
dementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond repute
easiest thing to do is go to the manufacturer... sometimes they'll just send you one for the asking... (ok not often)... but you wont have to fuss over how well it will fit etc...
37.8% of all statistics are made up on the spot...
hey give a guy some room... people are trying to evolve here... for crying out loud...
Old 07-18-2008
Dani Pace's Avatar
Why 2K?
Unless it's a Fender amp, they take forever to reply to any parts request or order.
Old 07-18-2008
jndietz's Avatar
The Way It Moves
B-52 hasn't even responded to my phone call that I left with them days ago. I'm going to end up e-mailing them and calling them simultaneously every five minutes until I get an answer
Old 07-18-2008
jndietz's Avatar
The Way It Moves
Dunlop sent me a free toggle switch when the one on my Crybaby broke only a few weeks after getting it. Nice guys over there
Old 07-22-2008
jndietz's Avatar
The Way It Moves
B-52 is sending me a pot for $10.
Sounds all right to me. Hope it isn't too hard to put in...
Old 07-22-2008
just be careful with it and you'll be fine... be methodical about taking it apart... screws in a bowl and such so ya dont lose any that sorta thing... let the iron heat up before trying to desolder the old one... more damage has been done here than anywhere else... when your done the solder should look shiny... if it's dull then it's a cold solder joint and will eventually fail... get plenty of solder on it but avoid overdoing it...
Old 07-22-2008
dgatwood's Avatar
dgatwood dgatwood is offline
is out. Leave a message.
dgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond repute
I recommend solder wick (braid) to remove the old solder. Put it next to the contact, heat up the contact, and watch the solder flow away from the pot. That way, there's minimal risk of lifting traces by doing something wrong (e.g. heating a lead while tugging, then accidentally pushing after it is halfway out). After the solder is removed with a braid, the part should pull out easily without heating or anything.
Originally Posted by Obi-Wan
If you mod me down, I will only grow stronger.
Old 07-26-2008
Minion Minion is offline
1K Silver Member
Minion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond repute
Seems a Little expensive to me...You can buy a carbon pot of pretty any value for about $1-$4...You will know what Value that is anyways when you go to replace the Pot....
I would simply open the amp Remove the broken Pot check it for its value which should be written on the Pot (If not you can measure it with a DMM)..One you know the Value you just go to an electroncs store with the pot and find one of the correct value and dimentions and replace it...should be able to do it in less than 1 hour....
M-Audio Delta 44 + Delta 1010LT
5 Piece Drum Kit w6 Cymbals
Custom Made Bass Guitar
Custom Made Les Paul Guitar
Mackie Traction Studio 2.1
P-4 PC w 512mb DDR 80gb HD
Sell you used Equipment Here:
http://www.proaux.com/phpprobid/index.php
repairing AKG K240 Wireneck Other Equipment and Reviews 3 03-29-2006 19:22
Repairing a Fostex VF-80 in the UK HappyDave Fostex Forum 2 09-27-2004 03:13
Repairing an NT1 NathanVibration Microphones 0 08-09-2004 08:22
Repairing Old Records Hi_D_Ho_Man DJ & Hip Hop Production 3 03-05-2004 05:59
repairing a broken part sharpie00 TASCAM User Forum 4 01-04-2004 22:15
