Go Back   Home Recording > Special Forums > DIY, Mods, and Homebrew
Old 07-14-2008
sweetbeats's Avatar
sweetbeats sweetbeats is offline
Reel deep thoughts...
sweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond repute
Question Soldering center recommendation?
Can anybody recommend a good one?
I have a simple 15/30W iron right now, but I feel like it is too hot on the 30W setting for audio PCB work...scorches...and not hot enough on the 15W to get the solder to flow well, so I think I'm looking for a variable temp unit.
And in that case, what temp works well for recapping and such?
Old 07-14-2008
Light's Avatar
Light Light is offline
Born in the Light ofStars
Location: Creating saw dust at rapidly increasing levels
Light has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond repute
I've got two Weller's (one at the shop, and one at the home hobby electronics station), a WES51 and a WESD51. Basically the same thing, but the WESD51 has a digital temperature read out. Pricey, but I love the things.
But if you are overheating things, it is almost certainly not that the iron is too hot, but that you are leaving it on there too long. A hotter iron that you can use for a shorter time is a good thing.
Light
"Cowards can never be moral."
M.K. Gandhi
"It's not about who killed my son, it's about what's killing our children."
-Aqeela Sherrills
http://www.theforgivenessproject.com/
Old 07-15-2008
sweetbeats's Avatar
Okay. thanks. I'll keep that it mind. I do try and be sensitive to the timing. It just feels like it hasn't always heated through right and it is scorching the surface. Maybe I'm off-track.
Old 07-15-2008
altitude909's Avatar
altitude909 altitude909 is offline
Best Advice Ever: RTFM
altitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond repute
Light
M.K. Gandhi
+1 On the WESD51, they are so common that you should be able to find one cheap. I got mine new on ebay for $75. Plenty of different tips which are cheap also.
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual
Old 07-15-2008
evm1024's Avatar
evm1024 evm1024 is offline
1K Silver Member
evm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond repute
Antex
I've never found a weller that I liked. Ages ago in high school I worked at Tektronix building scopes and other test equipment. Tek used the Antex M/3U exclusivly. I've found this to be by far the best iron for me.
You can get them from www.mmnewman.com
http://www.mmnewman.com/shopping/sho...pfs=1&catid=14
They are $27 plus the cost of tips. Many types of tips for about $5 each. 12 watts and a 650 to 700 degree tip temp.
Regards, Ethan
In Sunny Vancouver ..... (Washington)
Old 07-15-2008
sweetbeats's Avatar
Goodness...
That's a lot of tips!
What would be good for PCB work? For cabling?
Old 07-15-2008
evm1024's Avatar
1K Silver Member
Yes
Originally Posted by sweetbeats View Post
Goodness...
They are designed for PCB and typical cables. They just work well on PCB and all.
I've never found anything that comes close in comfort and control.
-E
Old 07-15-2008
buckkillr8's Avatar
buckkillr8 buckkillr8 is offline
David Gilmour's clone
buckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond repute
another +1 on the WES's. I have the WES51 on my bench.
My Gear
Old 07-16-2008
dementedchord dementedchord is offline
Psychotic State alumni ch
dementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond repute
for me any of them with a variable temp and different size tips is a winner... the one i have now is a cheap Tennma... i keep small round /small chisel/big round tips handy for different work...
37.8% of all statistics are made up on the spot...
hey give a guy some room... people are trying to evolve here... for crying out loud...
Old 07-16-2008
santiu santiu is offline
Rock-scientist
santiu has a reputation beyond reputesantiu has a reputation beyond reputesantiu has a reputation beyond reputesantiu has a reputation beyond reputesantiu has a reputation beyond reputesantiu has a reputation beyond reputesantiu has a reputation beyond reputesantiu has a reputation beyond reputesantiu has a reputation beyond reputesantiu has a reputation beyond reputesantiu has a reputation beyond repute
I've always been a fan of the Weller WTCPT, and that's the one I use now. Rock solid performance, and build like a tank. The analog/digtal temp adjustable stations are convenient and all, but without frequent calibration, that temp control will go out of wack. You can change the tip temperature on the WTCPT, but you have to get replacement tips that swap in, so it's a bit more involved than a dial.
Old 07-16-2008
Anfontan's Avatar
Anfontan Anfontan is offline
Banned by eurt
Anfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond repute
I use a Weller all day at work with a 700 degree tip for repairing and modifying circuit boards-it does the job well but they are fairly fragile it seems. But using it 40 hours per week would be tough on any station though.
  #12
Old 08-12-2008
sweetbeats's Avatar
Meant to reply awhile ago.
Thanks everybody for sharing. Its been helpful.
Here is what I'm using at present...likely anything could be better (or at least a new tip???)
  #13
Old 08-12-2008
For basic cable making, that will be fine but I would not go near a circuit board with that monster. You really need something with reasonable temperature control for that.
  #14
Old 08-12-2008
sweetbeats's Avatar
Okay. Thank you for the confirmation.
I've got an Antex M2 pencil iron on the way that is 650 degrees at the tip. It looks like it will be much easier to handle.
Soldering gun? RideTheCrash Other Equipment and Reviews 20 04-06-2006 13:14
Tell me I can do this...soldering.. bford Guitars and Basses 20 12-17-2005 13:22
Patchbay Soldering longsoughtfor Studio Building & Display 8 11-12-2002 09:46
Soldering help... NoFO Studio Building & Display 8 01-17-2002 09:21
soldering cables... here is how to do it ! ! ! ! Proveras Recording Techniques 1 10-10-2000 16:16
