EQ'ing individual drums in Cubase 4 LE
I'm currently using the 909 kit. Is there a way I can EQ each drum instead of trying to EQ the entire kit? I tried dissolving the part, then trying to edit each drum, but it didn't work.
what do you mean dissolving the part?
take each drum and make it it's own track ( a track for midi bass, snare, tom, tom ,tom, cymbal, hi hat etc) then eq each one. |
or use something that has multiple outs
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual |
Never mind, I think I just need to read more about MIDI routing.
if you want to split the drum tracks to individual AUDIO tracks (i thought you were talking about midi) then you need a firewire interface... it has inputs to plug your microphones on your drum kit and then cubase will indeed split them up. you just need to choose the insert on each track to be input on the interface that has a mic going into it.
Actually, I was talking about MIDI. I'm using my Micron as the MIDI controller for the 909 VST drumset.
oh well. then just cut and paste each individual drum track to it's own midi track
| Sound clips of individual drums tuned and different pitches?? | WERNER 1 | Drums and Percussion | 1 | 04-21-2006 22:33 |
| Does Cubase LE come with MIDI drums? | ericlingus | Cubase User Forum | 3 | 12-19-2005 10:43 |
| Best place to buy individual drums from | CJWalker | Drums and Percussion | 0 | 02-28-2004 02:29 |
| a cubase mix into wavelab, or individual tracks??? | GhettoWayz | Cubase User Forum | 7 | 10-23-2003 11:53 |
| Cubase 5 package drums | awilliams | Cubase User Forum | 3 | 10-28-2001 17:31 |
