How do you know it is time to recap?
Hi folks.
I apologize in advance due to the fact that, at my skill level, I am much more likely to be a taker here than a giver. ![]() I started a thread about recapping over in the Analog Only forum thinking it might be more appropriate over here, and another member reinforced that idea, so here I am. ![]() The original thread is here. As you'll get from the original thread, I am comfortable with a soldering iron, have a pile of mid-80's Tascam gear that I intend on treating right for many, many years. I want to keep it going and going well. I have heard about the degredation in performance that bad caps can cause, not to mention the potential damage. I especially want to avoid the latter. So in the spirit of good stewardship to my gear and my craft I'm trying to evaluate if I get into recapping now, and where to start. Thanks in advance for the time you expend in this newbie! ![]() |
From what I've read and been told, I would agree with an early post in your other thread that says if you've cleaned your pots, switches and faders and they still pop and/or scratch, then you probably need to recap (as long as the pots, etc. are really clean and good). I've also been told told, when asking about a mid to late 80's Soundcraft 200B, that recapping the electrolytic caps is likely a good idea. I haven't yet, but I would like to try a few channel strips now that I've built a work bench. My dilemma is that the mixer sounds good, but I do have some scratchy faders and some channels that are the same revision (I've got 5 different rev's across all of them) do sound different. So, leave it alone and just set the gains differently or start recapping? Sorry, I guess I've posed the same question in response, but I'm leaning towards recapping, but doing it at my leisure instead of immediately. Note: Someone might've mentioned this, but the ones you care about replacing are generally only the electrolytics, the can-shaped ones.
I'd say if you have the time, skills and can risk screwing it up, go for it on a few channels/groups/auxes, etc. and see if it helps. Then decide from there. The other consideration in my case is that many people advocate using larger value caps as you can fit them in the same foot print as 80's-era and get more low-end. Doing this eliminates your existing channels as controls for the experiment and also risks losing some of the flavor of the original design. One last thought is that many nicer, low-ESR caps have one-time surcharges when ordering, so bulk is good, but that makes experimentation more expensive. The last two are where I'm currently stuck, but as a bassist primarily, I'm very tempted to go with larger value caps when I do this. Hope this helps in some way. |
A sincere thanks for your post, and it is helpful...getting somebody else's thoughts and ponderings, even though some may be inconclusive, is helpful.
I realized as I read your post that (duh) I have 8 spare channel PCB's for my Tascam M520. Could I post some links to some hi-res detailed pics as well as the schematic for for the channel PCB and get some recommendations on component replacement? I could do two cards...one with just cap replacements, and the other with caps and IC replacements if there are solid recommendations that would be known improvements...? Thanks again... Do larger value caps require more power from the source? Any thoughts on my question about a new soldering iron? What temp works good for this kind of work, and what solder wire guage is recommended? |
If it was a Leslie, you'd know. Thunderstorms is what we used to call it.
If anybody would be so graciously inclined, I have scanned and zipped pertinent schematics and parts lists for my M520 and would love to know what should be replaced and with what.
The .zip file is located here. Its about 3Mb. |
When I'm riding along with the top down, and my hair is blowing all over the place- I know I need to re-cap- the old one obviously blew off!
Couldn't help myself... |
Um...
I think my mother-in-law had a recap a couple weeks ago...damage due to sticky food...I guess that was a crown.
You guys are nuts. |
Seriously...anybody?
Maybe I'll just wait awhile...maybe I'm being impatient.
1. Do I replace caps with the same value caps or is there an art to selecting other values for a desired result? 2. Any IC replacement recommendation for the M520? Somnium7 are you out there? ![]() I'm generating a parts list for my 58 as well...where is a good place to by capacitors? |
1st as to where to buy??? i like digikey... prices are good seems like it's always in stock (or i've been lucky)... good selection...
as to the caps... if ya look at the parts books you would hopefully realize that they tend to come in ranges... ie. it goes from say 11mf-22mf-33mf-47mf and on... so you can think of useing the next step... but it may not help that much unless that particular one is in the audio path... also there's a temp rateing ... the higher temp is a good thing they tend to last alot longer and dont drift as much... as to what chips to use... looks like most of whats in there are 4556's tl072's and such... there are way better chips available but before i would recommend some specifics i'ld want to see an actuall schematic... board layouts and parts lists dont work for me... i need to see what that one is used for... ya dont want to just add say the fastest op-amp available if there's a chance that it's used as say a line driver where current handling is more important than speed... get my drift??? also if/when you change out these op-amps ya should consider adding extra decoupling caps at each opamp...easiest way is to jumper a cap between pins 4+8 on dual opamps...
37.8% of all statistics are made up on the spot... hey give a guy some room... people are trying to evolve here... for crying out loud... |
Digikey...okay.
![]() ![]() ![]() Quote:
Thank you so much for the information. |
I noticed that there are many caps that have the same capacitance and voltage rating, but there are additional bits that are different. Can somebody explain those differences to me?
Like look at these 3 caps...All the same capacitance and voltage rating, but the percentages and that pesky "(B. P.)"...what is that? 10uF 16V 10uF 16V (B.P.) 10uF 16V (B.P.) 20% |
#12
most caps have side that is high voltage and the other is low... at least relitively to each other... make sense??? in otherwords... they're polarized... also a cap can be rated within certain tolerences... some in big guitar power supplies can be +20/-50% ??? wow thats a lotta tolerence ya got there dude... in things that are high speed circuits or in tone controlls i use 5%... which is bout as tight as it gets for caps...
so your 3 caps there are ... 10mf 16V (polarized) 10mf 16v bp (bipolar or non polarized) 10mf 16V bp 20% (bipolar and at a 20% tolerence)
#13
Dementedchord,
Awesome response...thank you...I'd add to your chiclets but I'll have to wait until I "spread it around" some more. ![]() So is there any advantage to going with a tighter tolerance cap if there is one that is originally spec'ed at 20% say and going with a 5 or 10%? |
#14
the advantage is going to come in when you start doing the channels in that 520... especially in the eq's... a tighter tolerence here will mean better matching between channels... in fact what ya may want to do is go through each channel and pick the one that you like the best... they all will have drifted some but which way and how much??? so when we get the one you like the best meter the caps and then build two channels... one with the original spec the other the one you liked... now you can test them against each other and decide which way to go with the rest.... make sense???
#15
Makes perfect sense. Thank you again.
So am I right in assuming that the downside to using tighter tolerance caps is that they cost more? Quote:
#16
yep... wish my fluke79 had cap testing...
#17
Fluke 80 Series Digital Multimeters (that is for "III" )
DCV Maximum Voltage: 1000V Accuracy: Fluke 83 III: ±(0.1%+1) Fluke 85 III: ±(0.08%+1) Fluke 87 III: ±(0.05%+1) Fluke 87/E: ±(0.05%+1) Maximum Resolution: 0.1 mV ACV Maximum Voltage: 1000V Accuracy: Fluke 83 III: ±(0.5%+2) Fluke 85 III: ±(0.7%+2) Fluke 87 III: ±(0.7%+2) Fluke 87/E: ±(0.7%+2) Maximum Resolution: 0.1 mV DC Current Maximum Amps: 10A Amps Accuracy: Fluke 83 III: ±(0.4%+2) Fluke 85 III: ±(0.2%+2) Fluke 87 III: ±(0.2%+2) Fluke 87/E: ±(0.2%+2) Maximum Resolution: Fluke 83 III: 0.01 mA Fluke 85 III: 0.1 µA Fluke 87 III: 0.1 µA Fluke 87/E: 0.1 µA AC Current Maximum Amps: 10A Amps Accuracy: Fluke 83 III: ±(1.2%+2) Fluke 85 III: ±(1.0%+2) Fluke 87 III: ±(1.0%+2) Fluke 87/E: ±(1.0%+2) Maximum Resolution: 0.1 µA Resistance Max Resistance: 40 MW Accuracy: Fluke 83 III: ±(0.4%+1) Fluke 85 III: ±(0.2%+1) Fluke 87 III: ±(0.2%+1) Fluke 87/E: ±(0.2%+1) Maximum Resolution: 0.1W !!!! Capacitance 1 nF-5µF !!!! Frequency 0.5 Hz to 200 kHz ********* Happy "matching". ... don't forget having fun doing all that. ![]() BTW, I'd rather restrain myself from commenting on the whole idea of "matching" electrolytic capacitor's values to somehow match the channels ( making them sounding the same as the one that sounds best (or the one that you "like it best", what ever that may mean )., heh heh, I must be missing something here completely. Very interesting "idea" indeed ![]() also, some rant on Fluke Meters - 80 Type, Models and Series @eBay, this is just in case as I don't know which "fluke" exactly we are talking here, not that it really matters in this case... ************** *********************** one more little thing. Quote:
![]() But you don't have to, of course. As I've said before, it's all great as long the "doctor" is busy and happy ![]() /respects |
#18
Electrolytic caps failing in a power supply (i.e. the really big ones) will manifest itself in a hum. PSU caps ("smoothing" Caps, they filter the ripple out of the DC after being converted from AC) are always the ones to start with since they deal with higher currents and will be the first to go.
Another important thing to understand with lytics is how they are rated voltage wise. The voltage rating is only related to the MAX voltage the device can withstand, so really when recapping you can use anything the same rating or higher (NEVER LOWER, they will blow). The catch is that the higher the voltage rating, the larger the cap. This generally has no bearing on the low values since they are all very small physically and rated for high voltages but larger uF values, it will be can be an issue depending on what else is around it. It is always very good practice to double check the case size/lead spacing of what you are buying vs what is there on the board. The big electronic suppliers in the US are Mouser, Digikey, Allied, Newark. Between those four you should be able to find just about everything. I have had good luck finding the odd value stuff at: http://www.surplussales.com/Capacito...citorsAll.html
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual |
#19
Dr. ZEE, altitude 909 et al,
THANK YOU for the replies. All very helpful. Dr. Zee: Quote:
)Quote:
Altitude909: Quote:
#20
#21
perhaps you meant the decoupling caps that are used around the opamps??? they are there to eliminate parasitic signal from the opamps getting into the supply lines... and neither of these types of caps have anything to do with current capability... especially since they are dealing somewhat exclusively with DC... the only caps that deal with AC and subsequently with current "to some degree" are those that are actually in the signal path... like those interstage types in gutar amps... and really not much of an issue... you are right though in suggesting that the power supply is the place to start... and the only caps that have to be replaced are the electrolytics... the small value caps are generally like tantalum/polyester/polypropylene and dont really go bad that often but can drift a bit...
#22
No misunderstanding.
The larger the current draw after the rectifier, the larger the capacitance needs to be to bring down the ripple. Big caps dry out first, result is more ripple on the DC supply line, simple as that. I didn't say anything about current stability Opamps don't get decoupling caps btw, they have bipolar supplies and are never connected to ground
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual Last edited by altitude909; 07-22-2008 at 03:25.. |
#23
ah... i misread part of your post i thought you were trying to make some kind of distintion between filter and smoothing caps... my bad... though i still dont see the current draw as an issue... they need to be sufficient to pass enough current along to the device sure... but that shouldn't affect the amount of ripple... in fact an underspec cap will exhibit less ripple in some cases as the supply at that point is constantly in a sag state... ymmv...
as to opamp decoupling look at any good schemo and youll find them all over the place... most of the time they are very small values that sit on the supply rails near the op-amp and either go from supply to ground or between the two supplies... take them out and things get noisey quickly...
#24
electronically speaking, a lot of solid state packages (chips...lol) require tiny capacitors on their ground, or a supply pin, or whatnot...
in a simple block diagram, they are omitted. They overcomplicate the inherently straightforward function you are studying... BUT, they are practical circuit details, either needed for operation, or as in this case, to keep the noise down to a dull roar. in addition to recapping or whatever else maintenance you are needing/wanting to do, someone mentioned new OP AMPS up there... now THERE'S a place you can spend a few bucks, measure twice and cut once... and really get some bang for your buck, performance wise... this whole thread SQUARELY reminds me of a ream of similar ones on this one electronics site, whrere they are all EE guys in the audio field... they have schematics on home brew tube pre-amps, etc etc... if i can find the old site name, I will post it here fro you guys... ANYone liking this forum will go apesh!t about that site, trust me. You into audio? you have a soldering iron? you can read a basic schematic??? *you will get a woody*, LMAO |
#25
Okay...I'm getting into this...
I'm recapping the PS for my Tascam 58.
I've looked at the 4 retailers listed above and I'm finding that I can't get exact replacements, particularly with case size. I was advised to go bigger on the case size if possible, but for one cap in particular (6800µF, 40mm x 40mm case, 50V) all I can find are smaller cases. How critical is that? Also, the leads on the cap mentioned above are like riveted on terminals rather than tails...can those be rotated? The Tascam PS PCB has the mounting points in an 'L' configuration (i.e. the cap terminals are perpendicular to each other), and I'm concerned about finding a replacement cap with the right spacing/configuration. |
| How do you know when it is time to recap? | sweetbeats | Analog Only | 12 | 07-11-2008 16:10 |
| Mix advice wanted on rock song - "Time Time Time" | FattMusiek | MP3 Mixing Clinic | 6 | 04-12-2006 23:00 |
| First time cakewalk/ long time analog ! | Goodrat | Cakewalk / Sonar Forum | 6 | 01-14-2001 09:26 |
