Old 06-30-2008
JTC111's Avatar
JTC111 JTC111 is offline
Just Folkin' Around
JTC111 has a reputation beyond reputeJTC111 has a reputation beyond reputeJTC111 has a reputation beyond reputeJTC111 has a reputation beyond reputeJTC111 has a reputation beyond reputeJTC111 has a reputation beyond reputeJTC111 has a reputation beyond reputeJTC111 has a reputation beyond reputeJTC111 has a reputation beyond reputeJTC111 has a reputation beyond reputeJTC111 has a reputation beyond repute
This two-channel strip is very clean and only slightly used. It probably doesn't have more than 50 hours on it. I'm the original owner. It sells everywhere for about $599 new. I'll part with it for $450 shipped and I'll eat the paypal fees. My ebay id is jtc_111 and I have a 100% feedback on 211 transactions for those that want some assurance.
Key Features:
Two award-winning Class A discrete transistor-based Focusrite pre-amps
This pre-amp demonstrates the same wide bandwidth philosophy featured in the original vintage Focusrite units, ensuring low noise and distortion.
Mic 'air' and controllable impedance
TwinTrak Pro pre-amps also feature a wire-wound, inductor-induced ’Air’ function, as well as controllable mic input impedance. The 'air' switch enables the pre-amp to recreate the open and airy qualities of more expensive transformer-based pre-amps.
Dual mono/stereo optical compressor
Featuring custom fast-acting optos, comprehensive controls and true stereo linking to provide extremely smooth yet effective control of the signal's dynamics.
'Pro Series' Latency-free monitoring
Monitor your source signals within the mix, directly at source, avoiding having to resort to monitoring via your DAW or digital desk, both of which may be prone to latency issues.
24 bit DAC as standard and Optional ADC
24 bit/192 kHz DAC is fitted as standard, for processing digital signals or feeding digital signals into the monitoring path. The optional 24 bit/96kHz A/D can be retro-fitted and both the ADC and the DAC feature wordclock BNC.
Two Direct Instrument Inputs
For quick and easy connection without the need for a separate DI box. A High Gain switch provides the option to boost the incoming signal by 20dB - ideal for passive guitars.
Post pre amp inserts and compressor side-chain inserts
Professional routing options that allow for enhanced processing flexibility. Side-chain inserts provide increased control over the compression from an external source to deliver, for example, frequency-conscious compression.
Old 07-02-2008
JTC111's Avatar
Just Folkin' Around
Might someone be interested for $400 shipped?
Old 07-09-2008
JTC111's Avatar
Just Folkin' Around
Final Offer: $350 shipped and paypal fees included or it's going on ebay
Focusrite TwinTrak versus ART MPA Gold dshlapak The Rack 7 01-24-2007 19:29
Focusrite Twintrak Pro Questions. demensia The Rack 17 02-19-2006 12:00
Focusrite Twintrak Pro Problems. demensia The Rack 0 02-17-2006 07:18
Focusrite Twintrak vs FMR RNP / RNC Rufus Leaking The Rack 12 08-11-2003 15:56
Focusrite Platinum Range: TwinTrak Pro Flatpicker The Rack 3 07-17-2003 13:47
