Old 06-25-2008
trancedental's Avatar
trancedental trancedental is offline
Dedicated Member
trancedental has a reputation beyond reputetrancedental has a reputation beyond reputetrancedental has a reputation beyond reputetrancedental has a reputation beyond reputetrancedental has a reputation beyond reputetrancedental has a reputation beyond reputetrancedental has a reputation beyond reputetrancedental has a reputation beyond reputetrancedental has a reputation beyond reputetrancedental has a reputation beyond reputetrancedental has a reputation beyond repute
Got a Midiizer for £50.00 but without the cables & manual, looks too complicated to use without a manual so was wondering if anyone here has a scanned or .pdf version?
Also any information on the cables needed or will trade & / or buy some that would be great I suppose I'll have to track some down & / or make them?
Cheers JK
Old 06-25-2008
Beck's Avatar
Beck Beck is offline
Analog Partisan Ranger
Beck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond repute
JK,
I have the manual on pdf and also pinouts and info on how to make the cables. I thought I had your direct email, but I can't find it. Send me a PM and I'll send you what I have.
«:: «::B::» «::E::» «::C::» «::K::» ::»
"Where in the hell are the red M&M's?"
~My Lil' Sister, 1976
Old 06-25-2008
Dedicated Member
Cheers Beck!!! PM on it's way!
Old 06-25-2008
Dedicated Member
Midiizer MTS-1000 Manual & Cables
Double post!!!! Doh!!!!!!!!
Old 06-27-2008
Dedicated Member
Got the manual from Beck, thanks for that!
Seems to be some problems with this machine, powers up, LCD screen on, control buttons including lights come on but no control buttons change functions. The flywheel / shift esc keyboard section doesn't do anything either?
I tried sending a sync code to a recorder but with no luck so far?
Any ideas? Is there a reset procedure for this machine or cell type battery that needs replacing maybe?
Any help appreciated!!!
Old 06-28-2008
RICK FITZPATRICK's Avatar
RICK FITZPATRICK RICK FITZPATRICK is offline
Been Here, Posted That
RICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond repute
Did you make the cables yourself? I hope you saw the pin 4 to pin 2 reversal on each end. AND the shield around...ah...I can't remember which one. I'll have to look. Oh, here it is.
fitZ
ps. good luck with the midiizer. I LOVE mine!!
BTW, I just made TWO of these. I had to lengthen my cables to TWO MSR's
Oh, and btw again, I believe the diagram is viewing the plug from the BACK SIDE. But check your Pin numbers for sure.
alright breaks over, back on your heads!
Old 06-28-2008
Dedicated Member
RICK FITZPATRICK , I was trying to record a sync code although I don't have the serial cables I'm assuming that I can still do this without the serial cable, which just won't adjust the speed of the recorder?
I'm sure I read that this is possible on here somewhere, just like a usual sync box?
As I said I don't think any of the function control buttons are working, and none of the buttons change when you press them at all!!!!!!!!!! The cursor doesn't move on the LCD screen when you use the keyboard keys either????
Old 06-29-2008
Dedicated Member
Followed the instructions below but still none of the control buttons work.
"After the machine is power up, press OTHER, then press UTILITY, then hold down SHIFT and OTHER together and the software version will appear on the screen."
Old 07-01-2008
Dedicated Member
Wink
This machine appears to be working at least some of the time after I took it apart a few times, although maybe not 100%.
Still I managed to record & play back a sync code even without the accessory 2 cable connected to my TSR-8.
Once I locate & / or make a cable I'll see if the other functions work properly on it?
Reading through the manual it looks like I'll have to create a MIDI song & events to run a sequencer?
I really want PTLE to just work from MTC without having the Midiizer doing the MIDI tempo stuff, I think I'd rather do that in the computer!!!!!!
Old 07-17-2008
Dedicated Member
Bump this thread up to ask a silly question!!!!!!!!!!!
Does it matter which way round you use these cables, because either end is wired slightly differently to the other, which end goes to the midiizer & which to your R2R recorder? Or does it matter at all?
Go the parts so I'm ready to go........................! My soldering skills are not that great!!!!!!!
Old 07-17-2008
As long as the pin to pin wiring is correct, then it shouldn't matter which end of the cable goes to which machine. They're the same. But JUST TO MAKE SURE you've soldered them correctly, use a multimeter set on "continuity", or resistance(R1 etc.) to check the PIN TO PIN CONTINUITY. Start with the PIN 2 on one Dsub to PIN 4 on the other. Then, PIN 4 to PIN 2 on the other. Those are the only two pins with CROSS CONNECTIONS from Pin 2 to Pin 4 and vice versa. Then check the contiuity from PIN 5 to PIN 5, 6 to 6, 7 to 7, 8 to 8, 13 to 13, and 14 to 14. It is IMPERITIVE these are soldered correctly and do NOT short out to other pins. I know these are tough to solder. I've done TWO sets and their a bitch. BTW, you've got to really LOOK closely for the numbers. Do NOT assume the direction of the plug shown in my drawing is from the front or back. LOOK AT THE NUMBERS ON YOUR DSUBS!
fitZ
  #12
Old 07-18-2008
themaddog themaddog is offline
Rockin' & Rollin'
themaddog has a reputation beyond reputethemaddog has a reputation beyond reputethemaddog has a reputation beyond reputethemaddog has a reputation beyond reputethemaddog has a reputation beyond reputethemaddog has a reputation beyond reputethemaddog has a reputation beyond reputethemaddog has a reputation beyond reputethemaddog has a reputation beyond reputethemaddog has a reputation beyond reputethemaddog has a reputation beyond repute
I'm not sure if you're still having this problem, but on my Midiizer, once in a while one of the white menu buttons gets stuck. If this happens, I'm not able to use any of the buttons until it get "unstuck." It might just be a stuck button on your console.
Hope that helps!
-MD
  #13
Old 10-24-2008
Dedicated Member
Angry
Final update on this thread!!!!
Although this particular Midiizer does send & record SMPTE codes & syncs to recorded stripes without any problem & also the MIDI functions seem to work, none of the tape transport control features work at all from what I can tell, nor does this machine seem to want to communicate with the TSR-8. Tried the set up procedure ect;
At first I suspected my soldering skills were suspect as I had to makup up a connection cable, if you saw my soldering you would tend to agree, but I picked up another Midiizer very cheap complete with the original PW-5MD D-Sub serial cable, and further tests confirm that the first Midiizer doesn't fully function.
Can't get bargains all the time I suppose!
  #14
Old 10-28-2008
Dedicated Member
Unhappy
Been looking for a schematic for the Midiizer on the net with no luck!
Have opened it up again & not 100% sure about the 3 PCB fuses, they don't test right but work so could be worth replacing them to rule them out.
I might have to take the 2 main PCB boards out & have a look then, I suppose at least I've got another working Midiizer to compare but really don't want to open up another one as I'll propably wreck it!!!!!
  #15
Old 10-28-2008
Dedicated Member
Unhappy
Fuses replaced but same old problem, now I've taken my working Midiizer apart to help troubleshoot the faulty one!
So the whole front top control panel & attached PSB on the faulty one works 100% now it look's I got to take apart the rest of the bottom section & the 2 PCB boards within to see what I can find....................?
Arrrrrrrrgggggggggghhhhhhhhhhhhhhhhh!!!!!!!!!!!!!!!!!!!
Update: Fault is somewhere on the lower PCB, the control PCB & the function button display PCB board are working OK.
Can't see anything broken or burnt out though, seems that a service manual / schematic is not going to be cheap judging by a phone call I made earlier!!!!!
  #16
Old 10-29-2008
I've got one. It might take a few days but I'll see if I can scan them and post em or email you a file. I'm slammed with work at the moment so give me a few days.
fitZ
  #17
Old 10-29-2008
Dedicated Member
Cheers Rick!
I'm begining to suspect that something like a digital chip might be faulty somewhere on the bottom PCB main board as the lights / buttons on the syncro mode CHASE PHASE SLOW, & the code staus LOCK 24 25 30 DF VIDEO don't light or seem to work at all although sometimes they light up just slightly once in a while.
I know the middle control PCB & the top PCB at the back of the cover work as I've swaped them around into with the working Midiizer.
Midiizer picture for reference below not my faulty one!
  #18
Old 10-29-2008
What a BEAUTIFUL machine! I love em. Been so busy I haven't had a chance to turn mine on in 8 months. Heres mine. Kinda blurry though. I suck at photography
fitZ
  #19
Old 10-29-2008
Dedicated Member
Wink
WTF!!!! So that's what happened to mission control's console!!!!
  #20
Old 10-30-2008
My "mission control" is only part of the story. Heres what it will look like when finished...except even the Sketchups arn't finished yet too! Not enough hours in the day anymore. But I'll finish it as soon as I finish the kitchen I'm building right now. Sorry, don't mean to hijack this thread. But I thought you might be interested in my ANALOG MISSION CONTROL Except these Sketchups don't have the twin MSR-16s or other ANALOG tape decks inserted yet. Thats why I have the MIDIIZER...32 tracks with a 32 channel M-3700 to mix on.
fitZ
  #21
Old 10-30-2008
Dedicated Member
Talking
That is impressive!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! When will it be all finished, looks like a lot of work?
Back to our scheduled programing.............!
Should have posted this on here before but just to say on the faulty midiizer display screen, the "accessory 2 online & ready" message does not appear after the Tascam welcome message. Afterwards the usual timecode displays as normal.
Seems that something is wrong along the signal circuit from the Acc 2 serial D-Sub input on the lower bottom PCB onwards. Or maybe a software glitch? Wonder if there is a reset procedure on this machine?
  #22
Old 10-30-2008
Dedicated Member
Taken a few pictures
1. My working Midiizer software version displayed on screen
C 1.22 M 1.21
BTW the faulty Midiizer software displays
C 2.00 M 0.00 ??????
2. Control PCB Middle showing the location of "C" chip marked "C 2.00"
3 Main Lower PCB board
4. Main PCB lower board showing "M" chip marked 2.00 & the nearby yellow SANYO battery
So the "M" chip in the picture above marked as 2.00 is the one displayed on the faulty Midiizer software version as M 0.00
Either that strange SANYO battery is gone or the chip is faulty?
Just going to test the battery for continuity now!
File Type: jpg Midiizer Control PCB Middle C Chip on left.jpg (66.6 KB, 62 views)
  #23
Old 10-30-2008
Dedicated Member
Here's the type of battery which seems weak in the faulty machine & doesn't even make my meter bleep at all it reads .328 continuty........!
The battery in the working machine reads -1.0 AND bleeps!
I've swaped the "M" 2.00 / 1.22 chips (I'm assuming they are ROM chips?) around & that one works in the working machine and is displayed as normal "Accessory 2 is online" & the software version is displayed. And the buttons & lights all come on at power up & work when you press them!!!!
When I moved the other working "M" ROM chip to the faulty machine it resulted in the same problems as before.
So I need to get hold of one of these weird batteries, none available locally or online over here to try out
Sanyo Cadnica N-SB3 Nominal voltage (V) 3.6, Capacity (mAh) at 0.2C rate 90
This thread is becoming as long as one of those sweetbeats threads!!!!!!!
  #24
Old 10-30-2008
Work? Surely you jest...your the one tearing apart a Midizer?
  #25
Old 10-31-2008
jpmorris's Avatar
jpmorris jpmorris is online now
Tape Wolf
jpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond repute
It would take a bit of adapting, package-wise, but wouldn't one of these work?
http://www.cellpacksolutions.co.uk/r...-batteries.asp
I've seen the three-pin ones often used for this kind of thing, on the Cheetah MS6 (which I had to replace to fix mine) and also on sideways firmware boards for the BBC micro.
Tascam CM-16 Card for Midiizer themaddog Analog Only 11 04-24-2008 12:56
MTS-1000 Midiizer EDAN Free Ads for Music / Recording Equipment 0 10-31-2007 07:53
Tascam Midiizer MTS-1000 cables EDAN Analog Only 4 09-21-2007 13:01
accessory 2 cables for mts-1000 midiizer?? kiira Analog Only 9 06-06-2004 10:20
accessory 2 cables for mts-1000 midiizer?? kiira TASCAM User Forum 2 06-02-2004 07:16
