Cubase Le 4 Midi... Please Help
Hi There Everyone,
I just started using Cubase LE 4 for recording and I have a problem when it comes to my Midi monitoring... I couldn't hear the sound coming out of my headphones when it comes to playing the midi track, but I could hear my recorded guitar parts... I exported a Midi Drum track from Guitar Pro 5 and when I import it in Cubase and play it, I couldn't hear the sound coming out. It know that I correctly imported the midi because whenever I play it I could see the monitor bars moving so that means I imported it right, but when I play it I could get no sound from my headphones... is there something i've done wrong? Please help me with this I would really appreciate any help or advice. Thank you and Godbless |
you need to route the midi drum track to a drum machine or sampler. Open up vst instruments (F11) and select the LM-7 from the drum menu. On your midi track where it says Out:, select the lm7.
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual |
here's what i've done so far: 1. exported programmed drums from Guitar Pro 5 to Midi 2. opened a new project in Cubase LE 3. added an instrument track(used the Halion option) 4. dragged the midi file to the instrument track but when i play it, i still dont get sound. when I open the presets in the Halion control, I just couldnt see any file even though I installed the halion package already(im currently using Mac OSX) please help... I really am on the end of the rope here... Im planning to get the EZdrummer but if I couldnt get through this problem, I dont think that it would be easy for me to use the EZdrummer.. thank you and I really appreciate any reply |
I don't have a mac this le program nor ezdrummer but what altitude909 said is correct. Maybe reread your manuals? It takes about three times before you can see the forest through the trees. Make sure it's a midi track and not an audio. Midi tracks don't have sound and audio tracks won't play midi. You might try going to edit and choose GM/GS/XG editor if it has one and then choose the GM mode, associated program and output to your soundcard.
You have to add it to the VST stack (F11) before it is available anywhere, this applies to all VST instruments
Do you still have to run drums through channel 10?
No, whatever you want. Just set the midi track to all
| midi in Cubase LE | PaulK | Cubase User Forum | 2 | 09-28-2005 18:01 |
| Cubase MIDI | DonaldChang | Cubase User Forum | 5 | 06-29-2005 09:07 |
| Cubase LE MIDI | TFunk | Cubase User Forum | 1 | 06-21-2005 00:55 |
| midi and cubase.......please help!!! | Tyler22 | MIDI Mania | 2 | 06-26-2004 06:40 |
| Using Mia Midi with Cubase SX | GothGirl | Digital Recording & Computers | 2 | 03-26-2004 13:59 |
