Old 06-22-2008
ksounds ksounds is offline
Dedicated Member
ksounds has a reputation beyond reputeksounds has a reputation beyond reputeksounds has a reputation beyond reputeksounds has a reputation beyond reputeksounds has a reputation beyond reputeksounds has a reputation beyond reputeksounds has a reputation beyond reputeksounds has a reputation beyond reputeksounds has a reputation beyond reputeksounds has a reputation beyond reputeksounds has a reputation beyond repute
New old stock 244
Just put two bids on this...out bid both times, took it up to $100.00. It will go for close to $300.00 I bet. Sure looks nice and new.DAMN YOU GEAR LUST
http://cgi.ebay.com/TASCAM-244-PORTA...QQcmdZViewItem
Old 06-23-2008
cjacek's Avatar
cjacek cjacek is offline
Analogue Enthusiast
cjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond repute
Yeah, it's rare to see a genuine NOS 244 / 246. Indeed, this should bid up to about 300 and if it shall go beyond, I'll be a bit stunned but not overly 'cause a NOS 244 is certainly worth it.
Whomever wins this, make sure you tell the seller to wrap the original factory box in heavy duty, large bubble wrap, so that it's at least a good 2 - 3 inches thick [all around] and place it into another box and fill the voids with something soft, like crumpled paper or peanuts, so that it doesn't move around in there.
Old 06-24-2008
TinNedd TinNedd is offline
Junior Member
TinNedd is on a distinguished road
cause it still has the original box and packing, and probably hardly used, that is why it might have been adertised as NOS?
Old 06-24-2008
analogkid's Avatar
analogkid analogkid is offline
I Bleed Analog!
analogkid has a reputation beyond reputeanalogkid has a reputation beyond reputeanalogkid has a reputation beyond reputeanalogkid has a reputation beyond reputeanalogkid has a reputation beyond reputeanalogkid has a reputation beyond reputeanalogkid has a reputation beyond reputeanalogkid has a reputation beyond reputeanalogkid has a reputation beyond reputeanalogkid has a reputation beyond reputeanalogkid has a reputation beyond repute
From the pictures I doubt it was ever used at all. One thing I would eb concerned about is the belts - assuming this model uses belts (I've never owned or peered inside one). Even not in use, belts are under tension and will eventually begin to stretch.
AK
Stock Mac Pro with only 1 gig??? vineband Digital Recording & Computers 2 08-07-2007 06:47
What exactly does B-Stock mean? MikeDMusic Other Equipment and Reviews 7 04-18-2005 14:14
B Stock 603s caleb2438 Microphones 9 10-24-2003 08:49
RUN RUN RUN to AMS for MR8! (In stock?) Datoyminaytah Fostex Forum 14 05-04-2003 11:03
