Hi!
I've always wondered this, ever since i read about recording or (mastering) to VHS tape. I hear that you can get more headroom in your mixes by recording to vhs, then back to the DAW. Is this true? I know the vcr has some sort of built in limiting, or compressor right? would the prerecorded material thats being sent to the vhs have a*natural limit* while retaining its its loudness but at a lower decibel thus allowing you to increase the volume more while in the DAW without clipping? ( not overdoing it of course) Also, at which decibel level does a vcrs limiter kick in? Thanks! I have an emu 1212m, and a behringer UB802 |
If you already have your stuff in digital, if you need more headroom, all you gotta do is reduce the signal level on your individual tracks. Assuming you're working in 24-bit, you have plenty of room at the bottom to drop your levels by several dB and increase your headroom without hurting a thing. Plus you don't have the extra D/A and A/D conversions required to go out to the VCR. Best yet, if digital headroom is a problem for you at mixdown, that's a fairly sure sign that you're probably recording your stuff hotter than you need/should be. Bring your recording levels down a few dB per track and not only will your headroom problems disappear, but you'll probably find that your mixes actually sound better. G. |
Alright.
Thanks! |
VHS tape in a HiFi machine was popular for recording party mixes in the 90's - three hours of music right there in the lounge room with no one changing the poor record & dropping the stylus.
I experimented with it for recording but it's just another layer & one you can't control well. The old, old Umatic cassette video machines had recording level controls and pre DAW weren't bad for mixing to. That was then though. |
I think maybe the whole VHS thing started back in the mid-late-80s when one could buy a VHS Hi-Fi machine that had record level controls and actually halfway decent quality preamps (relatively speaking).
I was a Betamax man myself back then before wikiality won over with VHS, but in the mid-80s I bought a NEC VHS Hi-Fi machine with a halfway decent audio section, separate L&R audio line ins (different fron the standard audio ins, which were there as well), separate L&R mic ins, seperate line and mic recording level controls, *no* AGC limiting, peak level metering and output gain control. There were also similarly-equipped machines from JVC that were quite good. Both the dynamic range and audio quality on this machine were superior to cassette and - except for the quality of the preamps and the inability to use tape saturation purposefully; VHS tape just didn't saturate the same way - rivaled a typical 7.5ips open reel deck. Add to that the fact that you could get 2 hours of audio per tape, and it actually made a pretty fair mastering medium for the home recorder/project studio user in the 80s to early 90s. Unfortunately those machines pretty much disappeared from the market after only a few years as manufacturers moved their attention to digital technology. What passes for a "4-head VHS Hi-Fi" recorder these days would have been considered a piece of crap 20 years ago in every metric, including audio quality. Add in the the competing technologies (24-bit digital, for example ) these days, and the fact that they just don't make really high quality VHS tape any longer, and the old idea of using VHS as a poor-man's mixdown/mastering medium just isn't the good idea that it used to be.G. |
It was also popular to mix from 4-track cassetes to VHS. And some guys did this backwards and recorded to VHS and then dumped it into a 4-track. Sounds like there wouldn't be much benefit with a DAW.
Tom |
It was a great alternative to cassette and much less expensive than a 1/4 reel to reel. But, that was when DAT machines cost a few thousand dollars, home computers had 20Mb hard drives and the onboard sound was just good enough to make some beeps when you screwed up, etc... It's a different world now. Before cars, people used to hitch wagons up to a horse or two, that's not quite as useful as it used to be either.
Tom |
You also had to find (or modify) a VHS machine to strip out the Automatic Gain Control....
From the original post, I think he was counting on the AGC circuit.
. How musical! ![]() G. |
| headroom vs. no headroom - on speaker cabs | SpotlightKid83 | Guitars and Basses | 13 | 12-10-2007 23:17 |
| Recording tape | Splicit | Free Ads for Music / Recording Equipment | 2 | 05-06-2006 13:41 |
| recording to VHS tape | xandro | Analog Only | 4 | 01-01-2006 09:10 |
| Recording from tape to CD via PC | Begadoc | Newbies | 4 | 12-08-2001 18:56 |
| recording onto a cd from tape | bart | Recording Techniques | 0 | 07-03-2001 10:57 |
