Go Back   Home Recording > User Forums by Brand > Pro Tools Forum
Reply    Audiofanzine Digidesign Digidesign News Digidesign Medias Digidesign Tests Digidesign Articles Digidesign User Reviews Digidesign Classifieds Ads
Old 06-21-2008
batchmister1 batchmister1 is offline
Senior Member
batchmister1 is a splendid one to beholdbatchmister1 is a splendid one to beholdbatchmister1 is a splendid one to beholdbatchmister1 is a splendid one to beholdbatchmister1 is a splendid one to beholdbatchmister1 is a splendid one to beholdbatchmister1 is a splendid one to beholdbatchmister1 is a splendid one to behold
DAE Errors
DAE Error 6
DAE Error 87
DAE is having trouble keeping up. Your disc could be too slow or too fragmented. A firewire disk could be having trouble do to the extra firewire bandwidth or CPU load. (-9019)
Pro Tools hardware: M-Audio Firewire 410
Pro Tools software version: Pro Tools 7.1 M-Powered
CPU: Intel Pentium 4
Processor spped: 2.8 GHZ
OS version: Win XP SP 2
Motherboard make/model: Intel D865GBF
Chipset: Intel 865G.
Ram:1gb
Hard drives: Internal 200gb. External 300Gb
Old 06-21-2008
wreckd504 wreckd504 is offline
Force of Nature
wreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond repute
are you recording to the internal or external?
www.myspace.com/heavyrainproductions
Old 06-21-2008
Senior Member
i am recording into the internal
Old 06-21-2008
bennychico11's Avatar
bennychico11 bennychico11 is offline
bennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond repute
do you know the rotation speed of your drive?
www.redlabaudio.com
Old 06-24-2008
rossi68 rossi68 is offline
Newbie
rossi68 is on a distinguished road
You have to record to the external drive in order to make pro tools work properly.
Rossi
Old 06-24-2008
Rossi
well, not necessarily. It's not recommended to record to the system drive...which could be causing this issue. It doesn't have anything to do with the drive being external or internal.
www.redlabaudio.com
Old 07-02-2008
playsguitars playsguitars is offline
Newbie
playsguitars is on a distinguished road
recommended disk speed is 7200 rpm. i use firewire hard drives, myself.
you should probably upgrade to another gig of ram as well. i've found anything under 2g makes for an unstable (sometimes unusable) system. make sure your background processes aren't running while you're recording/mixing/whatever.
i used to get the errors when i recorded to my system drive as well, but i think it all depends on the bandwidth your drive is capable of. should be firewire at least, if not eSATA.
Old 07-03-2008
rpires rpires is offline
Registered User
rpires is on a distinguished road
Considering that you are running a 7200 rpm disk, you could try this as an workaround.
Delete (make a backup first) of this file
C:\Program Files\common files\Digidesign\DAE\IO Settings\Last Used.pio
I had some DAE errors, and after this step, seens that DAE were rebuild or something and fixed my problems.
Not too scientific, but worked for me
C1 C2 errors wil Mixing / Mastering 5 10-17-2005 12:14
For anyone who gets the errors about HD space!! dmbpettit Cakewalk / Sonar Forum 3 04-24-2005 20:55
Mixdown Errors..Help ThunderDan Cool Edit Pro / Adobe Audition Forum 1 06-16-2004 15:52
