Go Back   Home Recording > User Forums by Brand > Pro Tools Forum
Reply    Audiofanzine Digidesign Digidesign News Digidesign Medias Digidesign Tests Digidesign Articles Digidesign User Reviews Digidesign Classifieds Ads
Old 06-19-2008
greentea9769 greentea9769 is offline
Newbie
greentea9769 has a reputation beyond reputegreentea9769 has a reputation beyond reputegreentea9769 has a reputation beyond reputegreentea9769 has a reputation beyond reputegreentea9769 has a reputation beyond reputegreentea9769 has a reputation beyond reputegreentea9769 has a reputation beyond reputegreentea9769 has a reputation beyond reputegreentea9769 has a reputation beyond reputegreentea9769 has a reputation beyond reputegreentea9769 has a reputation beyond repute
Protools/ Is it worth it?
I need to know what the hype is about ProTools. I use a recording program from my computer, but will protools make my recordings better some how. And I also heard that it cost lots of money to buy, as well as extra added things needed to operate properly. Can some give me some answers?
Old 06-19-2008
wreckd504 wreckd504 is offline
Force of Nature
wreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond repute
Are you using a PC or a MAC?
Pro tools will not make you sound better. Neither will any other program. It has a particular workflow that some people like, and others don't. A large amount of commerical studios use it, so you will be able to take your session files in without the need to consolidate to wav [or another format] files.
You will need to buy the Digi hardware interface for pro tools to run, but that hardware can be used with other software. The software comes with the hardware when you buy it.
To be honest i'm stuck at the moment, because i've used pro tools for a while, its annoying to switch. However in Pro Tools LE (HD is far more expensive), because of the limited automatic delay compensation, the 32 track (48 with the production bundle) limit, poor summing i'm tempted to switch rather than go HD.
If I could go back i'd probably still get an Mbox and learn pro tools but not upgrade to a 002. I'm not using the pre's on my 002 so its basically a giant dongle for pro tools with a volume knob. Digidesign hardware can operate other DAW's so I'd buy their cheaper interface and another program at the same time, so that when you reach the limit of an LE system you can upgrade to an apogee or rme interface and continue down the pro audio path without having to go HD.
Heres a good article on choosing a DAW
http://www.harmony-central.com/artic...buy_gear_daws/
www.myspace.com/heavyrainproductions
Old 06-19-2008
Newbie
pc
pc need to know on the pc
Old 06-19-2008
Force of Nature
The resason I asked is because you have don't have access to logic on a PC so that rules that out as a choice for a DAW.
The thing is
Protools or Cubase do not care about the type of wave being fed into them. This is the job of the Pre-Amp and the Microphone.
From tweak [ http://www.tweakheadz.com/ ]
Tip #1:
Focus on what touches the sound!
(Hint, it's NOT the computer) [OR software -wreckd]
Excellent Microphone
+ Excellent preamp
+ Excellent Converters
+ Excellent Monitors
You should also read
http://www.tweakheadz.com/guide.htm
Old 06-19-2008
Newbie
protools
Thanks i ,m going to try some of these suggestions
Protools v7.0 for Mbox 2 having problems with the protools 7.0 yunga123 Digital Recording & Computers 3 10-20-2006 19:05
ProTools MPowered - Protools LE SpeedSound Digital Recording & Computers 2 09-01-2006 18:05
Overall EQ in ProTools LE 6.4 jtcole44 Mixing / Mastering 3 07-01-2006 12:59
HELP! ProTools (digidesign) vs. ProTools M Powered (m-audio) vschiano2008 Digital Recording & Computers 3 11-17-2005 23:41
Protools HD compared to Protools LE ohmeohmy Digital Recording & Computers 2 08-22-2004 13:24
