Old 06-17-2008
Guitar4life0000 Guitar4life0000 is offline
Newbie
Guitar4life0000 is on a distinguished road
Miking A Guitar Amp
Simple question, when miking a guitar amp, how loud should you have the amp? Quiet? Loud? Very Loud? Or does it even matter?
Also, are SM57's TRUELY one of the best amp miking mics?
Thanks!
Steve.
Old 06-17-2008
pipelineaudio's Avatar
pipelineaudio pipelineaudio is offline
Official Shill as of 7/07
pipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond repute
needs to be loud enough so the amp itself sounds the way you want it ideally.
57 works fine, but its not as easy as most people make out
Old 06-17-2008
jndietz's Avatar
jndietz jndietz is offline
The Way It Moves
jndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond repute
If its a tube amp, unfortuneately you have to crank the bastards to get any good tone out of them So as long as your parents, your neighbors, your dog... blah blah... as long as they don't care... GO BANANAS!
If its a solid state, go buy a tube amp.
And yes, the SM57 is pretty much an industry standard in miking guitar amps.
I play lead guitar for a rock band called Indecision based out of Omaha, Nebraska. Check us out here
Old 06-17-2008
Newbie
hahah okay I have a tube amp and an SM57 so that helped a lot, thanks
Old 06-17-2008
WhiteStrat's Avatar
WhiteStrat WhiteStrat is offline
Go Speed Racer, Go!
WhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond repute
Thanks!
Steve.
1) Q. How loud? A. How loud is it when it sounds good? I can record mine quiet enough to let people sleep in the next room. But that's not where it sounds the best. The amp sounds best when the power tubes start warming up at around 4-5. Nobody's sleeping through that! So I use an attenuator to bring the volume back down. Bottom line is that you can record it as quietly as your preamp will allow. If you've got lots of clean headroom in your pre, you can turn the amp down, and the pre up. More importantly you have to start with "where does the amp sound the best?"
2) SM57? Yes. The debate rages and there's always someone to say that some other mic is better. And lots of other mics are better for certain things. But a 57 is a workhorse that do almost anything you ask of it. I've used 'em on everything, and even as my mic collection has expanded to include lots of more expensive specialized mics, I still use it all the time--esp. on guitar cabs.
Old 06-17-2008
Newbie
alright, thanks man!
Old 06-18-2008
tubbabubba22 tubbabubba22 is offline
Newbie
tubbabubba22 has a reputation beyond reputetubbabubba22 has a reputation beyond reputetubbabubba22 has a reputation beyond reputetubbabubba22 has a reputation beyond reputetubbabubba22 has a reputation beyond reputetubbabubba22 has a reputation beyond reputetubbabubba22 has a reputation beyond reputetubbabubba22 has a reputation beyond reputetubbabubba22 has a reputation beyond reputetubbabubba22 has a reputation beyond reputetubbabubba22 has a reputation beyond repute
can u use a large diaphram condenser to mic guitar amps if you are just using a softer clean tone?
Old 06-18-2008
tunetown's Avatar
tunetown tunetown is offline
Junior Member
tunetown has a reputation beyond reputetunetown has a reputation beyond reputetunetown has a reputation beyond reputetunetown has a reputation beyond reputetunetown has a reputation beyond reputetunetown has a reputation beyond reputetunetown has a reputation beyond reputetunetown has a reputation beyond reputetunetown has a reputation beyond reputetunetown has a reputation beyond reputetunetown has a reputation beyond repute
Many great records used SM-57 on guitar cabs. You will need to find the sweet spot on your speakers. This can vary from amp to amp. Depending on your budget, you will also have good results with the Royer 121 ribbon mic or other ribbons. They works best a little further back. Maybe 6 - 8 inches as opposed to the 57 which is usually placed as close a possible.
There is some good reading here http://www.badmuckingfastard.com/sound/slipperman.html
if you can handle the language.
Cheers
Peter
Old 06-19-2008
PhiloBeddoe PhiloBeddoe is offline
Dedicated Member
PhiloBeddoe has a reputation beyond reputePhiloBeddoe has a reputation beyond reputePhiloBeddoe has a reputation beyond reputePhiloBeddoe has a reputation beyond reputePhiloBeddoe has a reputation beyond reputePhiloBeddoe has a reputation beyond reputePhiloBeddoe has a reputation beyond reputePhiloBeddoe has a reputation beyond reputePhiloBeddoe has a reputation beyond reputePhiloBeddoe has a reputation beyond reputePhiloBeddoe has a reputation beyond repute
Yep, 57 is fine but it can take some work to make it sound good. IMHO the reason it isn't quite as sure fire as it used to be is because it sounded better recorded to tape. These days a lot of people are turning to ribbons to get a smoother top end and fuller sound, sometimes combining a ribbon with a 57.
As far as volume, this often goes with the size and wattage of the amp. Smaller amps don't have to be as loud because the often tubes saturate and speakers break up at lower volumes. But if you have a 100W amp on '1', it's probably not going to do much for you.
No rules of course, do what sounds good.
Old 06-19-2008
NYMorningstar NYMorningstar is offline
Recording Modus Operandi
NYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond repute
Another thing to keep in mind is to use less distortion than you normally have when recording and remember that the track doesn't have to necessarily sound good on it's own to sound great in the mix.
Originally Posted by chessrock
There's this thing on our site ... called "the Newbie section." And it's really cool. And even if your name isn't NYMonrningstar, you can still get a lot out of it. .
Old 06-19-2008
WhiteStrat's Avatar
Go Speed Racer, Go!
Never thought of the tape vs. digital issue w/the 57's, but you make a good point. I often just use a 57 for scratch work, but my best sounding guitar tracks are a 57 with a ribbon (sometimes an i5 with a ribbon). Good call.
Miking guitar cab dwdruman Recording Techniques 26 05-11-2005 15:39
miking my guitar amp traciiroxx Guitars and Basses 5 03-30-2004 18:48
miking guitar amp! k1enneth Microphones 9 10-17-2003 09:42
Help with miking a guitar amp RSM1000 Microphones 2 06-21-2003 05:00
miking a guitar amp?? iravage Microphones 20 05-29-2001 14:44
