Old 06-16-2008
Rickson Gracie Rickson Gracie is offline
Force of Nature
Rickson Gracie has a reputation beyond reputeRickson Gracie has a reputation beyond reputeRickson Gracie has a reputation beyond reputeRickson Gracie has a reputation beyond reputeRickson Gracie has a reputation beyond reputeRickson Gracie has a reputation beyond reputeRickson Gracie has a reputation beyond reputeRickson Gracie has a reputation beyond reputeRickson Gracie has a reputation beyond reputeRickson Gracie has a reputation beyond reputeRickson Gracie has a reputation beyond repute
Using my Digi 002rack w/ Tascam TRS-8 and M308 Mixer
Im considering using my old Digi002rack with my current analog setup.
I was thinking of tracking with the TSR-8 and then doing some minor editing in Pro Tools.
What is the easiest/best way to hook this all up?
Is the analog richness going to suffer when I import into the computer with the Digi002Rack? Will it sound digital?
Should i just scrap this idea and stick to just not having to edit anything and master to the Alesis Masterlink?
Thanks!
Old 06-18-2008
Force of Nature
oops i meant TSR-8
anyone with any advice or experience with this setup?
Old 06-18-2008
trancedental's Avatar
trancedental trancedental is offline
Dedicated Member
trancedental has a reputation beyond reputetrancedental has a reputation beyond reputetrancedental has a reputation beyond reputetrancedental has a reputation beyond reputetrancedental has a reputation beyond reputetrancedental has a reputation beyond reputetrancedental has a reputation beyond reputetrancedental has a reputation beyond reputetrancedental has a reputation beyond reputetrancedental has a reputation beyond reputetrancedental has a reputation beyond repute
Talking
You will need a way to sync the TSR-8 & 002R if you want to transfer tracks between them, editing for example. Or if you want both machines to play togther in time.
A SMPTE / MTC code is recorded on track 8 with DBX noise reduction bypassed, popular units to achieve this are as follows.................
http://www.jlcooper.com/pages/pps2.html
http://www.philrees.co.uk/products/tapesync.htm
I've used the phillp rees with a Fostex E16 & PTLE 002R without any problems, only recently got a TSR-8 so not had the chance to use it much. However the principle is the & setup is the same whatever analog recorder you're using!
If you don't need to edit tracks sync is the way to go just edit the tracks you want to & leave the others on the TSR-8 for mixdown!
Old 06-18-2008
Force of Nature
thanks trancendental.
actually i would like to just record the main tracks (drums, guitar, bass...) to the TSR-8 and then record those into the digi rack and then do everything else from there.
can i just run the line outs of the TSR-8 into the 8 line inputs of the digi rack? if i did that how would i adjust the levels?
Old 06-18-2008
poopchute's Avatar
poopchute poopchute is offline
Just back from your moms.
poopchute has a reputation beyond reputepoopchute has a reputation beyond reputepoopchute has a reputation beyond reputepoopchute has a reputation beyond reputepoopchute has a reputation beyond reputepoopchute has a reputation beyond reputepoopchute has a reputation beyond reputepoopchute has a reputation beyond reputepoopchute has a reputation beyond reputepoopchute has a reputation beyond reputepoopchute has a reputation beyond repute
I too would love to know how to do this? I have the exact same setup except I dont have the 002 rack i have the 002 factory (mixer) and a TSR-8. So I would love to know if it works and how well it works...
I own: Tascam TSR-8, Tascam M-30.
Im on the lookout for a nice Tascam M-1516...
"I sell drawings of the recording at the gigs on homemade paper."-zorf
Old 06-18-2008
Dedicated Member
You can bypass the mixer & plug the outputs of the TSR-8 straight in to the 002R but the levels might not be exact, the 1st 4 channels with the mic pres (switch the line pots on) have gain pots & you can adjust levels to suit, the other 4 have a switch on the back for -10db or +4db so use -10db
The OO2 (R) inputs / outputs run at +4db & the Fostex E-16 is around -10db the Tascam TSR-8 is probably around the same level?
Old 06-18-2008
Force of Nature
thanks thats the info i needed.
when i try to set the input for a track, inputs 5, 6, and 7 arent showing up on my drop down list of choices of input.
i only get mic/line 1, 2, 3, and 4 and 'Analog 8' to come up.
any suggestions on what i can be doing wrong?
thanks
Old 06-19-2008
Dedicated Member
Are you sure that the cables are in the right sockets as there are a few other sockets on the back for monitors ect? 5-6-7 should be beside 8.
If that's not the problem try reset the settings paths in the software?
Old 06-19-2008
Force of Nature
thanks i figured it out. i went into the I/O preferences and reset them and now they show up.
Tascam M308 or M312 Monitor Hook-up question Ginazgifs Analog Only 9 12-23-2006 20:24
TASCAM M308 dimensions EDAN Analog Only 2 09-08-2005 14:51
Digi 002rack and Behringer ADA8000 BrettB Digital Recording & Computers 7 08-09-2004 14:50
Digi 002rack questions BrettB Digital Recording & Computers 4 07-31-2004 10:42
Tascam TM-D100 digi mixer for sale kinda cheap earthrisers Free Ads for Music / Recording Equipment 0 03-24-2001 10:47
